How can i adjust the brightness on my old panasonic tv with no remote. Tv does not have a menu button
techman
  • 3130 Answers
SOURCE: tv still dim after adjusting
sounds like you may have gotten a pwer surge and blew out the regulator in the set. If you know how to trouble shoot regulator curcuitds then it could be as simple as the str type regulator. If you dont then open the set and see what module the set has it would start with a 9-something as it should be inside the back cover and then contact http://www.tristatemodule.com and see what they charge to repair the entire pcb or the exchange of the module. As Zenith sets are made to be repaired in house by quilifyed repair stations IN hOUSE. Good luck to ya.
Posted on Apr 27, 2006
TVtechmaniac
  • 140 Answers
SOURCE: The picture on my JVC TV is too dark
On the inside of the TV, on the flyback transformer there should be two controls. Turn the one that says "screen" very slowly clockwise while looking at the pix. The pix should get brighter as you turn it up- if you go to far you will see lines in the pix or the TV may shutdown.
Posted on Aug 30, 2007
techman
  • 3130 Answers
SOURCE: Accessing menu without a remote
You will need to get an original replacement remote or the original to access the menu. An original replacement remote for this TV set is not cheap! You can see what you need here
http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=SDP50A5K&brand_pn=PIONEER_SDP50A5K&mode=large&uid=11944400246090
Good Luck
Posted on Nov 07, 2007
SOURCE: Bright Star Br100P-D remote TV Panasonic
the remote is a hotel remote. Bright Star BR100P-D For a thomson tv. I just need to know how to reprogram the remote.
Posted on Aug 24, 2008
SOURCE: Remote Sensor on TV Doesn't Work and Can't Manually Adjust Menu
i bought tv ,just week ago and tv sensor on tv want wwork, that why we cant use remote.
Posted on Oct 09, 2008
Brightness adjustment
There will be a control panel on the TV, usually on the side of the TV. You can use these buttons to enter the menu and adjust picture brightness. You can find an inexpensive universal remote easily.
Nov 04, 2013 | Sharp Aquos Televison & Video
Tip
Service menu codes panasonic
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
Panasonic TV's after 1996 can be set to "Serviceman Mode" with the
following remote control sequence:
-select the SET-UP icon and select CABLE mode.
-select the TIMER icon and set the SLEEP timer for 30 minutes.
-press the ACTION button twice to get out of the menus.
-change to channel 124.
-adjust the volume to minimum (0).
-Hit the VOL down button on the TV itself (not on
the remote) and a red "CHK" should appear in the upper corner.
-press the ACTION and VOLUME DOWN buttons (again, on the
TV, not the remote) you will toggle between AGING and SERVICEMAN modes.
Select Serviceman mode. The POWER button on the remote control will
select one of the five Serviceman Adjustment modes.
The modes are:
B - Serviceman VCJ SUB Adjustments. These include sub-tint,
sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,
audio and video adjustment, and vertical size.
C - Serviceman VCJ Cut-off adjustments. These include Red, Green
and Blue cut-off, red and blue drive, automatic fine tuning
(AFT), RF AGC (RF gain control), horizontal center, beam limit,
etc.
S - Serviceman Options Adjustments. These involce the PIP and
clock.
M - Serviceman MTS (Stereo/SAP) adjustments.
CHK - the mode you first entered. Normal picture and sound, lets
you check things over and still have a hotkey into the
service menu.
There is one more adjustment that isn't in the five modes, it's
global. When in either the yellow or red CHK mode, you can press
RECALL on the remote control to enter the purity field check mode.
This lets you select a pure white, red, green, or blue screen. A
good thing to walk away from if you just want to temporarily freak
out the floor manager, but it will be fixed as soon as the TV is
turned off. Oh well.
To get out of Serviceman mode, press ACTION and POWER on the
receiver simultaneously for at least 2 seconds. The TV will momentarily
shut off and then comes back on.
PE77U / PX75U / PX77U / PZ700U / PZ750U
PD60U / PX6U / PX60U / PX600U
PD50U / PX50U / PX500U :
* Hold down the {VOL -} button ON THE PLASMA TV.
* Press the {RECALL} button 3 times on the remote.
* The Service Menu will be displayed.
* Use {1} {2} on remote to navigate main menu items.
* Use {3} {4} on remote to navigate sub-menu items.
* Use {VOL+} {VOL -} on remote to change item value.
* Write down all values before changing
Once a value is changed, THE CHANGE IS MADE.
* Power off to exit service mode and save.
PA25UP / PD25UP / PX25UP :
* Using the remote control:
* Press the {MENU} button.
* Set "Antenna A" to "Cable".
* Select "Timer" menu and set sleep timer to 30 min.
* Press {OK} twice to exit menus.
* Tune to channel 124.
* Press and hold {VOL -} button ON THE PLASMA TV.
"CHK" appears in on top-left corner followed by 5 letter/numbers
(which are the cumulative hours in hex numbers)
* While the "CHK" is displayed, press the {OK} and {VOL+} buttons
ON THE TV simultaneously to toggle between Modes:
?ƒ?¢?¢?€??¬?¢?'¬? Red "CHK" for Serviceman ?ƒ?¢?¢?€??¬?¢?'¬? Yellow "CHK" for Aging ?ƒ?¢?¢?€??¬?¢?'¬?
* Press the {POWER} button on the remote to select one of the six
Serviceman Adjustments Modes.
