Question about Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel
How to repair leaking monda mixer tap - Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel
4 Suggested Answers
  • 268 Answers
SOURCE: brought a new monda vege spray sink mixer for
it does, hot connection goes one side and cold connection goes on other. If you get it wrong then just swap em. It intalls better then you one you took off. I believe it just requires 1 nut to go on bult.I replaced mine in 3 minutes.
Posted on Oct 07, 2010
twoduckster
  • 370 Answers
SOURCE: Is there any reason why the hot and cold can't be
The only way is to get a new faucet. This one was designed for separate hook ups. Any plumbing supply house can get you what you want. Its an easy install, but will have to be a new unit.
Posted on Dec 25, 2010
  • 129 Answers
SOURCE: How to remove the cartridge
first shut off the water under the sink:) next put the stoppers in the sink so you dont drop anything in the drain:) then examine the handle closely and you will find a plastic/rubber "knob" like a wood dowel which is hiding the bolt we need to access to remove the handle. carefully remove it (it may be gone already depending on how old your faucet is and it will be pretty small) most likely you will need an "allan" key to remove it. now there is just the threaded ring which holds the cartridge in place. now its possible that grohe makes a tool designed to remove this ring. i am actually not familiar w/this model but you do not need it. you can use a pair of channel locks w/a dish towel and a lite touch to loosen the ring (ritey titey lefty loosey:) now the cartridge should come rite out but it may take a little coercion. just let me know if you need anything else and good luck:)
Posted on Jul 27, 2011
How do I repair a leaking mixer tap?
take the set screw out and repair the plastic washers inside it
Aug 31, 2014 | Delta Bathroom Basin Single Handle Chrome...
How to repair kitchen mixer leaking from swivel not the tap
You will need to take handle of to see where the leak is coming from. It could be from the cart. or the spout o rings or both.
Aug 24, 2014 | Plumbing
Leaking sink tap base
If I understand this correctly, you will need to remove the tap handle, the surround which sits against the sink, then the tap body, then unscrew the spindle till it comes free, and replace the o-ring on the spindle.
If the leak is under the sink, or if it is a mixer tap, please clarify that.
Jan 10, 2014 | Home
Oliveri mixer taps
turn off the hot and cold water supply, place a container under the sink where the hose meets the Sink mixer.
release the pressure from the tap by opening the tap to let the water out.
use a suitable tool to undo the flexible hose from the underside of the tap, there should be a small "O" ring on it which you will have to replace as the "O" ring is possibly the cause of the leak.
Oct 01, 2013 | Home
How to remove the cartridge from a monda sink mixer tap?
Jul 27, 2011 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Dripping from mixer tap in kitchen
This is a failure of the washer in the valve of the mixer tap. You can remove most of these to change the washer that is worn out. However even if the valve is faulty with a worn out thread the tap can leak.
Use the correct tool to remove , model not mentioned .
Jan 24, 2011 | Garden
Is there any reason why the hot and cold can't be changed over in a mixer tap? Our model is a Monda. The instructions are to connect hot and cold to specific sides of the tap, but this doesn't suit our...
Dec 25, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Brought a new monda vege spray sink mixer for kitchen.Not sure how to connect the mixer hoses together.No picture instruction were provided which makes it hard to install.
Oct 06, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
I have mixer taps fitted to my kitchen sink which leak from under the mounting seal when the taps are turned on.when the taps are turned off the leak gradualy stops and the actual tap never leaks,do the...
It appears that the seal at the base of the tap is worn or the screw collar is loose - try hand-tightening it. It may cure your problem. Plumbers tape is a white tape that helps seal water pipe joints!
Oct 08, 2009 | Plumbing
Kitchen aid mixer leaking yellow oil is it repairable it still tu
It can be. This may require replaing the plate that the shaft comes through, since there is now enough play to allow the grease that is in the nead to leak through. You can find the parts online, but be ware, it involves tapping out pins and undoing many screws. Manuals are available online at Kitchenaid.com
Jan 24, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel Logo
51 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
