Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Wont turn on
It flashes 3 times and every once in a while it will make the startup noise but wont turn on.
    Top Expert:
  • Sony Master
  • 74,243 Answers
The problem is with its main power regulator section itself. Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
This is the fault, and check points. For more details about the blinking codes for Sony TVs, check this.
Posted on Jan 04, 2013
Tv turns on for 10 seconds and then turns off. Then a red flashing blinks 6 times and repeats
Search Results
    Samsung TV On/Off Issue - Repair - Instructables
    www.instructables.com/id/Samsung-TV-OnOff-Issue-Repair/
    InstructablesThe result of this issue is a TV that will cycle between on and off repeatedly and/or an annoying clicking noise while turning on. Time to get informed about the ...
    Easy fix for new Samsung TV switching on and off power ...
    ? 4:41
    https://www.youtube.com/watch?v=H0cG3lzjuw8
    Sep 15, 2012 - Uploaded by alwaysafix
    www.alwaysafix.com Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http ...
    Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
    www.cnet.com > Forums > Samsung
    CNETAbout 3-4 months ago, my TV would start turning off and on a few times at startup but eventually would stay on after a couple of minutes. Every once in a...
    Samsung TV turning off [Solved] - Samsung - Displays - Tom
Jan 19, 2016 | Televison & Video
Why does my SB-700 pre-flash 3 (not once or twice) times before main flash? It didn't used to do this...
You can turn that off
it is used for red eye it will flash to dialate the subjects pupils and wont blink
Sep 13, 2012 | Nikon Speedlight SB-600 TTL Flash
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
My screen come's on but the startup wont come up but my users and stuff like game video images and settings wont appear up (contents page) ie: no video game online acess its just a blank screen with the...
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
How to program new remote to alarm
TRANSMITTER PROGRAMMING Note: System can learn up to 3 different codes max. 1. Turn Ignition ON and OFF 3 times quickly, leaving it ON the 3 rd time. (ON/OFF, ON/OFF, ON) You should hear (1) short chirp. 2. Push the Program/Override Button for 5 seconds until the siren chirps (3) times. Release the button. The system is now in programming mode. 3. Press Button #1 on new transmitter - siren will chirp to confirm programming. Repeat Step 3 within 5 sec. for up to 2 additional transmitters. 4. Turn off Ignition. Note 1: If only one transmitter is being programmed, continue pressing button #1 until dash LED flashes goes out and the system chirps to exit programming mode to prevent unauthorized codes and noise from entering the system. Note 2: Programming mode is exited automatically after 5 seconds of last code transmission or once 3 new codes have been programmed. The LED will flash (4) times indicating program mode exit.
Jan 12, 2011 | 1Way Remote Transmitter
WB 1TB blu light flashes but wont startup
The my book world has 3 different kinds of flashes.
1. Fast flashing (every 3 seconds) - Which means it's going into standby mode.
2. Slow flashing (every 5 seconds) - Which means it's in standby mode.
3. Alternative flashing between inner and outer ring - Means RAID failure (this only applies if you have the RAID compatible version [dual drive my book world])
4. Simultaneous flashing - Means the drive is overheating and the drive needs to be shut down.
Try resetting the drive, using the link below for guidance (this will not effect your data). If the drive does power-up, you will need to change the IP to static, if you had it that way before and you will need to login with the following login details: Username: admin | Password: 123456
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1521&p_created=1172595028&p_sid=UhG4a-Sj&p_accessibility=0&p_redirect=&p_srch=1&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MSwxJnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD0xNTIx&p_li=&p_topview=1
Jan 19, 2010 | Western Digital 500GB My Book World...
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
RCA TV D52W19
Describe noise.. Chirping 3 times? does the led on front flash
Mar 06, 2008 | RCA D52W19 52" Rear Projection Television
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Jan 01, 2008 | Samsung TX-P2670WH 26" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
192 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
