SOURCE: pulled the wires for the crts off. didn't label them correctly help
Yes the first one near the rear of the set goes to the blue crt which if you are looking in from rear will be on the far left and the middle will go to green in the middle and the 3rd or last will go to red on the right. A rule of thumb in this case is alway red on right and green is always middle crt.
SOURCE: Front Panel Connector: JFP1 hookup
You can go to the link below and see the directions for that. Turn to page 2-17
http://www.premioinc.com/pc/manuals/mb/m266/m266.pdf
SOURCE: Does anyone know which connector to plug into on power supply
Double check all the connections from the AC line and from the power supply to the other circuit boards. The connectors you are mentioning are identical as per the picture below.
If you need a new power supply, you can find one from this link.
Testimonial: "I have a few more questions that I would love to ask Jaime867. He produced a drawing of my circuit board within minutes and was a big help. Thanks"
SOURCE: oyxgon no.1 sensor replaced 2 time With code P0031
could be a fuse for the heater,check all fuses because some fuses feed other fuses and are not labeled as such
Testimonial: "I will check every fuse tomarrow, hope that works Cecil"
