Question about Kodak 4200 Slide Projector
Slides advance continusly
Havent used projector in years when finally got the wheels to turn, the slides advance cotinusly
  • 33 Answers
I can solve this i think but am pretty busy right now. It's also cheap and usually easy. If you can carefully open the shell (body) , with it unplugged of course,note where all the thin wires belong for when you put it together again. Assuming you have the projector open and on its back, look near the top, centre roughly. You'll see a white, thick gear that gets driven by a long worm gear/pulley that is driven by the motor belt. Above the thick gear is a silver-grey metal catch or "trigger" and resting on - or near it- will be a (usually) copper coloured thin metal "finger.
in normal operation this finger catches on the grey metal trigger which flips into position and catches the clutch built into that thick gear. When you activate the slide advance, the solenoid, for a moment, pulls the finger off the trigger which moves the triger which allows the clutch to engage and turn the thick gear, driving the mechanism. What's happening is that over time the light grease has thickened and the trigger is not engaging properly.
In some cases, all you need to do is just activate that slide advance a couple of dozen times, or let it keep advancing a few dozen times. You might try this before takign it apart. It selldom is enough but might be. usually though you'll need to look carefully to the pivot point of that grey metal trigger. If you have any contact cleaner for electronics (degreaser) get a little on and behind the rivent that holds that trigger and let's it pivot. With your finger, getnly rock the trigger back and forth. Repeat a few times if necessary as that cleaner evaporates quickly. If you don't have such cleaner, you can use a bit of WD-40 or alcohol can sometimes do the trick. Rubbing, not whiskey! Whatever you use to clean out the old, dried lubricant there, be careful not to let it get into other areas of the mechanism! Especially the WD 40 whihc has both grease cutter and oil. Oil in the wong places will give you bigger problems.
Eventually the trigger should move very easily and return to position quickly when you release it. Now you want to put a drop or two only on that pivot point, of the lightest oil you can find. Most easily accessed is light sewing machine oil.
You may decide to plug in the projector now -remove the lamp first. it is dnagerous at this point so be careful, or before you plug it in, put the shell cover back on. If you cover it hough, you can't see what's happening. In any case, run it, advance the slides via the remote preferably, a few times and unplug it.Hopefully it's stopped advancing continuously by now.
Take a look at the point where the "finger" engages the "trigger". You want to be careful not to bend the finger or things'll get out of whack.But IF you can (unplugged again!) spare just a tiny bit of grease from that thick gear, put just a bit on the trigger where the finger rests. If you can locate a clear coloured teflon added lubricant called Super-lube (also sold under at elast one other brand name I can't recall), that is the stuff Kodak used.
Reassemble carefully and try 'er out. If you run into any problems, give me a shout at . Put Kodak in the heaidng so you don't get spammed out.
Posted on Feb 19, 2009
  • Derek Madge Feb 19, 2009
    oops! ignore that first line,lol!
On my kadak 4400 I placed a slide tray with 35mm slides in. After turning the power on I attempted to advance the first slide. Nothing happened with the slide. I turned it off reset the tray and tried. ...
Try turning your projector on without a slide tray. Cycle it 2 or 3 cycles in reverse. Place the tray back on the projector and cycle forward. By cycling it a few times in reverse, it re-sets the cycling mechanism.
May 08, 2012 | Kodak Carousel 4400 Slide Projector
I just dragged this projector out of my grandma's basement. I have a new bulb and the projector appears to be in working condition except for the slide advance--the slides advance continuously. How...
There is usually a sliding tab on the side of the projector (behind the handle) that toggles between "manual" and "automatic" advance. (Some models will have a couple of pre-set advance settings between "manual" and "automatic." These usually advance the slides every three to ten seconds.) Push the tab to the manual setting--this will allow you to use the buttons towards the front of the machine to advance your slides.If moving the tab doesn't work it may be broken or jammed.
