Question about Sewing Machines
Singer Athena 2000 Sewing Machine
My machine will not reverse. I have the same problem, won't reverse when reverse button is pushed. If I touch stitch lenght knob - light comes on and it will sew backwards. is this something I can fix myself?
5 Suggested Answers
  • 323 Answers
SOURCE: my singer athena 2000 won't
I think if you watch the hook as you turn the wheel you will see that it is not moving.If it's not moving it can't pick up the thread or sew or wind the bobbin. If you really like this machine you can take it to a technician who is going to tell you you have a broken gear.Always have them replaced in pairs. On this machine there are 2 gears( 1 Pair) on the left and 2 gears( 1 Pair) on the right. If the machine is making buzzing noises, replace the machine instead of the gears. Singer makes a nice machine which sells for around $300 which will do more than the one you have and it is easier to use. Look at Model 7467. I sell quite a few of these and they don't give me or my customers problems.
sewman7
Posted on Aug 29, 2008
  • 27 Answers
SOURCE: Singer Athena 2000 Sewing Machine
Most often this is caused by a faulty reverse button ,assuming everything else works well
Posted on Jan 10, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 43 Answers
SOURCE: reverse stitching on a singer 514, HELP!
In the center of the stitch length knob (at the right side of the machine) is a button. You would push that button in to get the machine to reverse.
Posted on May 08, 2009
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
How to replace motor belt on singer 2ooo atens
I think you're referring to the Singer Athena 2000, a slant needle, touch and sew machine.
I don't have a service manual for that machine, but on all the machines that I have worked on, there are two belts near the hand wheel, and the tensioner is at the center--the part where both belts come together--and you can adjust it by loosening two Phillips screws.
However, before you attempt something like that, you will need the parts number, and I would purchase the service manual. You can get a part list free and purchase the service manual here. Singer Athena and Touch Tronic
Apr 07, 2015 | Singer Sewing Machines
How do i thread the bobbin on a singer athena 1200 sewing machine
The Athena 1200 and 2000 are "Touch and Sew" slant needle machines. Singer has not made them for many years, but I always loved them, because the bobbin is wound in place--you don't take it out! You can still get a full assortment of presser feet for them; just make sure they're for slant needle machines.
You would be wise to visit the Singer Sewing Machine site and download your user's manual--it's free, and it will show you how to wind the bobbin. There are a series of pictures there as well. There are several steps you need to take, such as raising the presser foot, selecting the blind hem stitch, etc. Sounds complicated, but I owned an Athena 1200, and I can tell you that after the first or second try, you'll find it quite easy.
Incidentally, did you know that it's one of those rare machines that will do a TRUE 1/2" basting stitch! I kept it for years, just for that ability!
Feb 20, 2015 | Singer Sewing Machines
How do I thread a Singer Athena 2000?
The user's manual for the Singer Athena 2000 is a free download from the Singer Sewing Machine site. It will show you how to thread your machine properly. A heads-up, though--the presser foot MUST be UP when you thread ANY machine from ANY manufacturer, going back at least a century!
Jun 21, 2014 | Singer Sewing Machines
Free athena 2000 Manual singer sewing machine
Singer Athena 2000 won't feed properly, feed dog ok, circuit board.
When top is removed there are four adjustments that have red dots, I think I need to adjust one of them. Can you give me advice.
Oct 07, 2011 | Singer 3343 Mechanical Sewing Machine
Trouble shooting a Singer Athena touchtronic 2000 Sewing machine I have a Singer Athena touchtronic 2000 Sewing machine. The light comes on but the needle will not move when you step on the foot pedal. ...
Yes it's true, most parts are not available for this machine anymore. You might try to push the red reset button on the bottom of the machine. Also make sure that the reset button is not being depressed by anything that the machine is sitting on, and that the reset button pushes in and out freelyl.
Apr 27, 2011 | Singer 3116 Simple
Singer Athena 2000 won't zig zag
Did you switch the metal plate to one of the ones that won't allow left/right movement by any chance?
If the wrong plate it in -The machine somehow figures out that the plate won't allow the needle to move in the left/right directions and only does a straight stitch or funky other stitches.
Jun 08, 2009 | Singer Sewing Machines
Oct 25, 2008 | Singer 132QRFB Mechanical Sewing Machine
Sewing Machines Logo
167 people viewed this question
Top Sewing Machines Experts
Bargain Box
Bargain Box
Irene Tulloch
Are you a Sewing Machine Expert? Answer questions, earn points and help others
