Question about Ovens
Meaning of signs on the oven knob of UPO ST60 electric cooker
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: I have an AEG cooker but the marking around the cooker knobs have
Hi.
You need thermostat knob and main oven control knob.
Posted on Nov 20, 2008
barkencoa
  • 3463 Answers
SOURCE: how can i mend the grill and oven on my electric cooker?
If the rings work o/k then could be timer if it has one make sure it is set to manual and not auto.
Another thing it could be is a faulty selector switch, which selects the different functions.
Hope this helps.
Plz rate my solution.
Thanks.
Posted on Dec 31, 2008
protek480
  • 1723 Answers
SOURCE: Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
Posted on Sep 03, 2009
Testimonial: "very useful thanks"
Two large cookers light up but as soon as the knob is released they stop burning
bad igniter switch aka the knob ur pushing is bad can check with a multi meter for continuity
Mar 07, 2015 | Ovens
Cooker knobs jammed
I have just checked on my cooker and the knobs just pull off,although they were a bit tight
Apr 01, 2014 | Stoves 720EF Electric Double Oven
What does it mean when a gas cooker needs hardwiring
It means that it does not have a cord and a plug to just plug it into a wall socket...
It needs to be "hardwired" into the electrical circuit with a regular piece of wire...
heatman101
Dec 13, 2010 | New World G60m Gas Single Oven
Replacement knob for Hygena Turbo electric oven
You should be able to get a replacement fairly readily, try www.appliance-parts.co.uk or www.cooker-parts.co.uk.
Jan 04, 2010 | Ovens
Bottom oven on Cooker Cannon c60gcw will not ignite, continuouos sparking and no gas when knob turned on
Fault caused by trapped and therefore cut wiring to main oven valve at bottom rear of cooker causing wiring overheat melting and open circuiting electrical supply.
Sep 15, 2009 | Ovens
Sep 03, 2009 | Ovens
Oven won't light - electronic ignition oven
Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
Aug 12, 2009 | Kenmore 33169 Gas Single Oven
I need six knobs for a 1950 Frigidaire model RM-45
I have the same model stove for sale. here is my number 678-644-2161 samantha
Jul 23, 2009 | Ovens
Hi.
Nov 19, 2008 | Ovens
Re: my whirlpool digital oven
The red key sign is a lock against children. To cancel it you have to hold the two buttons at the same time for 5 seconds (you activate it the same way).
The STOP sign appears after the cooker switches of after a power cut. You just have to press the left button, and, using the right knob, set the time.
Jun 24, 2008 | Ovens
Ovens Logo
57 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
