Question about Yamaha HTR-5940 Receiver
Att uverse remote won't turn on yamaha reciever
I have att an uverse remote that turns on the uverse box, LCD but it will not turn on my Yamaha reciever. However, one the remote will turn the reciever off. How can I get it to turn the rcvr on and off? I tried all of the codes and doing the manual code method. Help. Same problem with the Uverse remote and my receiver.
  • 6 more comments
  • HarleyBiker Jan 19, 2009
    Same problem with my Marantz SR8002. Tried all ATT's instructions. Turns unit off but not on. Still using the remote for Marantz to control unit.
  • justinrose Feb 28, 2009
    I have the same problem with an Onkyo TX-SR606. I tried all of the listed Onkyo codes, but not luck. I'll try searching for codes as described in the post.
  • bogh Mar 01, 2009
    I have the same problem but for my HK (AVR65) and Denin receivers. If I search using the FF key it will find a code to power it off, but not back on, or will not find a code at all.
  • r Rose
    r Rose Mar 02, 2009
    same thing happens to me with my Yamaha HTR-5835. Goes off fine but will not power up with the remote... what a pain in the arse...
  • Anonymous Mar 22, 2009
    Same issue here, Yahama receiver codes don't work. I tried manually entering them as well as using the automated find, neither worked.
  • clay2 May 16, 2009
    Samre as the others. cannot control Yahama HTR 5935 receiver with AT&T U-Verse remote. Is there any fixes?
  • Anonymous May 19, 2009
    Tried using the above solution for Yamha RX-V663 receiver, but no luck. Too bad, too, because I can't get harmony remotes to control the cable box as well as the Moto remote.
  • Anonymous Mar 30, 2014
    Att Uverse box connected by hdmi cable. Morantz Sr7007 is not picking it up
I used the code 5167 to program my ATT remote for the Yamaha RX-V671. It turns it on and off and controls volume.
Posted on Jan 16, 2012
  • Shawn Sep 01, 2012
    I have the RX-V671 too. Using the code (5167) did not work for me. I could get the unit to turn off, but not back on.
Do an automatic search for your code.
  1. Turn on the device you wish to program
  2. Point the remote control at the device
  3. Press and hold the mode key (i.e. tv, dvd or aux) you want to program
  4. Without releasing the selected mode key, press and hold the OK key simultaneously
  5. Release both the mode key and the OK key -All the modes keys will flash twice indicating programming mode
  6. Enter 922 by pressing the number keys on the remote control -The selected mode key will flash twice indicating correct entry (for anything other than AUX go to step 7, for the AUX mode searching only, press and release the play key then press 1 for VCR 2 for Receiver/Tuner 3 for Amplifier or 4 for Home Theater In The Box (HTIB) - The AUX mode keys will flash twice indicating correct entry)
  7. Press and release the PLAY key, every time you do this, autoserach will try a different code, continue to do this until your device turns off. (if you weren't paying attention and you miss it, the REW key can be used to go back through the codes one at a time, and the ff key can be utilized to move forward through the codes one at a time.)
  8. To save the code press the ENTER key (below the number 9) then press the exit to return to normal operations. (the selected mode key should flash three times
  9. Turn you device on by selecting the appropriate mode and power.
Posted on Feb 02, 2009
  • imcjim Apr 02, 2011
    Yamaha HTR-5835 works with the AT&T Uverse control with code 5167.
    You'll have to set your AUX on the remote to control the volume too. Seehttp://www.ehow.com/how_5066878_program-... for details on assigning the volume of the Uverse controller to the AUX key device.
LSoko007's SOLUTION works for only turning Yamaha receiver OFF. NOTE: Yamaha remotes have two power buttons - one for ON, and one for OFF.
Better idea, if your Yamaha Receiver cam with a LEARNING remote...use it, not the UVerse Remote. Much easier. You'll have to sacrifice some Uverse buttons, but it beats the multi-remote pileup. Hopefully you have the Remote with the Channel buttons separate from the <^> arrow buttons, cuz i dont so i have to use the arrow buttons for going up/down channels via PIP. Not perfect, but again, it beats the multi-remote option.
Posted on Sep 24, 2010
    New Friend:
I have AT&T Uverse and I just successfully programmed the remote to power on/off and control volume on my Yamaha-RX550. Try codes 6009 or 6012.
Posted on Jul 05, 2015
2 Suggested Answers
SOURCE: Att uverse remote won't turn on yamaha reciever
I think they use different codes for on
Posted on Aug 28, 2010
Trying to program Uverse remote for Emerson 32 flat screen
i install uverse, the auto seek is done by hit and hold TV and OK. wait for lights to flash enter 900 and push play over and over SLOWLY and when the tv turns off, press enter.
NOTE: some tvs WILL NOT program to our remotes
Jul 04, 2010 | Emerson LC320EM9 32 in. LCD HDTV
I have att an uverse remote that turns on my Yamaha receiver, but won't control the volume. Model No rx v480
You need to try other codes for Yamaha, as clearly the one you have put in the remote is incorrect, perhaps it was for an earlier model.
Mar 07, 2010 | Yamaha HTR-5730 Receiver
I have Att Uverse and a Samsung LCD. We have
If your using the IR remote, the actual colors of the tv are what is causing your problem. What I have found to solve this is go to your local ATT corp. store and order the RF remote this will solve your problem. The techs don't carry these on their truck.
Jan 01, 2010 | Samsung 52 in. Flat-Panel LCD HDTV
I need to program my at&t uverse remote with the Emerson 19 inch TV/DVD. I do not have a code.
Dec 25, 2009 | Emerson LD195EM8 19 in. LCD TV
Att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to helpme@att.net, and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
Apr 04, 2009 | Televison & Video
Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
Mar 19, 2009 | Vizio VO47L 47 in. LCD TV
Emerson tv and at&t uverse
Try code 1465. On my Emerson LCD TV the only thing it won't do is turn the TV on -- all other functions are controlled by the AT&T U-Verse remote however.
Jan 21, 2009 | Emerson EWF2704 TV
Samsung DLP 56' TV turns itself off when I initially turn it own. (I turn it on, then it shuts off for approximately 5-10 seconds and turns back on. Sometimes it does it a couple of times before it stays...
The problem is with the ATT UVERSE HDTV BOX and not the Samsung DLP TV. There is an inherent problem with the ATT UVERSE HDTV Box when using a HDMI cable. This was verified by the ATT UVERSE Technician.
Thanks,
Dec 13, 2008 | Televison & Video
Yamaha Receiver/Amplifier 5003, 5014, 5015, 5021, 5102, 5103, 5104, 5105, 5106, 5118, 5135you can use those codes
Nov 28, 2008 | Yamaha HTR-5730 Receiver
Yamaha HTR-5940 Receiver Logo
6,032 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
