Question about LG dlex2501v front load steam electric dryer 7.3 cft factory refurbish
LG DLEX2501 Dryer; making a loud vibrating noise as it spins/drys; 1 year old at the most: - bad rollers? - bearings? - repair manuals? - good links/sites/repair shops? Appreciate any constructive th
LG DLEX2501 Dryer; making a loud vibrating noise as it spins/drys; 1 year old at the most: - bad rollers? - bearings? - repair manuals? - good links/sites/repair shops? Appreciate any constructive thoughts/assistance--Thanks!
  • 3 Answers
SOURCE: dryer won't spin
step 1- remove the face of the dryer, then remove the cover for the fan, check to see if object is blocking the fan, if object is there , remove object, if not go to step 2
step 2- check to see if the belt is broken, if the belt is broken replace the belt.
step 3 - remove the belt from the motor and turn the dryer on, if the motor doesn’t turn then you need to replace the motor.
Posted on Jan 01, 2008
  • 210 Answers
SOURCE: squeaky dryer
Depends how technical you are. More than likely it is the rollers (depending on who made the Kenmore). Go to www.apwagner.com and you can get the parts there. Or if you are unsure about taking it all apart, call for service.
Sgt 48
Posted on Jun 03, 2008
abhishek33
  • 1239 Answers
SOURCE: How do I remove a roller
hi
The front of the dryer's drum is usually supported by two rollers. These wheels are either metal with a rubber rim or pressed nylon. If the rollers squeak but appear to be in good condition, apply a few drops of 20-weight nondetergent motor oil (not all-purpose oil) to them. If the rollers are worn, you can replace them if the roller assembly is not riveted. To replace drum rollers:
Step 1: Remove the front of the cabinet. Rollers are usually held on a metal shaft by a spring clip.
Step 2: Remove the rollers by prying the spring clip off with a screwdriver. Under the clip are a washer, the rollers, and another washer. You might have to remove a small nut at the back of the shaft and remove the shaft itself to reach the rollers. Remove the rollers from the shaft and clean away built-up lint and dirt before installing the new roller. This dirt and lint buildup could cause the drum to turn slowly, which prevents proper drying and strains other dryer components.
Step 3: Install the new rollers on the shaft with the washers in the same position.
Posted on Oct 10, 2008
  • 108 Answers
SOURCE: GE Dryer DPSR483GA2WW too noisy
Remove the rear panel from the unit. This should expose the motor, drive belts, and the drum bearings. Now turn on the unit and your may be able to determine where the noise is coming from. Keep your hands away from moving parts and electrical connections!!
Ray
Posted on Dec 14, 2008
MNTECH
  • 1543 Answers
SOURCE: LG DLE2516W Dryer suddenly making loud vibrating noise
Until you know how serious a problem you have, I'd advise against continued use. If you are in the USA, go to http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
to find a service provider for in warranty service, or call LG USA at 800-243-0000.
Posted on Aug 18, 2009
Maytag dryer makes loud squeeling noise when it gets hot. Drys clothes but makes such a loud squeeling noise. Have to let it cool down to continue to dry.
Hi and welcome to FixYa, I am Kelly.
A loud squeal is usually caused by either an idler pulley bearing. a drum roller bearing or a loose belt.
Since you did not include a model number I have to respond with generic across the board information. Idler pulleys, drum rollers and belts for Maytags can be found on this link:
(Just past half way down the page) http://www.apwapplianceparts.com/Laundry+Appliance+Parts/Dryer+Appliance+Parts+/Dryer+Drive+Belts+Idler+Pulleys+and+Support+Rollers/default.aspx
You can enter your model number on this page and find your parts: (Choose model number)
http://www.appliancepartspros.com
If you do repair it yourself.... do yourself a HUGE favor and either take a picture of the belt routing or draw a belt routing diagram BEFORE dis-assembly.
Thanks for choosing FixYa,
Kelly
Jun 08, 2011 | Maytag Dryers
I have an LG DLE3777W electic dryer that was making a sqeeking noise but is now making a banging and vibrating noise. I think the bearings are gone. I do not have a prts manual so I do not know what to...
drum rollers/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
I don't know how quickly you need the parts, but on eBay they are cheaper:
http://shop.ebay.com/i.html?_nkw=dryer+drum+rollers+&_sacat=0&_odkw=dryer+drum+rollers+and+glides&_osacat=0&_trksid=p3286.c0.m270.l1313
Hope this Helped Tim
Jan 18, 2011 | LG DLE3777 Electric Dryer
LG Model DLEX7177RM makes a rumbling noise upon start up like a bad bearing or gear drive sound. Noise is cyclic at dryer spin speed. Dryer is only a couple years old. Are there any recalls, warranty...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 02, 2011 | LG Dryers
The dryer is making a loud noise. Think its the
the belt that spins the dryers drum around has a belt tensioner located at the botton base of the body. If the roller bearing goes bad the sound you hear is caused by that. Replace the belt as well when replacing the roller or the whole tensioner if needed
Feb 06, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
My GE Harmony Dryer is making a LOUD noise during entire cycle
heatman101
yue
Jan 26, 2010 | GE Profile Harmony DPGT750EC Electric...
My CDE6500 is making a loud tumbling noise while in cycle. It drys fine, but as loud as can be. Can anyone help me ?
There are a couple rollers that the drum turns on that have probably got bad bearings and need to be replaced.
Jul 08, 2009 | Crosley CDE6000 Electric Dryer
Maytag sde3606ayw make loud screeching noise
You Need to replace the drum Rollers. They cost around 10.00 Each online, 20.00 Each at your Dealer. Please Dont try to Put Oil on The Roller Shaft. It will come off and make its Way To Your Clothing. Martin Appliance Sells Specific Oil for the shaft for around 8.00. Thanks Sean
Dec 06, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Loud noise when dryer is running.
My guess is that the belt is going bad. It could also be a bad bearing...the noise is generally metallic. Also...a bad belt tensioner comes to mind.
Dec 20, 2007 | Kenmore Elite HE4 Electric Dryer
Very loud fan or vibration noise
Listen from the back of the TV and locate the source of the noise. There may be fan with a bad bearing. The noise will lead you to it.
Nov 06, 2007 | Soyo Dymond DYLT037A Television
Noisy drier
I had the same problem with my dryer. The large cloths drum rides on two wheel bearing rollers that are mounted behind the drum. If one of those bearings to the rollers wears out, it will make a loud racket. If you want to repair it your self, purchase a repair manual for your model dryer. Then Disessemble the front of the dryer to expose the large drum. Remove the belt that goes around the drum. Then remove the drum. You will then be able to see the two rollers that the drum rides on. Go to your nearest parts store and replace both of them. Good luck.
Oct 02, 2007 | Dryers
LG dlex2501v front load steam electric dryer 7.3 cft factory refurbish Logo
101 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
