Question about Garden
Show fuel line diagrame for a talon 25cc garden hawk trimmer
5 Suggested Answers
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
bbap
  • 71 Answers
SOURCE: i have a 25cc homelite weed trimmer.... the fuel
You will need the correct size fuel line first. Follow this:
1. Remove the old filter/weight from the fuel tank.
2. Take a new fuel line piece about 8 inches long and cut about a 45 degree angle cut on one end.
3. Lightly moisten the cut end of the fuel line and insert it into the tank from the outside, pushing it in while turning as far as possible.
4. Use a needle nose plyers to reach in and pull the line to the fuel line cap. Cut the line and replace the filter.
5. Pull the line back the way you put it in leaving about 4 inches within the tank and re-attach to the carburetor or primer bulb (depending on the actual model/age)
It will work, but it is extreemly important to have the correct size fuel line to work with.
Posted on Sep 27, 2010
rycgl
  • 1545 Answers
SOURCE: need diagram for fuel hoses for a garden hawk
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Posted on Feb 27, 2011
rycgl
  • 1545 Answers
SOURCE: 25cc Gas Line Trimmer- both
It is never a bad idea to do so. If the unit has some years on it, I would say yes. Inspect it, and if it is still nice and white, keep it. If it isn't, I would replace it.
Posted on Aug 14, 2011
What fuel goes in talon grass hawk AT33550 line trimmer
2 stroke engines generally run on a fuel mix of 50:1
100ml of 2stroke oil in 5L of petrol
Dec 17, 2015 | Garden
How to string a talon garden hawk trimmer
https://www.youtube.com/watch?v=tXUrdUoS_PU
Mar 18, 2015 | Garden
Diagram for fuel lines on 25cc homelite ut20811b gas trimmer
Hi martinez7568
I believe the picture below is what you are looking for.
Please take time to rate me
Bud
Oct 22, 2012 | Homelite Garden
Which fuel line "port/inlet" on the Walbro wt-380 goes to the fuel tank? It's on a Craftsman 25cc Gas "Weed Wacker" Line Trimmer purchased in 2002. It has Walbro WT-380 carburetor with external primer...
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Jun 25, 2010 | Craftsman 25cc Gas Line Trimmer
Starting Instructions Talon Grass Hawk
i would like insructions how to replace trimes cord
Mar 13, 2010 | Talon Electronics - Others
Repairing fuel line on craftsman 32cc weed trimmer.
Aug 24, 2009 | Craftsman 25cc Gas Line Trimmer
New fuel lines, wont stay run, swapt in/out line, wont stay run
Sometimes simply removing the carb and placing it in a carb dip will clean it without tearing it apart, also check or replace the spark plug. Make sure you have compression, good spark, and that fuel is getting to the carb. If that doesnt work, email me and I'll find you a diagram. Jblee1975@yahoo.com
Jul 11, 2009 | Craftsman 25cc Gas Line Trimmer
Fuel hoses routed wrong on weed eater fuel tank
Go to sears.com then parts store then type in model no. You should find a parts breakdown hopefully that will help.
Mar 16, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
193 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
