Question about Oster 6232 / 6233 1500 Watts Toaster Oven with Convection Cooking
OSTER TOASTER OVEN --- TIMER TWIST KNOB BROKE
Plastic twist timer knob broke, where can I get a new one ? ----
  • 1 more comment
  • Anonymous Mar 16, 2014
    has bump out in back
  • Anonymous Mar 28, 2014
    It tells me that it is a function knob but does not tell me what those functions are.
    It tells me that it a function knob, but does not tell me what functions the icons represent.
    New Friend:
You can get on amazon for sure. take a look here Thanksgiving essentials from the Oster brand. p.s. take a look on seller reviews. I hope this was helpful. cheers
Posted on Nov 25, 2014
    Welcome Back:
    Visited the website for 2 consecutive days.
I've just called this number 800-798-7395 and talked to a service rep. Since my toaster oven was still under warranty she is sending out all three knobs to replace the timer knob that acutally melted from the heat of the oven at no cost to me! She was very curtious and pleasant.Aparently these knobs should be made fron metal instead of plastic.
Posted on Sep 11, 2012
Need to replace all the knobs on the Euro-Pro Toaster oven model T0160. Please let me know where I can purchase these knobs.
Posted on Jan 20, 2009
The timer knob broke. I would like to get a replacement knob.
Go online and search up your exact model toaster oven and see if you can find a replacement parts website. If you can't, call or e-mail the manufacturer and have them send you a replacement.
May 18, 2011 | KitchenAid KCO1005OB 1400 Watts Toaster...
Oster 6232 toaster oven.
trying to find a solution for a broken knob, i discovered that there aren't many decent options. so i took it upon myself to find one. my father actually recommended that i post the solution, seeing that there were so many with broken knobs. now this works on the timer knob on an oster 6232 toaster oven. it may work on the other knobs and possibly other models, but i cannot confirm that. the plastic stem of the knob that slips over the medal stem of the timer had broken. i crazy glued it back together and knew that there was no way in hell it would hold up with just glue. sorry for the lack of pics on this part. with the broken piece glued back in place, i went to home depot to find something/ anything that would securely slip over the stem of the knob. i tried all sorts of tubing. copper, pvc, steel and found nothing. in the plumbing isle with all the brass fittings and compression fittings, i found an "ander-lign compression nut" 5/8" OD w/ insert. part # A-304 961-P. 634052c.jpg
all you need is the brass flanged insert. if you can find it without the nut and compression ring, then more power to you. after buying this, slip the piece over the knob stem flanged end first. i used 5 minute opoxy to ensure it would stay in place. 7c9f2a3.jpg
i then used a cone shaped diamond bit in my dremel tool to notch out the two sides of the knob. 6be2e7e.jpg
just cut the brass down enough to match the notches in the stem of the knob. 0cdfdf7.jpg
and there you have it. sorry for the 2 blurry pics. hope this can help some of you.
Sep 15, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
My timer knob is broken. How can I order only that part?
I would advise you to call Kitchenaid Customer Service. They would be able to send you a replacement timer knob at no cost. You may simply pull off the broken timer knob, and the new knob will snap in with ease.
Their toll free telephone number is 1800-541-6390.
Jun 16, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
Broken timer knob
I had the same problem where the time knob broke. I filled in a claim form on the Oster Website and they answered within 3 days saying the timer knob was discontinued and no longer available. They proposed to replace the whole toaster-oven with another model 6073-33 which I received last week. I've to say that their customer service was amazing.
May 04, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Kenmore toaster oven timer knob broken
I have the same toaster oven and my timer knob just broke 2 days ago. Go to SearsPartDirect.com website. They have a substitute timer knob.
Mar 18, 2009 | Kenmore KTES8 Toaster Oven with Convection...
The knob on the bottom dial of the toaster oven has cracked and fallen off. Can i get a replacement knob so that I cAn turn the toaster oven on I need all three knobs (temp, function & timer) for my Euro...
You *can* order parts from the manufacturer directly, but good luck with that. The first time I called, and mind you their 1-800 # is a quagmire of numeric menu selections before you ever get to talk to someone, they said they would be happy to send me one but they were out/backordered and that I should call back in 2 weeks. Instead of putting me on some kind of list and sending me one when they got more...Grrr! Then I tried calling back and made it, again, through the menu maze only to find out they are in Eastern time. Super frustrating!
But I also discovered that the flat head screwdriver is the best temporary solution until I can get my hands on a replacement knob!
Dec 06, 2008 | Oster 6071 Toaster Oven with Convection...
Broken Timer knob
Hi Krusin,
Go to
http://prc.prodregister.com/prodprotect/applica/
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/gf.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Sep 10, 2008 | George Foreman GRV660 Toaster Oven with...
Oster Toaster Oven Model # 6192-33
Aug 28, 2008 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Oster 6232 / 6233 1500 Watts Toaster Oven with Convection Cooking Logo
3,135 people viewed this question
Top Oster Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Craig Butler
Craig Butler
Are you an Oster Toaster Oven Expert? Answer questions, earn points and help others
