Question about Weslo Pursuit R 3.8 Upright Exerise Bike Wlex912080
Tension to tight on bike won't losen
    Top Expert:
  • Weslo Master
  • 12,223 Answers
Step 1:
please follow the instruction and fix it. God bless you.
Pedal Arms
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Step 2:
LUBRICATION
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Wipe away any excess greas
Step 3:
Drive Belt
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use
Posted on Jan 04, 2013
2001 Jeep Grand Cherokee won't shift out of "low gear"
check kick down band adjustment,to tight,or lose,DON'T, over losen, a part inside the transmission will drop out inside transmission causing disasembly to be needed,check linkage first,could also be sticking servo which works the kick down band
Nov 03, 2011 | 1993 Jeep Grand Cherokee
My machine is a Singer Inspiration 4210. My stitch on top looks fine at first glance but it is birdnesting underneath. What should I do to correct this?
Check your top tension. It sounds like it may be too loose or the bobbin tension may be way too tight. Most likely it is the top tension that is incorrect though. The TOP tension effects the bottom side of the stitch and the bottom tension effects the top. If the top tension isn't tight enough it won't draw the thread up through the top side taunt enough and the excess underneath makes a big loopy mess.
Jul 29, 2011 | Singer Inspiration 4210 Mechanical Sewing...
The machine won' tsew as if the tension is too tight any ideas?
try rethreading the machine top thread & bobbin
try a tension of 3 or 4
make sure the thread move smoothly around the tension disks
make sure before threading the needle that the thread pulls smoothly
Nov 17, 2010 | Brother XL-5130 Mechanical Sewing Machine
The front wheel of our instep safari double wobbles like crazy. Took it to a bike repair store and they couldn't fix it.
I had the same problem with front wheel wobble, the fix for me was easy. I removed the four screws holding the foot rest in place and tightened the bolt holding the front wheel on, to tight and the wheel won't turn so leave the foot rest off and try it out until you get the the right amount of tension.
Aug 22, 2010 | InSTEP Safari TT Double AR265 Jogger
The chain popped off and I can't get it to fit back on.
Losen the bar mounting nut, then losen the chain tension adjustment screw until the chain can be reinstalled, then tighten the tension screw until the chain just sags 1/8" or so at the center of the bar then retighten the bar mounting nut.
Sep 10, 2009 | Remington 16" Electric Chain Saw
Changing gears
spray some wd40 into the cable untill you see it dripping out the other end then attatch a pair of vice grips to the tail end and losen the cable nut on the derailer then pull tight with vice grips and tighten cable nut.
Aug 02, 2009 | Mongoose Exile 26 Men's Full-Suspension...
1993 honda accord timing belt tensioner
timing belt tensioner should be spring loaded. its tight up there but you'll have to push the tensioner either up or down and slide the belt over it.
Feb 11, 2009 | 1993 Honda Accord
Weslo Pursuit R 3.8 Upright Exerise Bike Wlex912080 Logo
120 people viewed this question
Top Weslo Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
