Question about Sewing Machines
My Empisal Dress Maker 270D has jammed, the needle is not moving and the fabric is stuck, what shuld i do?
The machine has jammed, needle not moving ans the fabric is stuck, what should i do?
SOURCE: Fabric won't advance, bobbin case not turning, feed dogs not moving properly
It's a Singer 5830C -- schooling machine. It's crappy. I'm guessing that a new machine is my best option. For the time being, I'm using my mother-in-law's old metal Nelco.
Posted on Jul 26, 2008
  • 29 Answers
SOURCE: Brother SE-270D Jams below needle plate
Comment by margecam52, posted on Aug 12, 2008 It's the bobbin thread. Also, it does not have to be Brother brand. Any 60wt thread will work. I get mine at http://www.threadart.com
They have it on large cones, and I use a cone holder to fill my bobbins. I have not had a single problem since. I like this thread because it has a sheen to it. I also have a longarm quilting machine & I use this bobbin thread 95% of the time. Also, be sure to check the bobbin area (remove the plastic & the metal plates) for lint buildup... I have a small, soft artists paint brush that I use to remove the lint build up with. I check after every embroidery run.
And for the thread not coming through...mine does it when I change thickness of threads. There is an adjustment wheel on the front of the machine, I turn that...seems to make the difference...not even sure that is what it's for...but it works for me.
Posted on Aug 12, 2008
SOURCE: not sewing - jamming
Could it be that the feed dogs are down? I also have the 15358 and when I opened the bobbin area to clean it, I had this problem. Apparently, when you open the clips around the outside of the casing, it pushes the lever that adjusts the feed dogs to the right (lowering them). I didn't even realize it at first. Check your manual for adjusting this lever to raise the feed dogs. That might solve your problem.
Posted on Feb 15, 2009
  • 152 Answers
SOURCE: Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
Posted on Oct 14, 2009
  • 980 Answers
SOURCE: Need an Empisal sewing machine manual
As far as I remember that machine was made by Janome but you will need the model number
Posted on Mar 07, 2010
Machine stitching does not work what to do on dress maker 270D empisal
Um, we need more information to address your issue. Please tell us what your machine is or is not doing.
Mar 20, 2017 | Sewing Machines
Step by step how to adjust the timing on my empisal dress maker 270D
Search the internet for:
sewing machine timing
There are multiple web sites an videos available.
Jan 03, 2017 | Sewing Machines
I have an empisal dress maker 270D where can I find the oiling points and how do I change the belt
If it is a mechanical machine, you can apply 1-2 drops of good quality sewing machine oil or liquid Tri-Flow Synthetic Lube to any place where metal rubs against metal. AVOID belts, plastic gears, etc. Be sure to also move stitch selector lever and dial mechanisms.
Nov 30, 2016 | Sewing Machines
I'm using Empisal Dressmaker 270D sewing machine. My problem is. When I sew the underneath cotton is loose
Usually, if the thread is bunching or looping under the fabric, the upper tension is too loose.. But if the bobbin thread is showing on the top of the fabric, the upper tension is too tight.
The tension is correct when both the upper and lower threads meet in the middle of the fabric.
Sep 26, 2015 | Sewing Machines
Why does my Empisal sewing machine miss stitches , sew, miss, sew?
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem,, the feeddogs may need to be checked to see why they are not moving the fabric thru the machine.
the
thettttt
the the
Aug 26, 2014 | Sewing Machines
Empisal dressmaker 270d
Loosen your needle. Turn your handle towards you. You may have to turn a little hard. Now, throw that needle away.Take your fabric away and check the area where your bobbin goes and clean it out of fabric and thread. Now load your bobbin again and load a new needle. Pull your thread up from the bottom by turning the handle towards you while holding the needle thread with the foot down. Now look and place something under the foot and slide it forward while still holding the needle thread. The bobbin thread should come up. Let me tell you this though. Adjust the bobbin thread before you start. This is done by placing the thread in the carrier (usually unwinding counterclockwise) and place the thread under the tension spring. Hang this from your finger and bob it up and down lightly. It should fall about one inch. If it doesn't then loosen. If it falls too far then tighten.
Apr 27, 2014 | Sewing Machines
Brother 2003D jammed
i am not familiar with the brother safety device myself. however things i would check might be to first check the manual for the machine. if not available try to turn the machine off if it is electronic in hope that it would reset itself. i would also totally unthread the machine and change the needle. embroidery machines need to have needles changed more often due to their high speeds.What type of fabric were you sewing on? Some of the newer machines are just not made to sew on very heavy fabrics and this might be causing something in side to spring. Try to stitch on a lighter fabric with a stabilizer under it
Apr 30, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
6,205 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
