Question about Garden
Powerjet waterblaster pump problem
Pump not working but motor going and has water supply
4 Suggested Answers
  • 41 Answers
SOURCE: the water supply to my pump was disconnected while
Yes the impeller is probably shot. If you can find the parts it should be easy enough.
Posted on Aug 02, 2009
  • 700 Answers
SOURCE: motor running, water supply adequate but when
clean whole water supply and outlet from all debris, clean inlet filter as well. connect water and pressurise washer, pull trigger and wait about 3sec for pump to activate, if pump do not activate adn you have pressure from nozzle as it will be from main, this determines pressure sensor (it is extremelly rare for pump itself) is damaged.
check if you have still warranty,this will qualify as warranty repair, if warranty is expired, pressure sensor need to be replaced.
if you find my advice useful, please do not hesitate to leave your remarks and vote for me, thanx!
Posted on Jul 31, 2010
Testimonial: "It worked, thanks."
SOURCE: Type- KEW Hobby waterblaster-
Pump oil is 20 or 30 weight non-detergent motor oil. SAE20 or SAE30.
Pump oil fills about half-way up inside pump. Look for fill mark or read manual.
Of course you saved the manual, right? So you're not in line at fixya wanting a manual for some product made 5 years ago in China by a company that doesn't post manuals. Or manual is available in Italian and German with pages missing.
If this is gasoline-powered engine, do not turn machine upside down to drain oil or 10-W30 engine oil will drain into carburetor.
Posted on Nov 27, 2010
Does the waterblaster have a cut out button and if so where is it?
Modern electric pressure washers all have a presuure cut out (some older ones do not). When you let go of the trigger, the water pressure increases, which pushes a small plunger held by a spring. The plunger operates a switch which cuts the power to the motor. Without knowling the make of your pressure washer, I cannot help with the location of the switch, but I would expect you to find it close to the pump outlet, probaby in the pump casting. A common fault is for the plunger to jam up due to dirt, etc in the water, and the pump wont turn on when you pull the trigger.
Oct 05, 2014 | Garden
Why does Grundfus bell pump dry runs won't turn off?
If you have a switch of some sort to tell the pump the house needs water, look there first.
Aug 29, 2014 | Plumbing
Pool pump not pumping
A few things to look at-
  • Did you fill the pump pot with water?
  • Check to make sure that the pot lid o-ring is in place.
  • Verify that your plumbing is sound and has no suction leak.
  • Check water level in pool.
  • Make sure the voltage is correct. Many pumps come pre-wired for 220v. If you have 110v supplying the motor it will run at half speed. There is a diagram on the side of the motor showing how to convert to 110V. Make sure that your supply is 110v before converting the motor. If you switch the motor to run on 110v and hook it up to 220v it will ruin the motor instantly.
Feb 19, 2013 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Half pumping flow
Check to make sure all fittings are tight and no air is entering the lines, I know sounds like a no brainer.
Jun 21, 2011 | Laguna Hagen Pond Powerjet 900 Gph...
In door water dispenser of ED25QF will not dispense water. New filter, cannot detect kink in supply line, pump does not sound, still making ice, light in door works, dispenses/crushes ice. What is the...
The pump motor on the dispensing water is the problem. Pump motor problem is cause by no voltage power to motor, burnt motor winding, switch faucet on dispensing water, water supply line has jam, check it if you can if not, call a refrigerator service technician to do the job.
I hope I help you with your problem. Thanks!
Jun 11, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Type- KEW Hobby waterblaster- requires addition pump oil. What kind of oil does it take.
Nov 27, 2010 | Garden
I set up a Laguna powerjet pump and a Laguna Pressureflow filter in my pond yesterday. The fountain from the powerjet works fine with good water pressure, but even if I turn the dial on the powerjet to...
Hi and welcome to FixYa I am Kelly. I suspect that the filter is not properly locked into position but.... I highly recommend you countact Laquna Experts. The can handle most 1st time install issues over the phone is just a short time. (Cordless phone recommened)
CANADA ONLY:
Toll Free Number 1-800-55HAGEN (1-800-554-2436) ..........Between 9:00 AM and 5:00 PM Eastern Time.
U.S. ONLY:
Toll Free Number 1-800-724-2436 ....................................................Between 9:00 AM and 4:00 PM Eastern Time.
U.K. ONLY:
Helpline Number 01977 556622 ......................................................Between 9:00 AM and 5:00 PM.
If they can not help you just repsond here and we will give it our best.
Thanks for choosing FixYa,
Kelly
Oct 10, 2010 | Laguna Pressure - Flo Uvc Filter: Pf 2100
WATERMILL SHOWER PUMP - On turning on the shower
This sounds like a problem with the flow switch(es) that control the operation of the pump motor.
When the pressure decreases I assume that the pump has switched itself off - check this before going any further, but I will assume that this is the case. (If the pump is still running when the pressure decreases then you have a really strange problem and I would need to think again).
The pump motor is controlled by flow switches on the outlet side of the pump - when the shower valve is opened the flow of water activates a switch that supplies power to the pump motor. There will be one flow switch on the hot outlet from the pump and another on the cold outlet.
I assume that one or both of the flow switches is not operating correctly. This can be either a fault with the switch(es) or insufficient water pressure on the inlet side. Has anything changed that might have reduced the pressure on the inlet side of the pump? Have you moved the water tank that supplies the pump? (cold water storage tank)
If there is adequate pressure on the inlet then one or both of the flow switches is not working correctly. To further diagnose the problem try turning the shower valve to cold water only and test the operation of the pump, then turn it to hottest and test again.
If the pump operates correctly on cold only or hot only then the associated flow switch is OK, and the other one is faulty.
Replacing a flow switch is not difficult if you are reasonably handy, and I am happy to provide further help if you need it.
Feb 27, 2010 | Kitchen Appliances - Others
No voltage at water pump plug on MK 101 off switchbox.
The Capacitor is only for starting the main motor and not the water pump. Like you said, if you connect the water pump to 110V it will run so there is a problem with how it is wired to the on/off switch. there should be a white wire (neutral) permanently connected to the pump and the on/off switch should supply power on the black wire when turned on.
Apr 05, 2009 | Diamond Products Mk - 101 10" Tile Saw
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
