Question about Sony Ericsson K800i Cellular Phone
Will not turn on
When i try to turn the phone on the phone will not turn on but a red light flashes on the inferred strip on the bottom right hand corner.
  • 36 more comments
  • Anonymous Nov 09, 2007
    i also encounter this type of problem...can someone pls help us.tnx
  • sajidaali Nov 16, 2007
    mt sony erricson will not turn on but a red light appears at the bottom right hand side?
  • Anonymous Nov 21, 2007
    My k800 does not turn on but when i put it in charge there is a red little light on the side of the infered port inside, i little red light
  • sherry1980 Dec 03, 2007
    I have the same problem. My wap wasn't working so I turned the phone off , but it wouldn't completely switch off and I was left with a slight glow on the phone. Nothing else worked so I removed the battery and then put it back in. The phone wouldn't turn back on at all and there was a red light flashing a few times in the infrared bit on the side of the phone. Any advice on what to do?
  • layla_b Dec 05, 2007
    My phone turned itself off and won't turn back on again. When I do try to turn it on, all I get is a flashing red light by the infared port.
  • mstaifi Dec 08, 2007
    when i try to turne it on i see just tehe logo sonyericsson please help me.thanks .my phone is k800i cuber shoot
  • Anonymous Dec 12, 2007
    i have the same experiened with the above problem, and the technician said that it is grounded can it be so,? do we any available spare parts for this unit se k800i?
  • shreck Dec 15, 2007
    When i turn on my phone produce red light at the infrared
  • brikaff Dec 15, 2007
    When i try to turn the phone on the phone will not turn on but a red light flashes on the inferred strip on the bottom...
  • Anonymous Dec 26, 2007
    will not turn on
  • Nikki2008 Jan 02, 2008
    my phone won't turn on and when i press the power button a red light just flashes
  • Wayno m Feb 24, 2008
    I have exactly the same problem!!!!
  • Anonymous Mar 08, 2008
  • maddy9990 Mar 23, 2008
    not starting only flash ligh turn on
  • clarkey2008 Mar 24, 2008
    my sony ericsson k800i wont turn on it just flashes on the infrared bit :| ive been told the phone needs 'flashing' but what is this ???
    please help i want my phone bak :(
    xx
  • karen maca Mar 29, 2008
    i got my phone fixed i dropped it and the ink leaked i got it fixed but battery wouldnt work i changed battery it worked but the battery went dead really quick i got up this morning and the new battery is also showing the infared light and will not turn on
  • jamesp98 Mar 29, 2008
    Exactly the same problem
  • Anonymous Apr 12, 2008
    When i try to turn the phone on the phone will not turn on but a red light flashes on the inferred strip on the bottom right hand corner. i had been reprogrammed it once.. but it goes back after a few weeks
  • Anonymous May 15, 2008
    my sony
  • 11outlaws May 15, 2008
    my sony ericsson will not turn on it just flashes red on the infored bit
  • lloyd todeniO
    lloyd todeniO May 16, 2008
    my k800i is not turning on..,the red light beside the fone keeps on blinking but its not turning on
  • Anonymous May 23, 2008
  • Anonymous May 26, 2008
    my phoe was switched off to change my sim and there after i couldnt turn on but i could see a red light blinking at the infrared port
  • munja May 30, 2008
    i bought a new se k800i, but after 5 hours using i activated one java program named "executor". after that my k800 turned off and when i tried to turn on it doesnt work. this is maybe from o2 cell phone
  • jassicchew Jun 20, 2008
    I am having the same problem, I bought it recently, when I clicked the "executor", the flash of the screen appeared, then the phone switched off after 2 seconds. I wonder how it happened. I tried to take out my battery immediately after trying few times to turn my phone on, but it seems dead. I hope someone would give me a reason for that. Can I do anything with that?
  • Anonymous Jun 20, 2008
    phone won't switch on after taking out the battery and re inserting it
    phone is not getting started only red light bling near infared prot when kep on charging to , i kept it for atleast 5 hrs i thought battery is down but , battery was fully charged
  • preecher21 Jun 21, 2008
    phone goes to white screen onley
  • Maureen1013 Oct 07, 2008
    The red keeps displying on the bottom right side, i have it in a charger and everything.
