Question about Panasonic Lumix DMC-FX9 Digital Camera
Turn camera on and it zooms all the way in
When I turn camera on it zooms all the way in and I'm unable to do anything as it seems to be locked in the zoom position. I've tried everything.
  • 3 more comments
  • bengordon Feb 27, 2008
    I have exactly the same problem.
    I haven't tried anything exciting yet, I've only just started fishing for clues.
  • kwit May 11, 2008
    My camera also zooms all the way out to an extreme close-up & none of the buttons function (menu, trash, display, etc). Have tried the power-on with various buttons depressed but no luck. Other fixes/ideas appreciated!
  • mmanstett Jul 03, 2008
    Anybody find a solution? I have the same problem. Zooms in all the way and cannot use any of the buttons. Could this be a problem with the batter? Anybody try a new battery?
  • theoanisuni Aug 26, 2008
    I am in the Grand Canyon; just got here with my kids--took one beautiful picture, went to use the zoom and, same thing. i've tried everything. HELP!
  • Dangit1999 May 11, 2010
    Hi, I tried the suggested solution several times and also all other press-one-button-while switching the FX9 on, but the zoom problem remains. I also removed memory card and battery, trying again without result.
    Problem Solver:
  • 6 Answers
Hi, i've an fx8. i had a problem 2 weeks ago. my objective didn't want to close when i switched the camera off. it remained open. when i switched the camera on again, the objetcive has closed and opened again, and remained in this position after switching it off. i tried some button combination, like menu button on, and power the camera on. it didn't work, but the second was the shotting button on, power on combination. an it worked, my camera did some kind of reset. it returned to the original position, and everithing is working since then. so try it.
Posted on Jul 12, 2007
SOURCE:
My panasonic lumix dmcfx60 is constantly trying to zoom and will not allow me to do anything else even though the zoom button itself is not stuck it will not counter act the fact it my camera thinks i
Your electronics appear to have a poltergeist. Check with manual or mfg if there is a reset of unit to factory defaults. If this or a hard reset will not cure the issue then it is time to go shopping since repair is not cost effective unless this was a very, very expensive camera initially.
Sep 06, 2017 | Panasonic Lumix DMCFX60 Digital Camera
My olympus sp-590uz will turn on but is then frozen.
I have had a similar problem. My solution was to check the zoom button. It seems that when it is "out of range" you can do nothing with the camera. Try to adjust the zoom a Little bit and you will probably be "in range" and the camera with work.
Jul 01, 2012 | Olympus SP-590 UZ Digital Camera
When I'm taking a picture, and i try to zoom, it zooms a little then stops, says lens error and goes black. If i turn it back on, it goes on, I just can't zoom.
Most digital cameras jams are the cost of lens problems while zooming, with Nikon Coolpix S4000, simply use your fingers carefully pulling on the lens while turning the camera on. this can be done by getting your fingernail under the lens opening and gently pull.muunlyte5608.jpg
May 10, 2011 | Nikon Coolpix S4000 Digital Camera
I am unable to set the Digital Zoom to On, in my Canon G12. The Digital Zoom Option in the Camera Menu always seems to stay blanked out no matter what I do. Discussions with fellow G12 owners did not...
The digital zoom setting is only available when the aspect ratio is set to 4:3. The setting is accessible by pressing the 'func.set' button in shooting mode.
Mar 17, 2011 | Canon G12 Digital Camera
Describe your Panasonic Lumix DMC-FZ18 Digital
the zoom in the camera is manual, are the lenses moving inside, when you go from 35 to 420 mm?
Have you dropped your camera or has is experienced a shock of some kind? In that case you would need to send it for repairing the lenses, do not attempt to do that on your own.
Oct 18, 2009 | Panasonic Lumix DMC-FZ18 Digital Camera
NO MANUAL OR DISC FOR MY CAMERA
Hello Carrmaher, here is a direct link to your camera's owners manual.
http://sanyoservice.com/pdf/images/VPC-S500.pdf
If you are unable to open it please go to www.adobe.com and download adobe acrobat reader.
Hope this helps you and please don't forget to rate my assistance.
Feb 13, 2009 | Sanyo VPC-S500 Digital Camera
Konica Minolta Z6 camera lens won't retract or zoom out
I have the same problem. The lenses does not retract when turned off or function with the zoom control when turned on. Has anyone found a fix?
Dec 27, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Auto is stuck on and I can't zoom in or out or review pictures - shutter button stuck also
Being very careful, follow this pictorial disassembly (it's in Estonian, but just follow the pictures). Don't go any further than popping the top off the camera! Look for anything obviously broken off near the vicinity of the shutter button, or looking very different than what's in the pictorial. Keep in mind it's amazing what you can do with a little glue and scrap pieces of plastic:
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
Also, pay attention to the following post as there is some potential for electrical shock:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Oct 19, 2007 | Canon PowerShot A95 Digital Camera
Quantaray 28-90 for Nikon N65 zoom ring locked up
There is no secret locking switch. If a little gentle jiggling doesn't free the zoom ring, then I can only suggest you take it in to a reputable camera shop for a Clean-Lubricate-Adjust (CLA).
Sep 03, 2007 | Quantaray 28-90mm f/3.5-5.6 for Pentax
Panasonic Lumix DMC-FX9 Digital Camera Logo
195 people viewed this question
Top Panasonic Cameras Experts
Ekse
skyblue007
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
