Question about Electrical Supplies
Homelite HG600 Lightnin Bug generator won't work since light rain
Homelite hg600 shut off in light rain. It will now run fine for aout 30 minutes but then it can't keep up current outputs like it used to. What gives? Basically use the unit at full capacity. One evening there was a light rain outside (first time that I've used it in the rain) that was falling on it. The electrical extension that I was using may have had a small cut/short in it...I'm not sure...regardless, shortly after the rain began the generator stopped. On subsequent attempts to use the generator it will start up fine but once its been running for a about 20-30 minutes it begins to run (really low rpms) and the power outage goes way down next to nothing. Just hasn't been the same since the rain. Is there something that might have burned up in it that I need to change?
SOURCE: LCD shutting off automatically
Had the same problem with PB2140, during startup the lamp went off and power and lamp leds turned on. This happened after the projector fell down. I read a post there hat mentioned it was probably the power supply so i disassembled the projector. I found out that a small transistor of the power supply was torn away but it was still inside the projector. I found it, put it back and the projector works just fine. Thanks!
Posted on Oct 29, 2008
SOURCE: 1999 4.0L Jeep Grand Cherokee shuts down after 20-30 minutes.
I'd suggest the ignition control module, however I'd have a certified mechanic check it out just in case...
Posted on Feb 01, 2009
  • 69 Answers
SOURCE: 1986 Yamaha Radian stops running after 20 minutes
Sounds to me like it could be a few things... pretty interesting that it runs and shuts down...sits for a little while then fires back up. Could be something as simple as a bad ground.. maybe it needs cleaned.. if the ground is making very little contact.. the bike would run bad, and because its direct current it has to flow. The metal in the motor frame etc will hold so much DC current.. but *** soon as it load up the bike would stop sparking. Let it sit for a while, DC trickles into the battery through the slight contact, bike fires back up. OR could be bad venting of your fuel tank, or a partial clog at the pet ****.. the first is pretty easy to check, open your fuel cap and start the bike..if it does the same thing then its not a vent problem. One thing that does happen on the Radian, is the reserve fuel screen inside the tank comes loose, and then everything inside the that has built up over the years either partially clogs the pet ****, or the hose, or both. Take the tank off, pull the pet **** off..if it still has two intact tubes with good screens..you probably don't have any junk in your line..but I would pull the line off and blow through it any way... it could be some type of blockage, when the bike sets the fuel seep through, but when it runs it eventually creates a vaccuum that stops the fuel flow. Those are my two first thoughts... good luck!!
Posted on Jun 07, 2009
dmftrucker
  • 1922 Answers
SOURCE: Homelite Lightnin Bug Generator not getting gas
try leaving your choke partially on it may not be getting all the gas it needs,see if it will run then, it wont run full throttle, but this will tell you its not getting enough gas
Posted on Oct 07, 2009
  • 2468 Answers
SOURCE: The unit begins and after a short time the unit stops.
it sound like the unit is very low on r134a refrigerant and in being so the compressor is overheating and the thermocouple sensor on the compressor body is shutting off power to compressor to keep it from burning up
Posted on Jan 17, 2010
How do I drain oil on a Homelite HG600 Generator?
Correct, tip the engine to the side that has the fuel cap/intake or if its on other side tip on that side etc
Whilst tipping slowly pull the starter cable to turn the engine.
Hope that helps
Oct 16, 2016 | Electrical Supplies
Homelite HG600 Lightnin'bug generator. Where can I get an owner's manual?
Homelite Vintage Camping Generator - HG600 Lightnin Bug ...
? 1:23
www.youtube.com/watch?v=Amq5VLOsiN8
May 6, 2014 - Uploaded by david lum
For Sale: Great Generator 500 watts - quiet - looks like new - starts easily. Complete with owners manual.
Sep 25, 2015 | Electrical Supplies
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
Major electrical problem? No previous warning.
We had this same problem after my brother hooked up jumper cables backwards.
We had to replace computer boaord under the driver side dash. I can't for the life of me remember the name of it. lol But someone who can hooked that up and get the codes can tell you if it needs to be replaced. I found mine on ebay....they are Hard to find!
Jul 29, 2012 | 2003 Ford Windstar
Car starts up runs fine, shut it off to go into store, come out and it won't start. leave it for 30 minutes and it will start up fine... help!
You'll have to figure out if it is a fuel or ignition problem.
Is the check engine light on ? Have you checked for trouble codes ?
It could be a relay, the ignition module, coil, fuel pump, or a list of other things.
You should be able to duplicate the problem to get it checked out.
Jul 10, 2012 | 1993 Pontiac Bonneville
Gas lights up for about 5 minutes and then burns out. Try to turn on dryer again, but flame won't light. I let dryer sit for aout 30 minutes and turn on again - flame starts up, but will only last...
If the flame is shutting of before it reaches the operating temperatures the likely failure is a restricted venting system. There is a high limit thermostat that will cause the flame to shut off if there is a lack of airflow due to a restriction in the vent system. Remove the lint filter screen and clean in with soap and water. The filter may appear clean but it could have a clear film of fabric softener residue covering it causing a restriction in the air flow too. After cleaning the filter reinstall it before running the next test.
For testing purposes only, disconnect the dryer vent hose from the back of the dryer and put a normal load of clothes in the dryer and start the dryer. If the clothes dry in the normal amount of time that would confirm a restriction in the vent hose or the venting system. NOTE: Do not leave the vent hose disconnected after running the test. Reconnect the vent hose.
You will likely find the clothes drying in the normal amount of time indicating a restriction in the venting.
Aug 02, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
I have a Honda super quiet 6300i generator. It runs fine and then suddenly will stop. It restarts fine and there are no warning lights of any kind lit on the generator. What could be the cause and how...
Check the oil. Many of these units have a safety switch that will shut off the unit if the oil is low. It doesn't take much on some of these. Or, just add a little oil and give it a try, it certainly won't hurt it.
Jul 09, 2011 | Honda Electrical Supplies
Oct 05, 2009 | Electrical Supplies
Electrical Supplies Logo
85 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
