Question about Home
Is there two sizes of pan cone rubber for a toilet. Caroma uniset.
2 Suggested Answers
  • 171 Answers
SOURCE: toilet pan installation procedure
Hi muller2012,
I'm Harvey the Master Plumber.
Your question is: the procedure to join pan to waste pipe without leaking. do i silicone around rubber seal?
In 30 years this is the first time I've heard of a toilet "pan". If you're refering to the bowl, it connects with a wax ring and a pair of bolts. You then caulk around where the bowl meets the floor to keep cleaning liquids from getting under and getting stinky. If this is not a standard toilet it would be a good idea to post pictures and give make and model.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
When toilet is flushed and refills water leaks into the cistern.
Are you saying that water is running into the toilet bowl? If so, check the rubber flapper at the bottom, and the valve (tube standing up).
Mar 29, 2016 | Caroma Home
Where can I buy Caroma outlet seals?
Take the existing part to Lowes or Home Depot and look at there universal
toilet replacement parts. I bet you can find one that will fit.
Jan 04, 2013 | Caroma CARAVELLE270ADAW-EL Caravelle...
Opal 2000 toilet suite, water leaking from around bedding cement. Have marked water level in cistern and bowl with marker and there is no change, water would appear to be coming when toilet is flushed like...
check the donut seal which seals the cistern to the pan, they perish and leak when the toilet is flushed, water runs down back of pan to floor you can check this by drying/wiping with tissue back of pan and flushing you will see if any moisture is running down there by wiping again with tissue and seeing if it is damp.
Sep 04, 2011 | Caroma toilet - water saving Sydney Low...
I have a Caroma Concorde Dual Flush toilet.can't open it - any ideas?
, just lift the cover from the top
if screws are used ti tighten it, get a spanner that suits the size of the screw, and carefully loosen it...
Jan 17, 2011 | Home
Toilet will not Shut off!
the rubber flapper on the bottom of the tank is not seating on the drain and it is allowing water to leak out to the sewer, also check to see if water is too high in the tank and flowing out of the center overflow tube, if so adjust the height of the water level
Aug 19, 2010 | Caroma CARAVELLE270ADAW-EL Caravelle...
How to replace Caroma toitet suite outlet valve
Hello
Rossouw R. im a plumber.
Were the flexi hose go in to the toilet and conect up to velve thread tape. unscrew the flexi hose and then the plastick nut holding the velve on to the sistern.
put the new velve in and bobs ur uncel.
Its very easy, just look were the 2 seal rubbers are when u remove it, may be 1 rubber.
and the flout of the velve will be a cup or ball, thast ajast that tothe right water level, u will c were the flout or ball is on new velve there will be plastick with bumps un it [most commen] if not let me know bt around that area u should find somting to adjust the hight. sorry for spelling errors, im a plumber nt a english major lol
plz let me know if u get in a rut and plz rate my advice, thanx
Jul 10, 2010 | Caroma 270W-RF Reflection Round Front...
Caroma Sydney 305 toilet growls
this is caused by a slight leak in the wax ring causing a gurgle sound, remove it again and reset the wax ring should solve your problem. .
Jan 26, 2010 | Caroma toilet - water saving Sydney Low...
Home Logo
586 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
