Seagate freeagent go PN: 9KW2A6-502 880gb - Computers & Internet
  • 16 Answers
SOURCE: Where get free drivers for Seagate FreeAgent Go
I'm not sure what drivers you're looking for in particular, however, I've found the Seagate FreeAgent download page for you. I've clicked around and all of these downloads appear to be completely free.
These files should be completely safe for download as they are provided by Seagate but don't neglect to set a restore point on your system before downloading and installing. The files are .zip so they must be unzipped, your system should be able to do this without any additional software.
Also, be sure to register your equipment to get customer support should contacting them be necessary. Some of these will require you to contact the company in order to gain access to the download.
Check here:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=freeagent-downloads&vgnextoid=3723b5b59b7d5110VgnVCM100000f5ee0a0aRCRD
Posted on Oct 16, 2010
mbase213
  • 728 Answers
SOURCE: seagate freeagent drive
Hi George,
The seagate freeagent should be reconigized by windows. The question is are you adding an additional partition or do you want to create a brand new partion. I'm assuming you want to add.
You can add more space to existing primary partitions and logical drives by extending them into adjacent, contiguous unallocated space on the same disk. To extend a basic volume, it must be formatted with the NTFS ile system. You can extend a logical drive within contiguous free space in the extended partition that contains it. If you extend a logical drive beyond the free space available in the extended partition, the extended partition grows to contain the logical drive as long as the extended partition is followed by contiguous unallocated space.
  1. Open Command Prompt.
  2. Type: diskpart
  3. At the DISKPART prompt, type: list volume
    Make note of the number of the basic volume you want to extend.
  4. At the DISKPART prompt, type: select volume n
    Selects the basic volume, n, you want to extend into contiguous, empty space on the same disk.
  5. At the DISKPART prompt, type: extend [size=n] Extends the selected volume by size=n megabytes (MB).
Value Description list volume Displays a list of basic and dynamic volumes on all disks. select volume Selects the specified volume, where n is the volume number, and shifts the focus to it. If no volume is specified, the select command lists the current volume with focus. You can specify the volume by number, drive letter, or mount point path. On a basic disk, selecting a volume also gives the corresponding partition focus. extend Extends the volume with focus into next contiguous unallocated space. For basic volumes, the unallocated space must be on the same disk as, and must follow (be of higher sector offset than) the partition with focus. A dynamic simple or spanned volume can be extended to any empty space on any dynamic disk. Using this command, you can extend an existing volume into newly created space. If the partition was previously formatted with the NTFS file system, the file system is automatically extended to occupy the larger partition. No data loss occurs. If the partition was previously formatted with any file system format other than NTFS, the command fails with no change to the partition.
You cannot extend the current system or boot partitions.
size=n The amount of space, in megabytes (MB), to add to the current partition. If you do not specify a size, the disk is extended to take up all of the next contiguous unallocated space.
Notes
  • To open a command prompt, click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  • You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings might also prevent you from completing this procedure.
  • To extend a basic volume, it must be formatted with the NTFS file system.
  • You can only extend a basic volume onto the same disk.
  • You can only extend a basic volume if it is followed by contiguous unallocated space.
Hope this helps!
Thanks
Mark
Posted on Jan 04, 2009
  • 85 Answers
SOURCE: Seagate Freeagent not being installed
beck up your all files, then install a New Operating system, u install and un-install it, therefore it seems that some files are missing. and the fact is not installing and showing the device again.
so install a fresh O.S, and install it again,, and Enjoy..
good luck
shafky
Posted on Jun 26, 2009
SOURCE: i knocked over seagate 500 freeagent and it beeped and groaned an
I'm not expert but try freeze therapy. I did it in on mine and it did not work but I hear it does rarely. Basically all you do is wrap the harddrive in a plastic bag tightly to prevent any form of moister entering, leave it in for about two days and plug it back it. It's said that sometimes if the lense is shaken out of place the cold would make the metal go back to original placing. This means you plug the harddrive in while still frozen, just something try before throwing it away or replacing it.
Posted on Jul 08, 2009
  • 218 Answers
SOURCE: my son knocked the seagate freeagent down and it
Probably bad. Is it not being recognized by your system, no matter what you do?
Posted on Jan 05, 2010
I have a Seagate FreeAgent Go, 500 GB, sn2GE6NC5Z. My computer crashed and took it in for repair with the seagate. In fixing the computer, the service person erased everything on the seagate drive. Is...
FreeAgent™ Software Version 2.1.600 includes folder encryption. This download is compatible with all versions of 32- and 64-bit Windows. This software may be used in conjunction with FreeAgent DockStar™.
FreeAgent? ' Go Software Download for the FreeAgent? ' Go in case the software has been deleted from the drive
FreeAgent? ' Desk Software Download for the FreeAgent? ' Desk in case the software has been deleted from the drive.
FreeAgent? ' XTreme Software Download for the FreeAgent? ' XTreme in case the software has been deleted from the drive
hope this helps you
Jul 25, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
My seagate harddisk (seagate freeagent go 320GB) (PN:9za2ag/SN:2ge1p760) makes a sound when i plug it into my laptop) i already learned that my laptop has enough power etc. and 3 months ago it worked...
If it is a clicking sound then the hard drive has developed a fault where it cannot read the data from the disc, that is what the noise is, when it is trying and failing to retrieve the data. Only a data recovery firm could sort it.
May 21, 2011 | Computers & Internet
Nu pot formata hdd seagate free agent go 250GB
poti descarca manualul de utilizare pentru Seagate FreeAgent Go facand click pe acest link:
http://www.seagate.com/staticfiles/support/freeagent/fa_go_qsg_r2.pdf
Citeste cu atentie si vei gasi modul de formatare a unui astfel de disk.
Daca pot fi de ajutor in continuare, anunta-ma! Daca raspunsul meu a fost de ajutor , te rog voteaza-ma.
Mar 10, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate pn 9ZA2A4-500: I 'think' I got a successful backup to my desk top one time. Since then, many months, I have never been able to get a successful data dump. Maintanence of a good back up to my HP...
Hi ,
Here are several back up sofwares wich could help . I still think Acronis is the best .
If you are under Windows 7 , you don't need third party programs anymore . Just go to Start , type " back up entire system " and follow instructions .
Regards .
Jan 23, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Its a free agent go 250m gb PN-9ZA2A4-500
... and your question is _________________________________________ ???
Dec 23, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Check here:
Oct 16, 2010 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
My son knocked the seagate freeagent down and it
Jan 04, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have just purchased a Seagate 500GB Desktop hard drive
There is software preloaded on the disk. If you have AutoPlay turned off in your system, it won't start automatically when you connect the drive. Just go to MyComputer and open the drive and you will find a setup file there to install the backup software (I think it's called Launch.exe).
Oct 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Lost seagate freeagent PRODUCT KEY
WIth the original freeagent disk in hand,call Seagate and ask if they can give you the product key based upon the sereal number on the disk. If you purchased freeagent on line and downloaded , they wil have a copy of your invoice purchase . Just contact then as ask again for your product key.
Jun 19, 2009 | Seagate FreeAgent Pro 500GB External USB...
Computers & Internet Logo
297 people viewed this question
David Payne
David Payne
