Question about Sony KP-53S65 53" Rear Projection Television
Sony KP53S25 Rear Projection has "double vision"
My brother recently gave me his TV . It worked perfectly fine before the ride in the back of a pick up truck to my house. Once home, the picture is fine but there is black above and below the picture and everything seems to have a redddish/blueish tint outline. When subtitles are on it is like double vision. I did the convergence from the set up menu but the colors would not align on one another prefectly. The red and blue always seem to be a bit off.Could something be out of wack from the move? It was somewhat bumpy and the TV was tilted when loaded and unloaded from the truck. I called 3 repairmen one said (without looking) I would probably need to replace my convergence. Another came to the house and said I had 2 shorts in the wiring and the convergence would need to be replaced, he would need to take it into their shop. I do not know who to trust. I called another who said they would need to come out and look, but I already paid $80 for a 5 minute visit. No one seems to know a trustworthy and honest repairman. Anything I can do or do you think it is worth it to make another call? Thanks!!!
  • Gerardo Reyes Jun 27, 2007
    Thanks for your response. I do have a comment to add ( not knowing if this matters or not) When I was watching the tv originally, I was watching a dvd that is why there was black at the top and bottem with red/blue lines. But after hooking up with Direct TV the only problem with the picture is double vision on some parts of the screen(but not all). The direct TV guy said he thinks the projecter itself is just off balance /out of focus. Any thoughts????
  • Gerardo Reyes Jun 29, 2007
    Thanks again, I will follow your advice!
  • 944 Answers
Did you try to do the convergence both automatically and manually? if only one then try the other - just maybe solves your problem without having to replace bits, but I think Premtech is right. If you need help with doing the convergence either way, please ask again. Hope this helps :)
Posted on Jul 02, 2007
  • 934 Answers
Not a problem Gayla, get on the NESDA web site and research a reputable shop from there.. http://www.nesda.com/locator/state_search.php It does sound like the convergence amps (IC's) are the fault. Could be that they have some poor solder connections and the ride in the truck excited the problem. In either event you probably want to have them replaced because if they've been arcing it's likely stressed the IC's close to failure. That unit takes the STK 392-150 but ask them to install the STK392-180 IC's instead. That will give you more reliability and greater tolerance to heat. And one more thing, Sanyo makes the STK line make sure you confirm with the shop to use ONLY Sanyo and not some Japanese knock-offs.
Posted on Jun 27, 2007
SOURCE:
We recently moved the tv and now when we turn it on it has double vision. It kinda looks like a 3d movie. What could be the issue? Is it worth fixing?
If tv picture was fine before moved then check dry/ cold solder joints/ connections on convergence output ICs and nearby circuit area.
Local tv repairman will resolder loose/ dry solder connections to solve double vision picture problem.
TV worth fixing if picture is good.
Thanks.
Feb 18, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
Double vision sony tv
Hello, This is the "kiss of death" for an projection set. It is failure of the convergence electronics. And, it is not something you can do by yourself unless you have technical skills and know how to use a soldering iron at the advanced level.
May 19, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Where is the fuse located on a KP53S25 Sony TV?
hello there should be a glass fuse in the power supply also beware in a lot of sony sets there are soldered in fuses aswell. and circuit protectors i hope it helps
regards
shaun
Feb 05, 2010 | Sony KP-53S25 53" Rear Projection...
Double vision on a sony kp-43t90?
you likly have a convergence problem (is that a crt projection TV?)
Sep 18, 2009 | Sony KP-43T90 43" Rear Projection...
Sony KP53S25 rear projection TV - Horizontal lines on display
try this link
see this link and try to understand the blink codes.
this will surely help you
May 31, 2009 | Philips 60PP9202 60" Rear Projection...
Sony KP-51WS510
Your tv has a convergence board problem. Two convergence IC's need to be replaced.
Jul 22, 2008 | Sony KP-51WS510 51" Rear Projection...
Double vision on my samsung HDTV 1080i
Replace the convergence ICs. you will need two of them. They are located on a large aluminum heat sink with STK numbers. They cost about 10.00 each. They need to be soldered in. Its an easy repair if you can solder. Let me know if you need any additional info.
Sep 16, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
78 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
