Question about AMP (219560-5)
Mail me wiring diagram of earthquake power amplifiers,
Commonly use wiring connection of earthquake power amplifier
Thanks jowett
  • 48 Answers
Here is a diagram for an Earthquake PA-2050C shematic
Reference: http://www.diyaudio.com/forums/showthread.php?postid=1756684
mail me wiring diagram of earthquake power amplifi - attachment.php?s=&postid=1756620&stamp=1235581118
Posted on Mar 12, 2009
  • David S
    David S Mar 12, 2009
    The image didi not load, but can be viewed at the internet address listed. It is the second to last post on the page.
Wiring power house phd2 mono amp to the earthquake 4 ohm speakers.
When i hooked up my bass knob the amp made my subs hum i unhook the rca but still humming unhook bass knob still hummin
Jun 12, 2011 | Earthquake Sound PH-D2 Car Audio Amplifier
I have a earthquake 700.1 amp with nothing else hooked up to but the power wire and remote and ground i am getting a red protection light anybody have a answer .
Your power supply is toast. Might be repairable at a electronics repair shop. But for an Earthquake amp I wouldnt waste the money.
Dec 22, 2010 | Earthquake Sound PH-700.1 Car Audio...
Fuse for power cable on earthquake PH D2
I would go with a 40 or 60 amp fuse, this should be ok, you will hardly every run the amp to full capacity so its better to be safe than sorry.
Dec 02, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
I want a circuit diagram of the Earth Quake PHD2
Earthquake does not give out that information . I am an earthquake dealer for st.joe county and dealers are not given access to that information. what do you need it for ?
Jul 08, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
Red light is on when i connect input cable earthquake 1000w amp
Cables are either shorted, or deck is putting out too much power for input on amp... many new head-units will put out up to 7v on the output jacks (RCA) the amp may only want to see up to 1v will need to consult head-unit manual for adjustment of outputs.
Jan 22, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
6 channel power 1000watts earthquake amps red is on
This is normally a grounding problem in the amplifer. If you have a volt meter, check the voltage at the ground of the RCA input on the amplifier. If that voltage is anything more than just a few millivolts then you have a problem in the pre-amp of the amplifier. You should also only connect or disconnect the RCA jacks while the system is off. Otherwise you can get a loud popping noise that can damage the amp or the speakers. Check that voltage on the amplifer RCA jacks with the head unit not connected to the amp with the RCA cables, then if that is OK, check the RCA cables coming from the head unit. You may even have a voltage on those RCA's coming from the head unit, in which case, you have a problem in the head unit. You will be looking for a DC voltage, if you have anything more than just a few millivolts (0.070 +/- DC volts) on either of those then you have found the cause. After that, it will require a technician to be able to troubleshoot the amp or the head unit to determain why you have that DC voltage where it should not be.
Let me know if I can be any more help,
Dave
Jan 22, 2009 | Car Audio & Video
Wiring diagram for earthquake pa-4050 stereo car amp
please help me.....
i need diagram skema for use car amplifier 4 chanel mosfet p-450 planet audio
thank's a'lot before
me...
suryo.agustono@yahoo.com
Oct 30, 2008 | AMP (219560-5)
Bass sounds flat when volume is increased
probably your power is too short, increase your gauge wire, and your ground wire of the amplifier has to be shortly as possible, and the positive has to be enough to support peak power, you can also put a big capacitor on the positive wire to give some more power while the bass peak.
Apr 26, 2008 | Earthquake Sound PH-D2 Car Audio Amplifier
Computers & Internet Logo
313 people viewed this question
Top AMP Computers & Internet Experts
NOEL
NOEL
richie46
Tom Chichester
Are you an AMP Computer and Internet Expert? Answer questions, earn points and help others
