ACCO Rexel 250 - S2 Strip Paper Shredder stopped!!
Will run sometimes in reverse but not in forwards, if I try forwards light immediately goes to red. I cleaned/blew/vacuumed dust and paper particles out and if I press the reverse button I sometimes hear a faint low pitch 'Beep' with each press of the button, there also appears to be a noise from the PCB board, might be a relay sound.
  • bill437 Jan 05, 2013
    It appears that the problem is with the Printed Circuit Board (PCB) so I need a replacement either used but working or a new one, does anyone know where I can source one for this model?
JayBlair
  • 328 Answers
SOURCE: Aurora AS1512X Cross Cut Shredder
Sounds like the cutter is jammed. Do you ever feed staples or clips in it? Will it reverse? If not, the power borad is burned out.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Jul 31, 2007
Loringh
  • 185 Answers
SOURCE: Shredder problem
May I respectfully suggest that you do not attempt any repairs on anything that creates a "blue fuzz" of electricity.It is not worth the risk. I am a retired electrical engineer and over the years have developed a healthy respect for faulty electrical devices. Sparks anywhere near paper is a disaster waiting to happen
good luck
Loringh
Posted on Nov 01, 2008
landsend
  • 1066 Answers
SOURCE: _Have a small generic paper shredder with metal
sadly you most likely broke a gear.  Replace it.
Posted on Mar 15, 2009
POCBM
  • 121 Answers
SOURCE: Shredder Beeping
The motor would always turn the cutters.
You likely have a broken chain or a loose gear on a shaft. If you hear the motor running and the cutters are not spinning something in the drive is broken. Likely the chain.
hope this helps.
Posted on Mar 21, 2009
danforddan1
  • 192 Answers
SOURCE: Need forward & reverse plastic key buttons
Spray some contact cleaner into the buttons and this may free them up. try this
Posted on Apr 16, 2009
Rexel RSS1627/RSX1227 Red light always on when
I have an Acco Rexel RSX 1227 shredder. Can you use any oil to oil the shredder or must it be a special oil
Aug 22, 2011 | Office Equipment & Supplies
Rexel 3250 S3 wont stay in continuous mode
Try a hard reset first..Unplug the machine from power source, wait about 10 minutes, and try again..
Jun 07, 2008 | ACCO Brands 3250 S26 Shredder
My embassy schredder won't work although the light is on what should i do? is there some way maybe i can oil it or something because it's not clogged up or anything? what to do?
  • Cross cut shredders require more frequent oiling versus the straight strip shredders. The more paper and use it gets the more oil it requires. A good rule of thumb is to oil the machine each time you change the bag.
  • Use only shredder oil designed for the specific brand of paper shredder you have. Manufacturers design paper shredder oils to be heat tolerant for the cylinders and blades, and they calibrate them specifically for their machines.
  • Spray, squirt or run a bead of oil across the blade opening. It shouldn't take more than a second or two to reach from one end to the other. Any more than that may result in too much oil applied. Quicker than that means there isn't enough oil to adequately lubricate the machine.
  • Turn the paper shredder to "Manual" and run the gears in reverse for a few seconds, then turn the shredder on "Forward" or "Standard" mode. This ensures that you distribute the oil throughout the machine, and going in reverse first forces some of the dripping oil back up, and then the forward moving blades push it back through the gears.
  • Oil a sheet of paper rather than the machine. Don't just run a bead of oil across the bottom of the sheet because the paper soaks up the oil and the oil may not reach all of the necessary parts. Instead, spray the whole sheet, or run a zigzag line across the paper and immediately send it through the shredder tooil it.
  • Dec 31, 2010 | Office Equipment & Supplies
    My shredder overload light comes on immediately with only one sheet of paper inserted and it won't go.
    Try running the machine in reverse and putting some shredder oil onto the cutting blades to loosen things up. Then try running the machine in the forward direction but hold the paper in the eyes but dont let it go into the shredding blades...see if it runs forward.!
    If it will do this then slowly try paper 1 sheet at a time..but put some shredder oil onto the sheets of paper you are shredding.
    If the overload light still comes on without even letting you shred 1 sheet of paper then you likely have another problem...maybe the motor or pcb..you can contact Royal at 1-800-524-0799 for parts assistance.
    Oct 28, 2010 | Royal RS9512C Shredder
    Motor and cutter do not rotate - strip cut model
    Soak the clog with dishwashing detergent and a little bit of water overnight. This should dissolve the paper.
    Jan 07, 2010 | Fellowes Manufacturing C220 (Strip-Cut)...
    Apr 15, 2009 | OfficeMax 0M96431 Shredder
    Shredder says service due. cannot clear display
    Clearing the "Service Due" prompt:
    1. Lift safety flap (plastic cover over paper entrance).
    2. Depress Reverse and Stop button simultaneously 2-4 seconds.
    3. LCD display reads, "Service Info 1"
    4. Press Stop button once to obtain "Service Info 2"
    5. Depress Forward and Reverse buttons simult. 2-4 seconds.
    6. "Service Due" prompt will be cleared and service hours zero.
    7. Snap safety flap down to close.
    Apr 06, 2009 | ACCO Brands Office Equipment & Supplies
    Acco Rexel 4550 Parts Manual Needed
    I can get you the manual but i have to find out how to do it through FixYa.
    Oct 01, 2008 | ACCO Brands Rexel 4550 Shredder
    Rexel rdx1750 shredder jam
    This is the available numbers for ACCO Rexel 0845 658 6600 or 01296 732466/732468 in the UK or you may contact by email mailto:informationeurope@acco.com and this is the web address http://www.acco.co.uk/
    Mar 01, 2008 | Office Equipment & Supplies
    32 people viewed this question
    k24674
    jasbo
    jasbo
