Question about Microsoft Xbox 360 Console
I press eject on my xbox 360 and it opens and then closes within
It has no problem reading the disc but its annoying and barely gives me a chance to put a different game in
  • james morgan
    james morgan May 11, 2010
    im guessing this may be a samsung dvd drive inside the 360, try replacing the belt inside the drive which is attached to the main motor. sometimes they can either shrink and be too tight or they can stretch so they are too slack. replace it and try again.
    Problem Solver:
  • 71 Answers
Its definately ur disk drive. u will probably need to replace it.
Posted on Jan 30, 2009
My Xbox likes to eject my game mid game and sometimes it will open and close when i want to start a game.
Yes this is the disc reading error and it happens because of overheating on the back of the drive and you will need to get this fixed. You can send it in and they will fix it for you although this can take about 4 weeks and also the other thing that you have to think of is the repair cost will be about $150.
The other way that you can fix it is to use a good Xbox 360 Repair guide to fix the problem.
Feb 24, 2011 | Microsoft Xbox 360 Console
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
My xbox disc tray is not ejecting
If you lay your console flat press eject, then give the console a few raps (dont go mad) with your knuckles where the centre of the disk should be the draw will open.
let us know if this solution helps.
Jan 12, 2010 | Microsoft Xbox 360 Console
My xbox 360 cdrom won't keep
turn on your 360 and open the game drive. hold it open and turn of the 360. wait for it to power down completly. then turn the consel back on and it should close on its own now and stay closed as it should
Jan 07, 2010 | Video Game Consoles & Games
Disc tray won't close
Whenever you need help with your Xbox or Xbox 360 accessories, allways check out Xbox Customer Support
The answer to your question is quite long, so here's a link.
Xbox 360 disc tray help
Hope this helps
May 20, 2009 | Microsoft Xbox 360 Console
Starting
xbox 360?
you open the disc tray by pressing the eject button directly above the tray, insert the disc and then close the disc in the same manner. if the game does not automatically start up then you will be required to go to the row that says My Xbox and the very first tab should say the game you have entered. you play it by pressing A
Jan 27, 2009 | Microsoft Xbox 360 Console
Xbox 360
you need to send it off to get repaired
Aug 26, 2008 | Microsoft Xbox 360 Console
Xbox open/close disaster
u have the dvd rom damage y u dont try to change it
Aug 14, 2008 | Microsoft Xbox 360 Console
Disc Tray wont stay shut
A lot of people have this problem. Before you post, look around.
Anyway, I was able to call xbox 360 customer support. We did the troubleshooting but it still would not work, so they took my xbox 360 in for repairs. I would not try to fix it on your own because it might negate the warranty.
Xbox Support: 1-800-4MY-XBOX
Jun 22, 2008 | Microsoft Xbox 360 Console
Xbox 360
tap on right above the drive if a tap doesn't work just hit a little harder mine does it every now and then it will pop open
Aug 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
14 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