A. MTS ADJUSTMENT
B. CLOCK ADJUSTMENT
C. VIDEO ADJUSTMENT
D. HDEF ADJUSTMENT
E. VDEF ADJUSTMENT
F. DAF ADJUSTMENT
G. OTHER ADJUSTMENT
* Press {CH+} {CH -} on the remote to select the settings
on each of Service Adjustment Modes.
Write down the original values before modifying anything.
It's easy to erroneously adjust the wrong item.
* Press {VOL+} {VOL -} on the remote to change values.
* Press the {POWER} button on the TV to exit the service menu.
LCDs / CRTs / RPTVs :
* Hold down the {VOL -} button ON THE TV.
Model PT45LC12:
1. Press and hold Vol Dn on center panel and press recall button on remote until Work Mode is displayed on screen.
2. Press and hold Vol Dn on TV and Swap button button on remote until Factory Adjust is displayed on the screen
3. Use Channel Dn button to select Digital and press the Action button.
PROJECTORS :
* Go to "Options" menu.
* Highlight "OSD".
* Then press and hold the {ENTER} button,
until the Service Menu is displayed.
* Press the {MENU} button to exit.
on Apr 29, 2015 | Panasonic Televison & Video
To adjust the colour and brightness of the tv
yes there should be a menu button, normally in the middle of the remote, than you scould be able to change all your settings.
Apr 19, 2012 | Televison & Video
Tv picture is too dark and looks like everyone wearing lipstick went to menu but it doesnt help tv just a yr old
You need to adjust the brightness, tint, contrast, and brightness in order to get the color to even out. Menu; settings; display. If you no longer have the remote, either buy a universal, or use the tv buttons(channel + - should navigate the cursor) to enter menu mode. Be patient because it can be frustrating; so don't do it when agitated, hungry, or tired. GL
Apr 05, 2012 | Sanyo Televison & Video
We need the device code of the panasonic Tc42px24 plasma HDTV thank
Hello
The modes are:
etc.
clock.
service menu.
OK.
Feb 13, 2011 | Panasonic Tc42px14 42 in. TV
How to adjust color for better picture
Hello there,
For the Best Picture use the HDMI Cable and here are the Settings for the color setup.
Adjusting Your HDTV Settings
Using the On-screen Display (OSD)
The remote control or the control buttons on the side of the TV can control all the function settings. The
OSD allows you to adjust contrast, brightness and other settings. The TV will save changes made to the
settings, even if the TV is turned off.
The OSD consists of several menu options. The main menu options may vary depending on your
selected input source.
Note: Some of the main menu options may have additional submenus, for example, the TV Rating
submenu for Parental Controls.
The remote control or the buttons on the side of the TV can control all the function settings. The HDTV
Settings App allows you to adjust contrast, brightness and other settings. The TV will save changes made
to the settings, even if the TV is turned off.
The HDTV Settings App consists of several menu options. The main menu options may vary depending
on your selected input source.
1. Press the VIA button.
2. Press ? or ? on the remote control to select the HDTV
Settings App, and then press OK. The Main Menu will be
shown on the screen.
3. Press ?, ?, ?, or ? on the remote control to select one of
the menu options:
? Input
? Wide
? CC
? Sleep Timer
? TV Settings
? PIP
? Network
? Bluetooth
? Help
4. Press OK to select the option or feature you want to adjust.
5. Once the menu option is displayed, press ? or ? on the
remote control to select one of the items to adjust.
6. Press OK to select it, and then press ?, ?, ?, or ? to adjust the selection.
7. Press BACK once to return to the previous screen. To return to your program once adjustments
have been completed, you can do one of the following:
a. Press EXIT on the remote control.
b. Press the RED button on the remote control.
c. Highlight and select the RED X in any menu.
i hope this was helpful don't forget to Rate
Jan 26, 2011 | Vizio M550NV 55 in LCD HDTV
Theres no brightness setting in menu. it only has cc sleeptimer and exit. how do i change the brightness?
Hello
You can adjust the brightness control on your 19PR19 Philips Tv. For that you have to go to picture contol menu
Do it as follows
To adjust your TVs picture control, select a channel and follow these steps.
[1] Press the Menu Button on the remote control to display onscreen menu.
[2] Press Cursor up or Cursor Down button until the word Brightness is hilighted. For each press of Cursor Up or Cursor Down button you can go through Colour, Picture, Sharpness, Tint, Colour temp etc, depending on the adjustment you want to make.
[3] Press Cursor right or Cursor Left buttons to increase or decrese the selected option. Ok.
Nov 17, 2010 | Philips 19PR19 19" TV
The remote does not work and the tv will not accept an universal remote.How can I adjust the color, brightness, contrast, and etc. with out a remote. The screen is dark and can not be adjusted without a...
Tries press the tv menu button on the tv front frame bazel to select color,brightness,contract so on...Adjust ur setting.Try website like remotes.com to buy an a exact to the original remote.
Oct 20, 2010 | Panasonic PV-20DF63 20 in. TV/DVD Combo
How do you turn on the Backlight on the screen?
If the screen backlight is not on, first try adjusting the brightness.
Press TV/AV button on remote to select TV mode. Press the MENU button on the remote. Using the arrow keys (navigation buttons), choose picture mode and adjust the brightness and contrast.
If your TV screen is still not lighting up in a dim room, then the backlight is broken.
You have 90 days labor and 1 year parts from date of purchase.
Oct 19, 2010 | Haier HLT71 7 in. Portable TV
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
