Question about Samsung RS2630SH Side by Side Refrigerator
DA99-00258A THE FRIDGE IS NOT COOLING ENOUGH AND THE TEMP INDICATOR ON THE DIGITAL SCREEN IS FLASHING HOW DO I FIX THIS
2 Suggested Answers
  • 3 Answers
SOURCE: RS2545SH. Fridge side is not cooling. Thanks
I have the same problem....anyone have a fix
Posted on Feb 16, 2010
Why is my sub zero fridge model 590 warming up?
Hi fridges will warm up on the outside as they remove heat from the inside. excessive heat with not extreme cooling inside the fridge indicates a possible degridation of coolant fluid or a leak. as the motor tries to cool the fridge the thermostat inside stays on as the tempreture inside has not been reached. if you hear the motor/ pump continually running this will indicate a cooling problem.
May 28, 2014 | Sub-Zero Refrigerators
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
The fridge is too warm (15) but the temp. is set at 4. The temp. indicator sometimes shows 2 but the temp. inside the fridge is still 15
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | Bosch KGU32124 Bottom Freezer Refrigerator
I AM HAVING A PROBLEM WITH MY SAMSUNG FRIDGE FREEZER THE TEMP INDICATOR KEEPS FLASHING AND ITS NOT FREEZING?
Oct 22, 2009 | Samsung Refrigerators
Oct 18, 2009 | Samsung Refrigerators
The fridge and freezer stopped cooling. we defrosted it. There was frost in the freezer. Before that the ice on the door had stopped and now it works too.
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me,the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signaled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week).Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments which opens when the fresh food side needs cooling. If no air is moving in the freezer compartment, temps in the fresh food compartment climb.
I replaced the temp sensor in the fresh food side and solved the problem for a while.
I bought a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
About six months later I had the coil icing problem again. This time the fresh food side seemed cool enough (according to the thermometer as well as the fact that the flapper door would close, indicating that the computer knew to not try to additionally cool the fresh food side).
The thermometer indicated that the temp in the freezer compartment was cold enough, but the system computer continued to run the compressor. So I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a fridge freezer in the garage will not freez cuold it be the anbeant temp too low
no. temp is determined by the temp inside the fridge. if its on and running but not cooling its probably low on gas . if its not cooling enough and off its probably the stat. i doubt the garage gets cold enough to be a factor at all. good luck
Dec 07, 2008 | Refrigerators
Samsung side by side
you can reset the fridge by pushing "Power Freeze" and "Power cool" at the same time
it worked with my fridge Samsung RS21DAMS which stopped after a power cut and was also flashing at the digit of the fridge temp display
Mar 28, 2008 | Refrigerators
The refrigerator side is not cooling.
ALMOST DEFINATELY YOU WILL HAVE AN ELECTRONIC CONTROLLED AUGER(MOTOR)CONTROLLING THE AMOUNT OF CHILL ENTERING THE FRIDGE COMPARTMENT. IF YOU SET THE FRIDGE TO MINIMUM AND LISTEN CAREFULLY, THERE SHOULD BE A SOUND INDICATING THE AUGER IS WORKING.( OPENING AND CLOSING THE FLAP). SET TEMP. TO MAX AND LISTEN. IF NOTHING, IT COULS BE A DEFECTIVE MOTOR OR FAULTY THERMISTOR(TEMP. PROBE).
Aug 08, 2007 | Samsung RS2556 Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
32 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
