Question about Ice-O-Matic ICEU220HA Undercounter Ice Machine
Icematic N20L. I have the same problem. The machine is making ice but it does not drop into the collection bin. Please tell me what I can do to solve the problem. stoop@matopimotors.co.za
2 Suggested Answers
SOURCE: Ice-o-matic wont' drain water from bin
the purge valve empties the tray... the bin just drains with gravity... If you bin isn't draining... it must be clogged somewhere.
Posted on May 30, 2009
Once full, ice melts and then doesn't start making ice again until bin is completely empty
There should be a temperature sensor (thermostat) close to the top of where the ice comes out of. This determines the height of the ice in the bin by controlling a call for cooling/making ice. This thermostat may be sticking, or is not sensitive enough to read the drop in temperature of the depletion of ice.
Feb 27, 2015 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Icematic n131m
The more activity the freezer and fridge see, the more cold escapes. If the freezer defrost system gets issues (broken defrost heat coil, stopped up vents, frozen peas in coils) things slow down. Find the defrost timer and mark the knob on it with white-out to see if it moves. It moves very slowly, one rotation a day.
Nov 26, 2013 | Kitchen Appliances - Others
I'm having problem with my icematic 132M . I freezes the cubes allright , but the cubes doesnt fall out before the harvest stops, so the cubes is still hanging on in the machine which causes the m
First i would clean the machine per manufacturers instructions with nickel safe cleaner and sanitizer. When the plates get dirty it will cause ice to hang on to plate. Also check the thickness of ice if to thick it will not come off plate.
Oct 08, 2012 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice machine will not work. bin full light will not go out! Please help!
there are lens on the bin that shoot a beam across if there is ice it stops the beam and tells it's full. It can also become covered with calcuim and also tells the bin it is full. I would clean these lens gently with a cacium remover. they make products for this. its like an acid that clean off the calcium without damaging your lens.
May 17, 2011 | Scotsman Ice Maker 600LB CM3 30inW...
We have a commerical manitiwoc ice machine that after the bin fills up it cuts off and has to be reset. After resetting it fills up again and a blinking light comes on telling me that something is wrong....
Manitowac uses a plastic deflector which has a magnet located on the bottom. When the machine drops the ice the deflector opens breaking the circuit to the bin switch. This would indicate "Bin Full" condition. As the ice is used the deflector closes and the magnet comes in touch with the bin switch.
Most likely the bin switch needs replacement.
Feb 22, 2011 | Freezers
My cme 256a8 model scotsman ice melts to fast will not fill my 250 lb. bin in four days. What is the problem? in a hour run time it makes 7 lbs of ice and 4 lbs. water. in one dump cycle it makes 3 lbs...
There are a couple of things to check. The machine must be level. You can remove the front cover and the plastic sheet that covers the plate where the ice is made. Check to see that the water is flowing from the manifold at the top of the plate. You may have to pop the hose off the end of that manifold to clean the water holes out. It must flow evenly over the plate. Probably the most common problem is the radiator coil there the fan draws air through is clogged up so that it can't dissapate heat properly. You should be able to feel a lot of hot air moving through the coils. The fan cycles on and off periodically to maintain a certain pressure in the freon. That is normal. Clean the fan coils and level the machine.
Sep 16, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Ice dispenser will not dispens ice . light dims when pushed. ice maker works fine
It may be a good Idea to remove the ice bin, clean and dry ant the same time with bin removed see if while pushing the door light switch and the dispense ice control if the auger fork in the rear of the ice bin that normally turns the auger will rotate. Sometimes ice or water collects in the bin and locks the motor from turning and sometimes the motors go bad. Tell me your results, Thanks, Sea Breeze
Apr 23, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Where are the bin full sensors located for cme306as-1c bin full light on will not make ice.
It is a set of eyes located in the very back right and left hand side where the ice drops into the bin. Take some ice machine cleaner and wipe down the eyes. You should be able to pull the holders out to get to them better.
Jan 30, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
I have an icematic n45s but it's not making ice and it was second hand so dont have the service manual. Does anyone know if there is anything i can do or do i need to get a repair guy out?
i have a icematic F120 and 2 of the 3 led`s are on (the no water led and too hi-loww cond temp 3`stand by) Does anyone know what is the problem.!?
Sep 18, 2009 | Freezers
My binsensor lingh is on but my bin is not full so my ice machine
I see you already said you bin sensor light was on. The drop door has a metal tab that waves over a sensor as it opens, if that part when it closes does not tell the board that door is shut the the board thinks the bin is full. I know you already know that but until I can talk to Scotsman on the phone or review their service manual for your model. One good thing about Scotsman is they are very helpful to their customers. Unless the machine is obsolete.
Apr 23, 2009 | Scotsman Ice Machine, Cuber, 1930 lb....
Ice-O-Matic ICEU220HA Undercounter Ice Machine Logo
203 people viewed this question
Top Ice Kitchen Appliances - Others Experts
mike cooper
richie46
Tom Chichester
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