  • babyblue7 Oct 30, 2008
    When i try to turn the phone on the phone will not turn on but a red light flashes on the infrared side
  • Anonymous Nov 01, 2008
    hi can any 1 help me please my k800i will not turn on i have a red flashing light i have taken it in 2 a shop they flashed it and it still does not work'
    my email addy is [email protected] if any 1 can help me please thanks x
  • Anonymous Nov 03, 2008
    help! My sony ericson k800i was block out...
  • rhey1us Nov 03, 2008
  • Anonymous Nov 07, 2008
    the phone is off with the infra red light blinking red
  • adzithedevil Feb 01, 2009
    my phone jus won't turn on its jus has a red light tht flikers plz if u can help me for free contact me at [email protected]
  • Anonymous Feb 08, 2009
    my phone is not turn on
  • aveesach Feb 08, 2009
  • bojospec Feb 09, 2009
I had the prob where the infared light flashes for 5 sec and stops when i try to turn it on. some of these ideas brought forth to help solve the solution has relaxed me alot. i was about to throw out my k800i out of the 2nd storey of my home and hope it will hit the concrete and disintergrate. i might leave the battery out for 3 hours and see if it helps. i can't update the software if the handset does not turn on.
Posted on Dec 08, 2007
    Problem Solver:
  • 9 Answers
G'day, this some up a fair bit, how about this: http://trogg07.googlepages.com/
on it is a set of instructions that i've used for my phone: k800i
rate me if it helps you out
cheers
Posted on Nov 15, 2007
  • 50 Answers
The switch is not working properly this red light indicated the stand by mode or error. Have a specialist look the phone over.
Posted on Jun 28, 2007
    New Friend:
    Problem Solver:
  • 10 Answers
Hi can any 1 help me please my k800i does not turn on i ave a red flashing light ive taken it in 2 a shop they flashed it it still does not work
my email addy is [email protected] if any 1 can help me out thanks xx
Posted on Nov 01, 2008
Buy a new one..................
Posted on Oct 31, 2008
My k800i never kept its charge it would'nt recognise my wall charger and would turn on an off with the usb it also had white screen and red flashing light i disscovered that if i left in the usb for long enough for me to turn it on too the sony erricson screen then quickly slipped the wall charger in it would come up with charging screen and a picture of k800i there is no need to be flashing ir updating erom this is not necessary if you also check that usb is charging by pressing >*<<*<* go into servive settings and usb charger turn on hope this helps you all x x x x
Posted on Oct 15, 2008
Do never charge a phone when it dies on you, expesh the sony erricson ones!
the problem with mine the first time is it suddenly died on me an a red flash kept appearing beside the "c" key and after alot of attempts to turn it on the red flash would no longer flash!
so then i tried to charge it and was told that that was the worse thing to do, as it can blow the fuse in the electric board inside the phone.
that is when i had to sadly take it to the sony erricson store :(
then the other day i dropped it in cereal and it had a series of choosing when to come on for a few hours,
it would come on,
then turn itself off,
then eventually come on but the picture would be distorted.
and you can see how it would go untill after a while it wouldnt turn on and the red flashing returned.
so i resorted to charging it and completely forgot what i'd been told.
so now, ive taken the memory card out, the battery but some how cant manage to take out the sim :S
and i'm going to leave it like that for a couple of hours.
if you have any help attall for my phone to be fixed then PLEASE email me
[email protected]
hope it helped!
xx
Posted on Aug 18, 2008
How can i reflash the phone?
Posted on Jul 11, 2008
Man this is an awesome mobile, the only problem is the joystick .a
And regarding your problem with the phone is, your mobile has a virus threat it would be effecting your mobiles hardware also, i suggest you to flash your mobile once .And flashing is nothing but it would be removing all the data which is present in the mobile.
Posted on Mar 26, 2008
  • 29 Answers
In my opinion, and experience, the best options would be to first simply try charging the phone overnight. You can also use a firmware flashing service from the likes of http://www.wotanserver.com or http://www.davinciteam.com if this does not resolve your problem.
