Question about Microsoft Xbox Console
My original xbox does not read any disc that I put in, Raheem 15
Thank you all for your help in advance
  • Anonymous Feb 02, 2009
    same problem --original xbox does not read any disk, flashing green ring.
  • 25 Answers
Well at this point you have two options, buy a refurb from gamestop,
or take apart your xbox figure out what brand drive you have in it and order a replacement from ebay
i recently had to do this with my heavily modded xbox.....using it as a media center. the console is not hard to take apart it truly is just a pc in a consoles body....lol
http://www.tomshardware.com/reviews/modding-xbox-ultimate-multimedia-center,807.html
heres a little more info on taking it apart
Posted on Feb 17, 2009
My xbox360 arcade didnt read disks anymore so i replaced the disk drive with an older modle but still wont work it keeps telling me i need to put the disc in an xbox360 about to sell the stupid thing for...
Make sure you used the old key from the original dvd drive . 1st remove the new dvd drive . 2nd unscrew the 4 screws on the bottom and remove the board . step 3 do the same 2 steps to the original dvd drive and carefully remove the board and detach any ribbon cables . Do NOT forcefuly pull on the ribbon cables . take the original dvd drive board and put it in the new dvd drive . Put new dvd drive back together and install in your 360 turn on and enjoy . If you need pictures to help Google LLMAMA mods it should come up as inside xbox 360 and theres a page to guide you on how to install a new dvd drive a trouble shooting tips .
Aug 04, 2010 | Microsoft Xbox 360 Console
Xbox 360 Console: I've had problem with my Xbox 360 reading my discs...
Disc drive is out, needs replaced, but inorder to replace it you must keep the original drive. You can either order one online and follow these instructions to do it ureself (recommended) or email xbox360repair@palegathon.com for a pricing for repair.
http://www.llamma.com/xbox360/repair/xbox-360-repair.htm
May 18, 2010 | Microsoft Xbox 360 Console
Xbox is not reading games
rap it up in a towel for 15 mins then let it run it should work fine
Dec 19, 2009 | Microsoft Xbox 360 Console
My 360 dose not read discs but it dose spin them
Disc Error :- I have the same error. You can do 4 things.
A) You have to keep turning it on and off. Here's how... Turn it on, then click open tray then close tray ( keep opening and closing tray about 10 times) then turn the console off. Then keep repeating process for about 15-20 minutes and eventually the game disc will show up. ( I have to do this every time)
B) Make sure that this is covered by Microsof't's RROD warranty. Then some how get teh red rings on this console and send it to Microsoft. (Note: I am not held responsible for your actions.)
C) This is a lens problem. So go out to a store and buy a DVD lens cleanser. It's a disc that cleans the lenses of the DVD or the XBOX.
D) Open it up and replace the lens (like the above guy said) (much harder and more costly).
Pls rate my solution if it did help thanks.
Jul 25, 2009 | Microsoft Xbox 360 Console
Xbox 360 losd disc menu screen comes up says not reading disc
This is almost always caused by a bad or dirty laser. You can pick one up for under $15 on ebay. There are also numbeour tutorials on how to replace them on google.
Mar 25, 2009 | Microsoft Xbox 360 White Console
Doesnt read my discs
This happens to me sometimes as well, but usually it's very infrequent, and happens mostly with old original xbox games.
Basically, the xbox is just temporarily confused. Just eject and reinsert the disc and try again. Usually, the second try always worked for me. If that won't work, simply reboot the xbox with the disc in the drive. Now try to run the game.
Let us know if this works.
Ryan
Dec 31, 2008 | Microsoft Xbox 360 Console
Disc wont read
Hi
Are you using a modded Xbox 360 console?, if not then the disc you are trying to play is probably a copied Xbox 360 disc which would not work on an original Xbox 360
Regards
KreativeGeek
http://gamingbox.wordpress.com
Aug 30, 2008 | Microsoft Xbox 360 Console
How can i fix my broken halo 3 disc over the computer or and on the xbox 360 can you help please the thing i dont get is that i can play xbox online for halo 3 but i cant play campian at all can you help...
First get some disc cleaner, and clean any scratches. If that doesn't work, the only way fix your disc would be to mod your 360, and to use a program called xbox backup creator, to make a backup of your original copy. If you go this route, get a Samsung SH-D162C, or SH-D162A if you have SATA. This is the only dvd-rom that can be altered to read 360 discs, and you might need it if your 360 drive can't read all of the Halo disc. Note: for the obvious reasons you run a high risk of getting booted from xbox live, I got booted and never once played any of my backups online.
Apr 23, 2008 | Microsoft Xbox 360 Console
Xbox 360 not reading DVDs
Here is my advice Clean the disk with a disk cleaner and put it in then when it say's disk cannot read click ok and a backround should come up whether it is blue,purple,orange,etc. a screen will pop up...go to setup and it should say cd,dvd,multimedia click on it and there should be a box and you need to click inside and mark it and select ok
Mar 10, 2008 | Microsoft Xbox 360 Console
Not reading any discs
My xbox is not reading discs. please help.
Jan 13, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
991 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
