Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
976LM Security plus Wireless keypad
I need to change the battery in the wireless keypad. How does the battery door open? I cant get it open and dont want to break it by prying on it....
  • hsh92 Jan 19, 2009
    I have the same problem, can't open to change the battery.
    thank for your help.
It took a few minutes, but I figured it out. At the bottom of the keypad is a small half round hole. Insert a punch or anything small enough to fit in the hole. Press up, while prying out the bottom of the cover. I have a Liftmaster door with a wireless keypad. If you have the same pad this should work.
Posted on Jan 19, 2009
I had the same problem and just used the the teeny weeny Phillips-head screwdriver for fixing eyeglasses in that tiny hole. Popped off easily!
Posted on Jan 20, 2009
Re: garage door opener . i recently replaced the battery in my craftsman wireless keypad now the code doesnt work and i cant get the door open to press the reset button. how do i fix
Changing the battery wouldn't have caused the keypad to quit. You must have had a problem before the battery change. If you have a vault door. That is one with no other way to enter you will have to call a door technician. They can drill a hole in the door, use a special tool to pull the release and then install a keyed release in the hole they drilled.
Aug 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
My lift master security plus keyless entry pad for the garage door no longer will open the garage door when I key in the four digit code. Can I reprogram the entry pad and if sohow?thank you
You can try programming it but first make sure the battery is good. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in any 4 digit code you like and press enter.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
I need to reprogram my chamberlain security plus keypad model 940CB/67LM. I tried and failed now can't get it to work. Can you please help?
Make sure the battery is good and it is the correct model for your opener.
On the rear of the opener near where all those white wires are you will find the smart/learn button. Press and immediately release this and then walk over to your keypad and key in your 4 digit code and press enter. If this doesn't work you have a bad keypad.
Oct 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Two codes open door
You must hold that red button in for 6 seconds to erase the memory. Just remember you will have to program your hand remotes plus the wireless keypad.
Aug 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do I change my garage code to my chamberlain keypad?
Locate the smart/learn button just to the left of all those white wires. Press and immediately release it and then key into your keypad any 4 digit code you like and press enter.
Jun 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wireless keypad will close door but open
WHEN YOU CHANGE THE BATTERY YOU NEED TO REPROGRAM THE UNIT.
IF THAT DOESN'T WORK YOU PROBABLY HAVE A BAD KEYPAD.
HOPE THIS HELPS
Apr 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage keypad (liftmaster security)
NOT SURE WHICH UNIT YOU HAVE - MOST OF THEM HAVE A SMALL PHILLIPS SCREW NEAR THE FRONT BOTTOM THE BATTERY IS UNDER THAT SMALL COVER.
Mar 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cant get wireless Keypad to Link to new Garage Door Opener
The radio frequency has changed and the old keypad will not work with the new opener.
Mar 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keyless Entry Problem
First try changing the battery in thh keypad 9V. if that dos not work just moving the wire coming from your opener towards your keypad. DONT CUT THE WIRE OR ADD TO IT. That should take care of it
Feb 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can't Get in Garage
no remotes. new battery. why dont you have an emergency release in door. what would you do in case opener breaks or power failure. sorry, cant think of an answer.
Oct 27, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,089 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
