Question about HEWLETT-PACKARD HP ProBook 4420s Notebook WZ249UT
The shift key on my keyboard does not berfungsikeduanya and I use windows 8, what is the cause.the shift key on my keyboard does not berfungsikeduanya and I use windows 8, what is the cause.
The.spacebar.stopped..working.
If your space bar isn't responding when you press it, or if it responds sluggishly, it's possible that you have inadvertently enabled the "Sticky Keys" or "Filter Keys" accessibility option in Windows.
When these options are enabled, your keyboard response time will be dramatically slowed and may require more than one tap to register a keystroke.
Fortunately, it's easy to disable these functions and return your keyboard to normal working order.
Click "Start" and select "All Programs."
Click "Accessories" and select "Ease of Access."
Click "Ease of Access Center."
Click "Make Keyboard Easier to Use."
Click "Set Up Sticky Keys." Deselect the checkbox that says "Turn on Sticky Keys When Shift is Pressed Five Times." Make sure the box that says "Turn on Sticky Keys" is not checked. Click "OK" to save your changes.
Click "Set Up Filter Keys." Uncheck the box that says "Turn on Filter Keys."
Click on the checkbox next to "Turn On Filter Keys When Right Shift Is Pressed For 8 Seconds" to deselect it. Click "OK" to save your changes.
Click "OK" again to save all of the keyboard accessibility changes you have made.
Hope this helps
Oct 29, 2012 | Gateway LT2021u Netbook
Turning off my green keys on HP pavilion desktop keyboard?
How to turn off Sticky Keys: disable the Ease of Access feature
Tip: use the Windows Ease of Access Center
How to turn off Sticky Keys: what are Sticky Keys and why turn them off?
Sticky Keys is a Windows Ease of Access feature that makes it possible to use keyboard shortcuts or type capital letters without needing to press more than one key at once. Normally, you'd hold down the Shift key while pressing a letter to type a capital, or hold down the Ctrl key while pressing 'S' to save a document. It's even trickier if you want to use a shortcut such as Ctrl-Alt-Del or Ctrl-Shift-Esc.
With Sticky Keys, you can press Ctrl, Shift or Alt, let go and then press another key - Windows will interpret this as pressing two keys together. You should also hear a beep if you have speakers connected.
That's great if you're disabled and can't press two keys at once, but what if you want to disable Sticky Keys?
How to turn off Sticky Keys in Windows 8
You can't press Shift another five times. Instead, you need to bring up the Start menu (or Start screen in Windows 8) by pressing the Windows key. Now type "ease of access" and click on Ease of Access in the list of results.
If you're using Windows 8, you need to click on the Ease of Access Keyboard settings result, and then it's a simple case of sliding the Sticky Keys toggle to 'off'.
If this does not help you. Let us know the below details to understand the issue bettery.
What is the OS?
What do you mean by hot keys? ex.......
Rgds,
Divya
Sep 02, 2012 | HP (395366-001) Keyboard
My laptop is entering more than one character at a time when typing in my password for example its adding additional letters how can i turn this off
seems like something is ring with the keyboard, try an external keyboard, if the issue is still the same this will be a windows issue, once in windows tap on the shift key 5 times this will either deactivate sticky keys or ask you to activate sticky keys.
If it is not a sticky key setting issue then the problem most likely will be Hardware, did any liquid spill on your keyboard previously causing the key to malfunction causing the key to type extra characters?
If none then possible this is a faulty keyboard on the machine.
Sep 10, 2011 | Computers & Internet
Shift key not working
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
May 29, 2010 | HP Compaq nc6000 Notebook
Pressing shift key for @.Getting" instead.
includes what are known as "accessibility options" that are designed to make the computer more usable by people with various physical challenges. (Prior Windows versions include similar functionality but I'll focus on the XP specifics here.) Several of those options relate to the keyboard and are fairly easily enabled. Let's say you're frustrated with your work and start pounding on the shift key (or as was my case alternately pounding on both shift keys). If Windows sees the shift key pressed five times in a row it assumes you're asking for a feature called "Sticky Keys". This feature makes the Shift, Alt, Ctrl and Windows keys toggle instead of needing to be held down. Windows does throw up a confirmation dialog, but that's easy to miss if you're still pounding your keys and happen to hit Return.
"No, Windows isn't getting even with you though it might seem that way." Maybe you're not that violent. Perhaps you're just lost in thought as your finger slowly descends on the Shift key. 8 seconds later Windows thinks you've asked for something called "Filter Keys" which is a way to ignore brief keystrokes or repeated keystrokes. If it's the Num Lock key you've held down for 5 seconds, Windows will ask you about something called "Toggle Keys" which beeps a tone whenever you press Caps Lock, Scroll Lock or Num Lock.
To be fair, Windows does try to ask before turning on one of these features, but if you hit Return by mistake and the feature gets turned on, it can be frustrating to try and continue to get work done if you didn't realize what happened. And that of course can lead to more keyboard pounding.
The good news is that they're easy to turn off and it's also easy to turn off the detection that got you into trouble in the first place. If your keyboard is in one of these strange states, I suggest using the mouse and selecting: Start -> Settings -> Control Panel -> Accessibility Options. The default panel that comes up will in fact be for the keyboard options. There you can turn off whatever happened to have been turned on. While you're there for each of the three options, press Settings, and uncheck Use Shortcut. Now Windows will no longer misinterpret your random keystrokes.
Please give me good feed back i am not getting paid
Oct 10, 2009 | Acer Aspire One AOA150-1570 Notebook PC
My number keys arent working because i was hold shift for more than eight seconds the a message popped up then i clicked ok
Try holding down the shift key again for 8 seconds and read the window to cancel the filter keys.
As for your numbers not working, there is a NumLock [number lock] key on your keyboard. Try hitting that and see if your numbers work.
Hope this helps.
shibumi
Jan 26, 2009 | Targus USB Ultra Mini Keypad Keyboard...
Compaq laptop can't get the ? symbol
Looks like the French keyboard mapping is still in effect.
You can try changing the keyboard keys back to where they were by pressing:
Left CTRl + left Shift at the same time. then try typing the ?/ key. You may have to try this a couple of times to get it to work.
If it does work, try the right ctrl/left shift key.
Also found this:
Control Panel, Regional and Language Options, Keyboards and Languages,
Change Keyboards. Select the keyboard you that's causing you grief and
choose Remove.
If you don't remove the keyboard map, when this switch happens, you'll have
to exit the application you're in (Outlook, for example), change keyboards,
and restart the app. Changing keyboards without restarting the app doesn't
seem to change the mapping.
Hope this helps!
Sep 06, 2008 | Computers & Internet
HEWLETT-PACKARD HP ProBook 4420s Notebook WZ249UT Logo
26 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
