Question about Whirlpool GR2SHWXPB 21.7 cu.ft. Top Mount Refrigerator with External EZ Touch Water Dispenser: Black
Discoloration of ice and water dispenser on model 50544001 unit
Buffalo12980
  • 625 Answers
SOURCE: Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Posted on Aug 22, 2007
vanni7
  • 163 Answers
SOURCE: Whirlpool water dispenser ...metalic taste
Hi!!! you seem to have a bad water valve in your refrigerator.change your water filter and the water valve on the back on the frig..
Posted on Jan 03, 2009
gwshaw71
  • 83 Answers
SOURCE: Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Posted on Feb 15, 2009
Sea Breeze
  • 4654 Answers
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? appliancepartsse@yahoo.com
Posted on Jun 05, 2009
  • 77 Answers
SOURCE: Ice maker stopped making ice...no water coming
With ice makers it is almost always one of two things. The ice maker itself, or the water valve (valve is located on the backside of the frig, bottom right hand side almost 100% of the time). Figuring out which one is easy, and I will help explain.
First thing is the frig has to be cold enough for the ice maker to even start working. I'm assuming we have the cold part taken care of. Next, the machine will start a cycle and ask for water. Here is where the valve comes in. The ice maker energizes the valve and it opens allowing water to rush up the back of the frig and into the ice maker. After the ice freezes the ice maker goes into harvest and dumps the ice.
In conclusion, you either have an ice maker that stalled at some point during that cycle (in which case you need a new ice maker). Or the water valve is not opening, thus no water enters the ice maker and you get zero ice.
Quick facts: If you have ice in the ice maker and it is not dumping, you need a new ice maker. If it is empty, you have to either wait for it to ask for water or manually advance the ice maker into cycle so you do not have to wait.
At this point you will hear the water valve energize or not. If it never energizes, the ice maker is not working right, if it energizes and you get squat, the valve needs to be replaced.
If you have experience with a multimeter you could detach the harness going to the ice maker and simply hook up your leads. When the ice maker asks for water, you should get 110v reading on the meter. If you do, the valve is bad and needs to be replaced.
If I can be of any further assistance please let me know. good luck!
Oh, and the valve probably sells for between $50 and $100 depending on where you buy it. The ice maker should run between $100 and $180.
Posted on May 30, 2010
Frigidaire GLRSF266J side by side makes ice, but dispenser won't work, what can I do?
The part that holds the switch in the dispenser door may have allowed the paddle to no longer contact the switch correctly. Look for a discolored wire connector under the hinge cover on the freezer door. If it looks all in order the water solenoid located where the water line attaches to the fridge may be bad.
Jun 28, 2015 | Frigidaire Refrigerators
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
Water on the floor under the freezer side of unit
It happens to all those old refrigerators. There is a shield separating the drip container and freezer through a small hole. Check if it is blocked. This won't do much of the work and may not be stopped even if you do something. If you can, have a new refrigerator.
Apr 21, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Water dispenser is not working
Does it make ice? If it makes Ice, then you have water to unit. If No Ice and No Water, check water supply. Otherwise, you could have a bad water valve. Remove valve and the line coming off of valve to water reservoir try to dispense water and if valve is good you should have water coming from valve. (have a bucket or bowl handy to catch water).
Mar 28, 2010 | GE Refrigerators
Ice maker not working water is coming out through the front for drinking but water does not seem to be going up the line for ice in the rear of the frig
On units with both ice and water dispensing there is what is called a dual fill valve. One side of the valve can go bad, which allows water to dispense but no water flows to the ice maker. Common problem. Just search for the part using your unit's model number.
Dec 01, 2009 | Washing Machines
Ice maker not working, no water or ice dispensed.
Cause found to be faulty ice/water control board which is located at the back left hand side of the condensor behind the water solinoid valves.This is the single most expensive part of the ice maker!
Oct 13, 2009 | Westinghouse Refrigerators
Ice maker won't make ice after replacing water filter -plugged
I've had the discolored water before when replacing the filter. It normally means that there was gunk in the water line.
Do you still hear the ice maker trying to draw water in?
If not, the water pump might be burnt out.
If so, see below.
The water lines that feed the dispencer and the ice maker split after a certain point.
It's possible that the line that feeds the ice maker might be clogged. You should be able to get to it by removing a few screws and pulling off the back panel of the fridge. Then you can check them out and remove the clog.
Comment on the post if more helps is needed.
Jan 19, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
21 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
