Question about Sony STR-DE545 Receiver
MY SONY STR-D990 BLOWS A FUSE WHEN I TURN IT ON
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I have a Sony STR DB930. Something happend and it
The fuse blowing is a symptom of something seriously shorted internally. What preceded the initial problem? Smoke is bad. Fire would be soon to follow without the fuse blowing. Take it to a tech.
Posted on Feb 09, 2010
What would cause new fuse to blow when powering on (Sony STR-DN1030 Receiver).
Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
Dec 08, 2014 | Sony STR-DN1030 7.2-Ch. Wi-Fi Network A/V...
SONY RECEIVER MODEL STR - D315 keeps blowing a fuse
When the main fuse blows on a sony, it is usually caused by shorted output transistors. You would have to replace these transistors before the unit will not blow the fuse and power up correctly.
May 23, 2013 | Audio Players & Recorders
Turn my sony str-de597 on and fuse blows right away
Disconnect the speaker wires and speakers. Does the fuse(s) still blow? If yes then it's time for an authorized Sony repair.
Oct 31, 2012 | Sony Audio Players & Recorders
Sony reciever distortion
it could be an overload in the output tranformer
Jan 17, 2012 | Audio Players & Recorders
Hi,I have a Sony STR-D990 Receiver,and when I plug in power I see light on volume knob only, no other light turns on like the display etc. Please for some ideas on what i can do to fix this amp ,it's old...
I had the same problem with mine. Turned out to be a bad solder connection on the Printed Circuit Board on top of the power transformer towards the rear of the reciever. If you flex the board by the connector going to the display you might see it come and go. I resoldered the connections and now all is good.
Apr 29, 2010 | Sony Audio Players & Recorders
Feb 08, 2010 | Sony STR-DB930 Receiver
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
May 27, 2009 | Sony STR-DE635 Receiver
Sony compact disc receiver LBT-D990
KSS-213D lens has soldered joint to protect laser diode from static voltages damage when it shipped. You need to unsold laser diode protection joint and then try.
Oct 01, 2008 | Sony LBT-D990 Shelf System
Sony STR-DE310
Our Sony STR-DE310 displays the message "Protected" and will not operate. We have not used it for awhile, but it worked finte the last time.
Jan 27, 2008 | Sony STR-DE310
Sony STR-DE545 Receiver Logo
27 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