Jul 29, 2011 | Kodak Carousel 4400 Slide Projector
Slides will not advance.buttons do not seem to work
1. Does the SELECT button work? If so, hold it & remove the tray (if one is present). Skip to step 3.
2. If the SELECT button doesn't work, remove the slide tray (if one is on the projector) using the emergency tray release in the center hub of the projector. 3. 3. Turn the projector on & try to cycle a few times in reverse. This is how you clear a slide change mechanism jam in the projector.
4. If that didn't work, then either you have a broken cycle circuit wire (usually an orange wire within the projector) or the release wire is trapped under the cycle pad. Refer to the following diagram for the correct "at-rest" position of these 2 contacts. (If you don't feel comfortable doing this, then contact a factory-trained repair dealer).
Good Luck !!
Feb 15, 2011 | Kodak Carousel 4400 Slide Projector
My carousel tray will not advance. I was looking at slides (the unit has not been used in 10 yrs) and everything was working fine. Then the unit stopped advancing the slide tray. I have lost the owners...
I'm assuming you are talking about a Kodak Slide Projector. If this is so, and it hasn't been used in at least 10 years, then it is probably an earlier-produced model. If the fan & lamp work and just the slides don't advance, then chances are you have a broken solenoid "link". This "link" joins the Cycle Solenoid and the Slide Change Mechanism together. As the projector ages, the link (made of plastic) gets hard, brittle & cracks. This will, in literally one slide change, make the projector go from working to not working.
Parts are still available (, but this repair should not be tackled by the untrained. I recommend you contact a factory-trained dealer to make the repair.
Dec 20, 2010 | Office Equipment & Supplies
I just purchased an older Kodak slide projector with a carousel on top. Everything works fine but the carousel won't advance. When you click the next button, the plastic arm that should advance the...
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
Nov 14, 2009 | Kodak Carousel 5600 Slide Projector
I'm testing my 4400. With slide tray loaded (no slides in tray) when I advance the carousel the light from the lamp does not shine through. Does the carousel have to have slides drop down in order for the...
Yes!! The projector is equipped with a "dark shutter", which means light is only allowed to exit the projector when a slide is in the gate. That eliminates the "white screen strain" on your eyes when no slide is present. Happy New Year!
Sep 16, 2009 | Kodak Carousel 4400 Slide Projector
Slide/tray advancement
This link talks specifically about a Kodak slide projector. However the faulty mechanism in your Telex works in a similar way if you feel up to taking it apart. If you do, mark every screw and piece you remove, in a diagram. Though your symptom is sporadic advancing and the other link is continuous advancing, it's essentially the same cause, as sticking trigger mechanism in the clutch release.
Jan 27, 2009 | Telex 3280 Caramate 80 Slides Rotary...
Kodak Carousel 600 Projector - mechanism stops with slide out
Open the back up and spray just a LITTLE bit of WD-40 into the cavity where the bit of spring emerges from the grease covered cam shaft. This will loosen up the grease that has dried up. It may take up to half an hour to work on the grease. If things are improved but not perfect, repeat. If any WD-40 spills out, mop it up with Q-tips and especially avoid the rubber belt.
Please do NOT advance things manually ans especially don't pry apart any of the plastic or metal cams on the cam shaft in an effort to correct the timing. You will put it out of waht and it will take a whack of time and/or an expert to get it back in whack!
Jan 06, 2009 | Kodak 4200 Slide Projector
Kodak Carousel 760H wont advance or reverse
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
Nov 23, 2008 | Kodak Carousel 4600 Slide Projector
Change a bulb
Hi Janet,
Put on rubber gloves.
Hold bulb and push down and turn counter clockwise to remove bulb.
Maybe hard to remove, try spraying WD-40 first. MAKE SURE AC CORD(power cord) is disconnected. Wait a few hours and try to remove the bulb.
Jan 12, 2008 | Cameras
Kodak 4200 Slide Projector Logo
527 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
