Question about Pacific Digital PRIMEVIEW801 Video Recorder
Pacific TV - Need to tune without remote
Well recently my remote decided 2 pack in on me just wondering if anyone knows how to tune a channel in without using a remote. It's the pacific model with a built in video player can anyone help please?
2 Suggested Answers
SOURCE: lost remote
Go up to ch 80 and the next one is the AV ch
Posted on Jun 29, 2008
  • 50 Answers
SOURCE: does not provide code for my pacific dvd player
You can perform a manual search.
Press and hold TV,SAT,DVD or VCR until the centre light blinks red.
While it is blinking press 0000
The flashing will speed up.
Press the power button repeatedly - it will cycle through all codes.
When your device turns off (powers off) press the okay button.
It should now power on and off correctly.
Check the other buttons to see if everything works.
If it does not start the process again - it will hit another code which will also power down the device - takes a long time but should work - manual states it may take 20 mins - practise says longer!
Posted on Jun 01, 2009
Hi I have bought acoustics solutions tv second hand model LCD26805HD I cannot retune it can anyone please advise? Thank you
You need the (original correct) remote. Alternatively, you can use a programmable remote, but the ''menu'' must also be compatible with the TV. If you cannot ''navigate'' the Menu and Settings with the remote, you are stuck without a solution. // With the remote you enter the menu ''settings'' and then enter ''channel tuning.'' Then set for either ''manual tuning'' or (best bet) set for ''auto-tuning.''
Jan 01, 2015 | Televison & Video
Programming my tv with a remote
you can program the channel manually, just press the menu button in the tv panel. select preset and then manual fine tuning to tuned every channel you want to watch and then save it.to make a manual fine tuning, press manual then select channel you want to tuned and then press vol. up/down button to search right frequency channel.do this process in every channel you want to tuned. hope this can help.
Sep 15, 2012 | Haier HL24XLE2 LCD TV
How do I tune TV channels on my Sharp CX48G4 TV without a remote control? There is no tuning / settings panel on the TV itself which is very strange.
press the preset button on the front panel once then (TV should be on) the on the screen there should be words the likes of (Auto VHF 1 60.00mhz) now the Auto stands for auto tuning VHF stands for its frequency where its going to search the 1 stands for the channel where its going to start with 60.00mghz stands for the lowest signal to which its going to start now that you have understood all that just press the volume up button then it will automaticly locate all your working channels leave till it stops for when does it will start from channel 1 to which I believe that you be able to see the channel working so press the up button on the channel button to check the rest of your channels hope this will solve your problem!
Jun 01, 2009 | Televison & Video
Pacific TV sky remote code
Pacific TV's are made by Alba...using my Sky+ Manual the code is 0043.
I just used this code on My pacific 7107 ASDA model and my Sky remote now controls this TV. Good luck to you.
May 26, 2009 | Televison & Video
Toshiba 2100TB tuning without the remote control
If you are sure, that there's no way to do it manually on the TV, there are only two solutions: buy a new remote control according to your TV set model (sometimes it's hard to find) or buy a universal remote control
Jan 30, 2009 | Televison & Video
Vcr channels only go to 13
the VCR my not have a tuner capable of receiving channels outside of VHF/UHF tuning. Best bet would be to search on-line for a owners manual for your VCR.
Jan 29, 2009 | Durabrand DWT2704 TV
How do i tune tv channels?
I am afraid thatyou need the original remote to access tuning universal remotes will not give you this option. An original remote will probably be very expensive check with your local TV dealer.
SUPER8
Jan 05, 2009 | Televison & Video
Lost remote
Apr 17, 2008 | Pacific Digital PRIMEVIEW801 Video...
Mitsubishi TV model CY2525
as tv is old please replace it by new kit or whole pcb. now a days you get new pcb(CHINA MADE) at cheap rate with remote & mo of channals more.
Sep 26, 2007 | Televison & Video
Pacific Digital PRIMEVIEW801 Video Recorder Logo
584 people viewed this question
Top Pacific Televison & Video Experts
Electro Med Services...
Are you a Pacific Televison and Video Expert? Answer questions, earn points and help others
