Question about Peerless Industries Peerless& Single Handle Tub & Shower Faucet
How to rweplace a stem or cartrage on peerless 8700 series single handle shower control
Driping faucit
  • 5 Answers
SOURCE: i just change the whole cartrige, and i'm still
You may also have to replace the "seat" google good luck. that will stop the leak .
Posted on Mar 05, 2010
  • 14512 Answers
SOURCE: Just had a contractor give me an entire new
if u have the paperwork for the unit--in it will explain how to adjust the anti scold settings single handle units are shipped in cold setting u have to adjust the hot -- remove handle and on shaft will see blue and red clips adjust the red till hot water is to ur liking replace handle
Posted on May 18, 2010
  • 1015 Answers
SOURCE: We want to remove the
Look on the bottom side of handle and see if there is a allen head set screw. Loosen screw and you should be able to remove the handle, Thank you.
Posted on Nov 22, 2010
  • 118 Answers
SOURCE: The single handle shower handle
take the handle off and adjust the stop so the handle will go farther and give more hot water
Posted on Jan 19, 2011
al_kupchella
  • 843 Answers
SOURCE: the handle on my shower
If you have enough of a stem left, just file a flat spot on the stem where you want the set screw to stay. You might have to buy a longer set screw though. Take the old one with you and try to find a stainless one - any hardware or home-improvement store will carry them.
Posted on Mar 29, 2011
The handle on my shower faucet is stripped, the hex screw wore a ridge around the stem. Do I have to replace the whole unit?
Mar 29, 2011 | Peerless Industries Peerless& Single...
My showerhead leaks when I fill up the bath tub, do you have any suggestions as what will correct this?
Hi nanbooboo...
Sorry
Your problem shower control valve is ok, but the shower pull that turns on the shower is non-repairable.
Replace your shower controller with a new one if you want to solve this leakage problem.
Please take time to rate me
Mar 18, 2011 | Peerless Industries Peerless& Single...
Shower handle will only go half way to the left. won't go all the way to hot side.
That shower hardware is a temp balanced system and has limits build in to it so people like kids don't burn themselves. The limits can be changed but it is not recommended that you do so. The limit on the hot side should be no more then 110 to 115 degrees. If it is less then it needs to be adjusted and the Peerless people should be able to help.
Jan 30, 2011 | Peerless Industries Peerless& Single...
We want to remove the shower unit. its a single handle unit. how to remove from the front? there is no screw holding the handle.
Nov 22, 2010 | Peerless Industries Peerless& Single...
Just had a contractor give me an entire new bathroom. The Peerless Single Handle Tub And Shower Faucet will only go from 90 deg down on the cold side to straight up. it want go to the hot side. What is the...
May 18, 2010 | Peerless Industries Peerless& Single...
Instruction manuals
http://www.peerless-faucet.com/customersupport/requestliterature.html
Click on the link above and you can request the literature you are requesting. Peerless is made by Delta.
Mar 18, 2009 | Peerless Industries Peerless& Single...
Shower temperature too hot
Shower valves that have anti-scald features are renowned for this problem. Usually it is caused by not being used regularly. It can be repaired usually without replacing the valve, but you will have to dissemble it, clean, and use some plumbers grease to reassemble it. It should work fine after this. If it still does not work you will need to replace the cartridge.
Dec 10, 2008 | Peerless Industries Peerless& Single...
Peerless Industries Peerless& Single Handle Tub & Shower Faucet  Logo
43 people viewed this question
Top Peerless Industries Home Experts
Joe Lamb
Joe Lamb
john h
Steve Wood Plumbing...
Level 1 Expert
Are you a Peerless Industries Home Expert? Answer questions, earn points and help others
