Question about Dewalt DC618KA Angled Nailer Kit
My gun makes a strange noise when fire. - Dewalt DC618KA Angled Nailer Kit
    Champion:
  • 304 Answers
Check the driver blade assy, it might be stuck or bent.
Posted on Jan 04, 2013
I have a IOTA DLS 45 that is making strange sounds. The strange sound is variable and stops altogether at times. Is it the fan that would be making this noise? If not what else could it be?
About the only thing that could make noise is the cooling fan. Does it sound louder when you've just hooked up and started charging the batteries? When you've got a lot of things drawing 12v DC power? Only other noise might be arcing by a short circuit or crackling of a fire!! ;)
Mar 03, 2017 | RVs
With 90 # air and PC nails. When I pull the trigger nothing happens. No air noise, no nailing, no movement - just dead. It's been oiled every use.
Most likely stuck trigger valve. Easy to check. Remove nails, remove trigger to expose the firing pin of trigger valve. Connect air and very quickly depress the firing pin all the way in. If the gun fires , adjust the safety to depress the trigger valve completely. If the gun does not fire, replace firing valve, or remove and check /lube o-rings in valve. Good luck
Jul 11, 2015 | Air Tools & Compressors
I pull the trigger and you get a air sound but no firing of nails . You get air release from top of gun
Could be just a lack of lubrication in the headvalve /orings or the safety foot is not pushing in the trigger pin all the way. Easy to check. Remove the head and pull out the head-valve. Apply plenty of white grease or silicone paste to the orings and the surface where the orings make contact. Install the head and test. If the gun fires then you are done. If the gun does not fire, make sure that the safety foot is depressing the trigger valve all the way in when attempting to nail. Simple test is to remove the trigger exposing the firing pin. With nails removed and air connected, with quick motion depress the firing pin all the way in. If the gun fires make adjustments to safety foot. If the gun still does not fire (with headvalve lubed) replace the firing valve core part # ca0108. Good luck
Mar 05, 2015 | Senco & Frame Pro 601 Framing Nailer
Keeps repeating itself
Most nailers have a two position setting on the trigger to allow for single fire or bump fire. If set on bump fire, the gun will work better when you bump fire the gun instead of placing the gun on the work then depress trigger. Bump fire works best when safety spring has good tension. Easy test. Make sure that the safety spring is in place (with air hose removed, contact foot should spring back quickly when pushed against work). With air connected, hold trigger and quickly bounce the gun against the work. If the gun does not fire when you bump, the trigger is most likely set to single fire. With trigger set to single fire, you must place the gun against the work, then depress trigger. If the gun shoots two nails while set to single fire, most likely worn trigger or worn out trigger valve. These parts are not expensive and are easy to replace. Good luck
Apr 12, 2013 | Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil...
I have a paslode airless framer that wont fire. New batterry & fuel cell. It make the noise but wont fire
Hello harderconstr, I have that nail gun myself, and when it's working good it is a great tool to have.
Here are a few suggestions.
1. Remove the battery, make sure that you don't have a nail jammed in the the firing chamber, that has happened to mine before.
2. Adjust the depth tension on the end of the gun. You should have an alen wrench to loosen the adjuster at the tip. Slide the adjuster away from the gun, ( out ) as far as it will go and then tighten it back down. Reinstall the battery and try it again. You can re-adjust the tension after you see if this helps the problem. The adjuster on my gun was worn and I needed to adjust the tension to get it firing again.
3. I also got a new battery for my gun, and what I found was I really had to slide the battery in pretty hard to get it to click in place. Also, when you hold the gun in your right hand, the thumb side of the handle should have a very small LED light, red means it's not ready to fire, green means it is ready to fire. Make sure you have a green light.
I hope this helps you my friend!
Jan 09, 2011 | RTO Paslode #650027 2500CT Placement Nail
Hi .my im350 nail gun isnt working gas and battery ok and gun is cleaned.light on green .but when depresssed makes strange noise and lights on fire from fan end?
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Oct 24, 2010 | RTO PasLode 900420 Impulse Framing Nailer
My finish nail guns, 16 ga won't fire.
There is a little plastic piece inside above the trigger...usually this breaks. It touches a microswitch when the cylinder is closed all the way, allowing the nail to fire.
Oct 04, 2009 | RTO PasLode 900420 Impulse Framing Nailer
When stapeling it makes a strange ping noise
I talked to hatachi about this.as i had a customer that had the same problem.there tech support said that they have had a few of these do this. it is caused by some **** in side the tube connecting the two tanks when it was welded.they said over time it should stop as wares with time.will not harm anything but is extreamly irritating.The offer no solution. which is bull !!!!!!!!!!!
Dec 18, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Dewalt DC618KA Angled Nailer Kit Logo
60 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
