Question about Canon Powershot SX110 IS Digital Camera 9.0MP
Each time i replace battery it automaticly says change the battery
It is 2 years old
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Replace the clock battery following the instructions beginning on page 194 of this manual.
Posted on Jan 04, 2013
Onan JB 7.5 KW with Transfer panel battery trickler lasted 10 years on deep cycle now only 2 years?
[PDF]Onan Master Service Manual.pdf
michaelstractors.com/forum/.../Onan%20Master%20Service%20Manual....
Jun 28, 1978 - rated at seventeen and one half (17.5) kilowatts or less. ... of an Onanengine generator set, automatic transfer switch, running time meter and .
Oct 12, 2015 | Electrical Supplies
Typical battery life for cordless home phones
Rechargeable batteries will last 2 to 3 years so your experience is normal. Time for a new battery which is a common type. Can be found on Amazon and elsewhere. For example: http://www.amazon.com/T-Lucent-AT3211-2-Cordless-Battery-Replacement/dp/B0083YBU5O
Sep 15, 2014 | AT&T ATT AT3211-2 DECT 6.0 Digital...
Car will not start
Because the engine turns over means your started had enough voltage to turn ON. You can easily test the voltage on the battery with a volt meter. It should be about 12.0 Volts when the engine is not running. Batteries should normally be charged every few days for about 1/2 hour each time. You can go a short time for a couple of weeks without charging as long as you don't get in to a habit of doing that. If you went for months without running your car; I assumed you had to replace the battery already or your battery would not have been able to turn over the engine or hold a charge.
The automatic door locking is the least of your problems. It might be your car did not have a battery of proper voltage for an extended period of time.
Gasoline does not age well if you did not place any additive for prolonged storage. Even the additive for prolong storage says about a 6 month period. Maybe you should take out some gasoline from your tank to see if it still looks good. I normally don't fill my tank but every 1 to 2 months (without a problem) with no additive added, but 1 year is a long time. My guess is 1 year old gasoline may have changed over time and thickened and it could have contaminated your fuel system.
Depending on how old and how much fuel is in the tank can affect your next step. If the fuel is the problem; you will have to drain the tank and possibly have someone use one of the pressurized fuel cleaning treatments. You might need a new fuel filter, and I know there is a pressure regulator to return the fuel to the tank as well as fuel injectors and the fuel rail. I have never had gasoline that old, so you might need a professional mechanic if you are dealing with old fuel in the system.
The only gasoline I trust to age over time is Coleman fuel in a sealed container (also known as white gas). This can be found where they sell outdoor camping equipment. I don't know if that will help, but I had to run 1 gallon of this in 1992 Oldsmobile 88 because there was no gasoline. Coleman fuel is ultra refined gasoline without the extra additives they normally put in gasoline.
Apr 01, 2014 | 2005 Saturn L-Series
Roma 2001 battery cutting out at 90%
2 years is not unusual for battery decay try this
take out battery completely
start the computer and let it get rolling
insert the battery and see what charge level is there
sounds like the battery is due for replacement
May 22, 2012 | Computers & Internet
Car won't start, even automatic locks don't work
sounds like you need to replace your battery. If you havent tried to either charge the battery or have someone jump start your car and then let it run for awhile to charge up your battery. If you have done all those and things are still not working its time to replace. If your battery is about 4-5 years old or older then you need to replace battery. Hope this helps...Rick
Apr 13, 2012 | 2000 Ford Windstar
S5500 loses time and seeting when battery is changed
you have to slash your mobile .this can be done in a mobile service center.first they reset the phone and again they will install the mobile software
Jul 25, 2009 | Fuji FinePix E510 Digital Camera
Whenever i start up computer, the system clock & date revert to january 1st 2007 - HP pavilion slimline 6 months old
Replace the cmos battery on *********** board. Generally it last 2-3 years. Fault can happen anytime. So get it replaced and change time and date.
Dec 17, 2008 | HP Computers & Internet
How to replace Battery
OPEN the case back remove the old battery look the number of the old battery and change of new battery
Aug 25, 2008 | Columbia Elkhorn Countour Watch
Canon Powershot SX110 IS  Digital Camera 9.0MP Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
