Question about Dell Inspiron 1525 Laptop Jet Black
Dell inspiron 1525 memory test failure
I have a dell inspiron 1525 for 6 months.Last month it started to shut down without a warning.It looks like an instant shutdown and i don't get that memory dump message in that blue screen.I've ran a memory test and sometimes it shows that it works fine and sometimes it looks like the memory failes every test.I'd like the know if the problem is the ram or could it be something more serios.
Thanks a lot.
  • 2 more comments
  • olaruatomic Jan 19, 2009
    it was new...out of the box
    At first I thougt it was a virus so i reinstalled vista....three times:| No viruses there...i'm sure.The fans are running.I thought about that too.Even more since at a moment they were running real hard ant the cpu had about 80 degrees centigrade:| I don' know how....but it doesn't happend any more.And it seems to turn off only when the memory is at about over 80% in use(i have 3 gb)
    It wasn't bought with vista...it had free-dos.I figured it should be taken to the dealer...i just hoped it might have been somethin else:( Anyway,thanks a lot:)
  • DEKR
    DEKR May 11, 2010
    was this a brand new or did you get it used
    Genius:
  • Dell Master
  • 1,102 Answers
Were you able to do a virus scan
try to get on in safe mode by constantly pressing F8 during restar select safemode
See if shutsdown in safemode
Do you here the fans running when it's on
You may just need to do a restore
Let me know what happens in safe mode
Posted on Jan 19, 2009
  • DEKR
    DEKR Jan 19, 2009
    so your up and running did you go into safemode
    was this system bought with vista or did you upgrade.
    If you have more problems it should be under warranty
    I would take it back
  • DEKR
    DEKR Jan 19, 2009
    Honestly I would have installed xp instaed of vista
    but see if you have anymore problems if so I would advise returning it.
Dell inspiron 15 beeps 7 times
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 23, 2012 | Dell Inspiron 15 Laptop Computer- Intel...
My Dell Inspiron 1525 is shutting down at it own during working. From last 4 months I having this problem. during working, laptop shutdown automatically. And after that once I'll start again, its again...
there are 2 possibilities 1. cpu fan ventilation got blocked, so use you old tooth brush to clean it 2. the system is infected with virus. so user online virus toll to clean the virus any i recommend to us this link to clean the virus. it clean virus, spy ware & malware.
www.bitdefender.com/scanner/online/free.html.
i hope it will help you.
May 07, 2010 | Dell Inspiron 1525 Notebook
My two friends have the same screen freezing problem with a 6 month old Dell Inspiron 1525 laptop. Have to remove the battery in order to shut it down. Dell remotely re installed the original software to...
John,
As the laptop is still in warranty period, let us not open it up and loose the warranty. And also that she has taken additional insurance, you can threaten both o=the parties, ie, Dell and the insurer, that you will take them to the consumer forum (or whatever you have equivalent to that) which I am sure you have in your country. Yes, it is an additional headache, but sometimes you have to tolerate such aches and pains.
Jan 19, 2010 | Dell Inspiron 1525 Notebook
The screen on my dell inspiron nootbook started flickering last month, two weeks ago it started to turn completely dark at times and today 3 min after i turned it on a blue screen popped up and it told me...
windows dose not control any flickering unless the driver is being updated if thats not the case your flourecent bulb might be getting old inside the lcd!
Aug 29, 2009 | Dell Inspiron 1525 Laptop
Dell Inspiron 1525 Blue screen & windows error messages/reformat
Do a recovery first and if you are still getting a blue screen on this 1525 call dell and ask for a replacment do not go any further in trying to repair it yourself as anything you do would just make matters worse if its out of warrenty then the only thing you can do is try:
1. clean the unit if there is any dust
2. try new memory modules
3. run a memory diagnostic on it using windos diagnostics
4. recover the operating system.
I hope you have some good luck with this advice.
Jul 17, 2009 | Dell Inspiron 1525 Notebook
Memory write/read & address line failures on Dell Inspiron 1525
you may need to format that memory because it may be corupted.
Dell Inspiron 1525 Battery won't charge
i recommend you to buy new one.. for dell 1525 .. must better
Jun 08, 2009 | Dell Inspiron 1525 Notebook
Dell 1525 completely shuts itself down eg. when playing Sims 2
This did the trick http://en.kioskea.net/faq/sujet-4281-dell-inspiron-1525-overheating-and-shutting-down
Mar 09, 2009 | Dell Inspiron 1525 Notebook
Immediate shutdown, Heat problem, Low battery back-up
I have the same computer and had the same issues. It finally got to the point where it no longer tured on at all. I sent it in to Dell and they repaired in about 2 weeks. Send it in now before your warranty expires. But be sure to call support first and get an RMA number or you may never see your system again.
Jan 04, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell Inspiron 1525 Laptop Jet Black  Logo
284 people viewed this question
Alun Cox
