Question about Jensen VM9510 Car DVD Player
Jensen uv8 bypass code didn't work
I had my uv8 hook up by car toys and the bypass code does not work is it because the pink parking brake wire is hook up.
    Scholar:
  • 173 Answers
No the code should work . unless jensen put a stop to the code in the newer modles.
Posted on Mar 24, 2010
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: jensen uv8
They have it installed that way because they have signed a purchase agreement stating they will not bypass. If they do, they can lose the line.
Do this and you will never have to mess with the E Brake or any toggle ever again...:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Posted on Jan 16, 2009
Can't find Jensen UV10 e-brake bypass code.
Ok what you gotta do is connect the pink e-brake wire with the black wire that is already connected to the radio as the grounding.
UV10 Works 100%!!!!
Greetings from Montenegro
Jan 28, 2010 | Jensen Car Audio & Video
How do i bypass the parking brake on my jensen vm8013hd
I just installed the vm8013hd and I simply grounded the pink parking brake wire to the chassis prior to connecting the power to the unit and it works just fine. No bypass box, switch, codes, etc. Good luck
Dec 28, 2009 | Jensen Car Audio & Video
How do i get my phaser linear uv8 to come on.
Check to make sure you are connecting Power (+) to positive (red) and ground (-) negative (black).
Jun 30, 2009 | Jensen VM9510 Car DVD Player
Parking brake on a phase linear uv8
pulll the unit out there will be a wire marked park brake or most likly pink (remeber coming from the head unit ) next splice it in to the black wire or to a ground
Jan 30, 2009 | Jensen VM9411 Car Video Player
Jensen uv8
Jan 16, 2009 | Jensen VM9411 Car Video Player
Jensens UV9 By pass the brake
hook up the ground with the pink and when you are in am/fm mode hit the dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure it beeps after every no. has been pressed. then it should bring up the hidden menu select the hammer option and turn on the brake bypass option. your done.
i took this from the uv8 brake bypass. it works on the uv9.
Nov 12, 2008 | Car Audio & Video
Phase linear uv8 parking brake problem
for the uv8 to bypass the parking brake to watch dvds you have to take the pink wire and put one end to one of the screws on a two screw toggle switch connect the other end of the pink wire to the other screw and connect that to the black ground wire
Mar 12, 2008 | Phase Linear UDV9010 Car DVD Player
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
Trying to find the parking brake
YOU DONT NEED TO HOOK THE PINK WIRE UP JUST PUT IN A DVD AND TYPE IN 543210. THIS IS A BYPASS CODE SO YOU CAN PLAY DVD WITHOUT HOOKING UP THE PINK WIRE. YOU MUST HOLD DOWN THE 0 FOR 4 SECONDS WHEN PUTTING IN THE CODE.
Jan 15, 2008 | Jensen VM9510 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
isn\'t there a way to bypass the parking brake so my video plays anytime i want
Dec 15, 2006 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
253 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
