Question about Creative Labs ZEN Stone MP3 Player
My zen stone mp3 player won't play no music no more
When i turn my player on the green light stay's on solid and when i push the play/pause button a red light blink's up 2 times and then go's back to the solid green light.There is music on the Player.
Please can somebody help me, cause i like the player a lot.
  • 2 more comments
  • luisrgg Feb 06, 2009
    Just the same. It doesn't turn off, the light has been green since yesterday....
  • Robbiesweny Feb 08, 2009
    i have the same problem when i turns on the light turns green but no music comes on and i cant turn it off unless i press reset button
  • Anonymous Mar 15, 2009
    Exactly the same problem with mine
  • Anonymous Apr 26, 2009
    is it working now?
SOURCE: zen stone mp3 player not switching on
I had given up on my Zen ever working again. I had tried the reset button numerous times to no avail and all I had was flashing blue lights on the lower right, nothing seemed to be working. After reading this suggestion I tried holding in the "volume+" button while the player was hooked up to AC current and charging and at the same time pushing down the start button - suddenly I was back in business, the Zen screen lit up and said it was rebuilding library. I had all but given up! Thanks for help, I will NEVER again fast forward.
Posted on Jun 14, 2008
My Creative Zen Plus 2GB stopped working. When I tried to turn it on the screen would start and then give up during startup. Computers would not recognize it as the stone but would come up with a drive, which I couldn't open. If this is happening to you see below:
If you are getting a drive coming up when you plug it in (but not named "stone" or whatever you called it then try opening it.
If it says it needs formatting then this may help.
Right click on the drive and choose to format. When the format program comes up it should have the incorrect file system selected. Something beginning with N? Anyway don't format it in this type.
Select FAT as the file system and press start.
Check to see if your player is working now.
If not then try to run the recovery tool which you can download from here. Once installed, run the recovery tool.
This is how I sorted mine out and it's working fine now. Hope this helps somebody because I couldn't get an answer from anybody else.
PS I lost about 7-8 hours worth of work on this B*****d and missed a deadline because of it :(
Posted on Jun 17, 2008
SOURCE: My Zen Stone Won't Charge
That happened to me once, I'm not sure why. but the next time I plugged it in, it worked fine. Otherwise, can't tell you what to do
Posted on Jun 20, 2008
User Guide:
My player is not responding, what do I do?
If your player stops responding, reset the player. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring files.
  1. Insert and remove a straightened paperclip from the Reset Hole.
  2. If this does not work, proceed to Formatting Your Player.
WARNING: This step deletes all your player's content. If possible, back up all your player's content on your computer before proceeding.
  1. Make sure your player is connected to your computer and you are logged on in Administrator mode. For details about Administrator mode, see your operating system's documentation.
  2. In Windows Explorer, right-click your player and select Format.
  3. If this does not work, proceed to Reloading Your Player's Firmware in Recovery Mode.
(Not applicable for 1 GB and 2 GB player models without speaker)
  1. Download the latest firmware before proceeding.
  2. Disconnect your player from the computer, and then turn off your player.
  3. Press and hold the Volume Down button. Continue to hold the button until you have performed Steps 4 to 6.
    If you accidentally release the button, start the procedure again.
  4. Press and hold the Power/Play/Pause button.
  5. Connect your player to your computer's USB port.
  6. After 5 seconds, release both buttons.
    Your player will be recognized as a USB Mass Storage Device.
  7. Double-click the firmware file you downloaded earlier, and follow the instructions on the screen.
Why does formatting my player in Windows Vista take a long time?
Windows Vista formats devices differently from earlier versions of Windows. As such, your player may take a significantly longer time to perform a full format. Rest assured that once formatted, your player will perform as expected. To format your player in considerably less time, use the Quick Format option instead
Posted on Jul 13, 2008
SOURCE: Creative Zen Stone Plus won't sometimes turn on
try sync-ing ur mp3 with windows media player 11.
http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/welcome.asp?
then click on "Click Here if you require further information/assistance."
Posted on Nov 19, 2008
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
Screen went black. Shut t.v. off and tried to turn it back on. Power comes on, front light is green, and in about 3 seconds the t.v. shuts off, green light goes off. Was playing dvd at the time. Shut off...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix. SD TECH
Jul 15, 2011 | Mitsubishi WS-55819 55" Rear Projection...
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 07, 2010 | LG 42LC2D 42 in. LCD HDTV
When I turn on my Canon iP3000 printer the power light blinks five orange and one green light and continues to to so. It will not stay solid green.
Hello try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 02, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Help turning on
Push the play/pause button and hold it down for a few seconds until the light turns on. Once the light is on and solid push it again. The light will blink while it is playing songs.
Jan 05, 2009 | Coby MP-200 MP3 Player
S9000 canon printer ink tank full
Hi
Try this see if work for you.
may work
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
Nov 02, 2008 | Canon i950 InkJet Photo Printer
Shuffle not working, blinking green-yellow led.
If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
Jun 25, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Creative Labs ZEN Stone MP3 Player Logo
409 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