Flashing your phone with a new firmware can be risky if not done exactly as they tell you.
SEUS will not work to resolve the issue as it does not technically flash the phone. It only updates. And if your phone already has the latest firmware, it will do absolutely nothing.
Also, the answer from trogg07 is known to work on occasion.
Posted on Mar 07, 2008
  • 137 Answers
Smoe Erricsons If you let the battery go dead m they wont charge , get your sel a universal chargerm yust boost the battery a little bit and phone will be ok and charging fine again. If it doesnt work, Software Prob..
Posted on Dec 22, 2007
    Sergeant:
    Champion:
  • 241 Answers
Hey guys, http://horizonwirelessonline.com is your solution. They brought my w580 from flashing white screen to a vibrant phone, and they debranded it - all for $85 shipping included.
They are in Canada and they did it fast - 4 days from my home to them and back
Removing battery and memory card and sim and charger for 8 hours worked for me.
Posted on Dec 12, 2007
    President:
  • 1,950 Answers
Before sending your phone in for a flash or attempting to do it yourself (wotanserver), I would suggest the following. Take out the battery and leave it out overnight. Then put it back in the following day and try turning the phone on. If this didn't help, then flashing is required. You can try flashing with SEUS (Sony Ericsson Update Service) which is free (wotanserver requires credits=money). Good luck!
Posted on Dec 10, 2007
The eprom is damaged, if you reflash the eprom it should cure the problem.
www.wotanserver.com will be able to do this
Posted on Nov 10, 2007
    Sergeant:
  • 452 Answers
This may be a virus problem , try starting ur phone without a memory card , if it works format ur memory card after taking backup of ur MMC , this may b a battery problem a s well , try a diff battery also...
Posted on Oct 15, 2007
    Problem Solver:
  • 5 Answers
I agree with pernati., it's a software problem., just reflash the phone's software using wotan or seus
Posted on Aug 17, 2007
Hey for me 2 they same happened i just gave it to the service center ....i searched abt this many of them experienced the same ...it is some kind of software prob.........
Posted on Aug 05, 2007
  • 3 Answers
This happen with me if the battery if power free, check battery health.
Posted on Jul 08, 2007
2 Suggested Answers
SOURCE:
otacon
  • 1950 Answers
SOURCE: Will not turn on
Before sending your phone in for a flash2.gif or attempting to do it yourself (wotanserver), I would suggest the following. Take out the battery and leave it out overnight. Then put it back in the following day and try turning the phone on. If this didn't help, then flashing is required. You can try flashing with SEUS (Sony Ericsson2.gif Update Service) which is free (wotanserver requires credits=money). Good luck!
Posted on Dec 15, 2007
Will not turn on
Dec 15, 2007 | Sony Ericsson K800i Cellular Phone
Hi I have a vizio tv control with the key board and it all just stopped working so I thought it was the batteries changed them still not working ????? Help Please
Test ur tv remote control first see,if it is working,malfuctions or completely dead?U have a Digital Camer wright?Yes.Digital Camera can read Infer Red signal Output by the tv remote.Yes?Turn the Digital Camera on and take the tv remote point it at the Digital camer and pushes all the remote buttons the Infer Red signal will read all buttons Infer Red signal flashes u can see on Digital Camer viewing screen.Pushes all remote buttons see flashes of white lights.Mean the tv remote control it it good or not.Take some cottons ball soak it with some rubbing alchachol clean the tv Infered Red sensor on the tv frame near the power LED incation light.Might be dirty,Still not reading the Infer Red signal.If 100% it is the tv remote control is the cause,it CPU is dead.Try website like Remotes.com to buy another the tv original remote.
Jul 29, 2011 | Vizio VO47L 47 in. LCD TV
Black strip down the right hand side on my viera plasma
Hello
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
Angel
Thanks...
Aug 02, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Xbox
see this web page for your problem on red light
Sep 04, 2008 | Microsoft Xbox 360 Console
One red light bottom right hand corner
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jul 22, 2008 | Microsoft Xbox 360 Console
Sony Ericsson K800i Cellular Phone Logo
1,509 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
