Question about Haynes VW Jetta, Rabbit, GTI and Golf Repair Manual covering New Jetta 2005, Jetta 2006-2011, GLI 2006-2009, Rabbit 2006-2009, GTI with 2.0L engine 2006, GTI 2007-2011, and Golf 2010-2011. Does not include 2005 Jetta based on the A4 platform or 2006 1.8L GT
Door won't unlock on Jetta 2010
  • barignall
    barignall Jan 04, 2013
    And when I need a smart arise we all know who to contact. Thanks for the great advice! NOT!
    Problem Solver:
  • 10 Answers
Call a lock smith
Posted on Jan 04, 2013
Alarm won't turn off
the valet key doesnt have a transponder chip in it, so it will allow physical turning of keyways and operations, but will not disable the alarm and often wont disable the immobilizer.
sorry to say i think you will need to get an autolocksmith , or main dealer to get you a functioning key with transponder chip mapped to your cars rfid system that will allow alarm to be enabled /disabled
Mar 23, 2017 | 2000 Volkswagen Jetta TDI
Mazda 3 2010 driver's door locked and won't open
This is what fixed the my car's driver's door that was stuck closed and locked: the plastic piece that function as the manual lock/unlock on the inside of the door (it's black but when the door's unlocked it has a red side facing out) had essentially popped out and everything was jammed. So you push the button back in while you flip the inside handle open. But maybe I was lucky, in that it was only the button that was jammed.
Feb 03, 2013 | 2010 Mazda 3 1.6
My 2010 Cadillac SRX trunk won't open with the doors unlock from inside the car, from the remote and from the touch pad button under the license plate. Please someone let me know if they know the
sounds like a fuse is bad for that circuit..check and replace if bad..in an emergency to gain acess to the trunk, remove the back seat by taking the base out first then the back of it..remove the noisebarrier(fiberboard or batting) and the trunk is accessible by a smaller person who can trip the lock from inside manually..good luck and reposr please..
Jan 17, 2013 | 2010 Cadillac SRX
Replaced door lock fuse on 03 Suburban, doors still won't unlock.
You need to replace the Unlock Relay, it should be in the fuse panel on the passanger side.
Dec 03, 2012 | 2003 Chevrolet Suburban
2010 Jetta My daughter had a cd in and loaded another one. It is a single cd player. I don't know how it took it? It won't eject. How do I get them out??
If possible remove the unit from the dash, remove the top plate and push the cd out. If not I have removed stuck cd's with small flat nosed needle nose pliers.
Nov 01, 2012 | Volkswagen Cars & Trucks
97 jetta doors won't lock
I assume the doors can be manually locked. The problem is in the electrical circuit. That means anything from a faulty switch (the lock / Unlock button) to a loose connection. If both switches don't work then look for a blown fuse. If one switch works and the other doesn't than remove the switch and inspect its connection. If it's ok then check the switch. If both switch and connections are OK then you'll have to remove the door panel and access the lock mechanism.
Dec 11, 2011 | 1997 Volkswagen Jetta
CTS 2010, RKE system does not work for the driver door. The key is in my purse, my purse on my shoulder and the driver's door only refuses to open even if I hear the doors unlocking. It's driving...
if you are hearing clicking noise but the door won't open then the door lock actuator is not releasing the lock. not uncommon problem ,but the car is still new. most of the time this type of problem starts after 5or6 years. I hope your car is still under warranty.
Aug 12, 2011 | 2010 Cadillac CTS
1994 jetta want trun over
lock and unlock drivers door you may have a bad door latch and is telling the alarm to go off and prevents startup
Jul 21, 2009 | 1994 Volkswagen Jetta
Haynes VW Jetta, Rabbit, GTI and Golf Repair Manual covering New Jetta 2005, Jetta 2006-2011, GLI 2006-2009, Rabbit 2006-2009, GTI with 2.0L engine 2006, GTI 2007-2011, and Golf 2010-2011. Does not include 2005 Jetta based on the A4 platform or 2006 1.8L GT Logo
348 people viewed this question
Top Haynes Heating & Cooling Experts
Mike
Lawrence Oravetz
SimplyNo
Are you a Haynes Heating and Cooling Expert? Answer questions, earn points and help others
