Question about Yamaha YSP-1 System
YSP: Need remote code for TV Sony Bravia KDL-46W4500
I have a Yamaha YSP-800 and want the remote control to turn my TV on/off and change the volume/input channel.
I have tried the provided codes in the YSP manual: 644, 676, 677, but these do not work with my Sony TV.
TV is Sony Bravia KDL-46W4500
Thanks.
I have the sony KDL 46 EX720 and got the code 2751 to work.
Posted on May 03, 2012
Use codes 263, 214
Posted on Jul 12, 2009
What is the remote control code for Sony Bravia TV KDL-37EX503
Please provide the make and model number of the remote you need the code for.
Mar 03, 2015 | Sony Televison & Video
My sony bravia kdl-46v3000 was giving me three blinks i change the main board now i am getting eight blinks
try this.
Turn on the TV. While holding down V on the remote control, press POWER
on the TV. (The TV will turn itself off, then back on again.) Release V.
WARNING: The Reset will clear all of your customized settings
Sep 27, 2012 | Sony BRAVIA KDL-46V3000 Television
Screw size for attaching stand for Sony Bravia LCD TV model# 46W4500
while the owner manual does not specify the length etc of bolts it does show there are 4 of them---look like find thread machine bolt---may be able to buy a few at the hardware sore or Home Depot---if the threads are inside the base take it with you as a guide.
http://download.sony-asia.com/consumer/IM/4106869131.pdf
pretty stupid as owner manual has everything including dimensions and weight etc but no list of bolts size.
May 20, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Need a remote contol code for sony bravia kdl 37U4000 for skyplus HD remote control
Hello
Remote codes for Sony TV with Sky Plus remote are:
038
533
679
505
533 038 039 064 102 130 505
Ok.
Jul 06, 2011 | Sony BRAVIA KDL-37U4000 37 in. LCD TV
Can not change the channels on my Sony Bravia KDL-46V3000. The remote will turn the TV on and off but will not change the channel.
Is this the original remote or a universal remote? Can you change the channel with the buttons on the right side of the TV?
Can you type in a channel number and go to that channel? (this applies if the channel will not change with the buttons on the TV.) Try to rescan the channels (it could be that the TV has the other channels hidden (or lost the list).
If it is a universal remote, you may not have the correct code (just a close one). Try additional codes for Sony TVs. Also when was the remote built? If it was programmed more than 6 months before the TV was released, then it will not have the correct codes. You would need a newer remote. A substitute remote can be obtained from https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?sessionId=4q4-Cd8shqFs_c5rcVcD_Lw or http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=KDL-V32XBR1&uuid=12842263276080 .
I hope this helps.
Sep 11, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I tried out a few of the numbers that were posted and the "0000" number worked.
Thanks anyway
Jan 03, 2010 | Yamaha YSP-1 System
Remote Codes for new Sony Bravia
you should press 10000, which is the code
Mar 06, 2009 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
Remote code needed (sky+) to sync with Sony bravia kdl32v2000
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Sony Code: 0000
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
YSP-800 - remote code..
so you want to use your remote that you use for your tv with the unit and not the remote that came with it to use with your cabe?
if you are wanting to use the remote that came with the unit here are the following remote codes, or please state the universal remote that you are using the model ect ushally found on the battery cover or inside the battery cover.
here is the origional owners manual for you as well
http://files.hpifdesigns.com/pdf/ysp-800.pdf
I uploaded it to my server for you.
Mar 01, 2008 | Yamaha YSP-800 System
Yamaha YSP-1 System Logo
1,674 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
