Question about 1995-1997 Chevy Suburban Ignition Starter Alarm switch
When u put it n gear it will roll a few feet and clunk and wobble at about 5mph
When looking under as it moves where driveshaft connects at rearend it moves up about 4 inches when u put it n reverse
    Scholar:
  • 117 Answers
You either have a bad u joint or the ring and pinion bearing is bad. If the play is in the driveshaft it is the u-joint. If the yoke on the rear axle moves up and down, then it is the pinion brngs or the bolt has come loose holding it on
Posted on Nov 02, 2013
My 1992 wrangler won't roll at all. It starts fine, and stays running but when I try to put it in gear it stalls out. Even in neutral, I can't seem to push it to get it rolling. Any suggestions?
This sounds bad, even in neutral it stalls, you cant even push it. i would start by putting the transfer case selector in neutral and see if it rolls, if this jeep is only two wheel drive then start by jack the front wheels up and do this for the four wheel drive also, this is to see if its in the trany or the wheel, check and see if you can spin the wheels in the front, if this is two wd then if the wheels dont spin then you have a problem with the brakes but what concerns me is that it stalls in neutral, i would have to say the problem is in the trany and if this is a stick shift trany i would say the clutch broke and will not release but when its in neutral it should roll. anyway do the same in the rear wheels, jack them up and see if the wheels move, if they dont then remove the driveshaft at the rearend and then see if the wheels move. if the wheels turn with shaft off then theres a problem with the trany oor transfer case if its 4wd, if its 2wheel drive then its something in the trany, if the wheels dont spin with shaft off then start truck and see if it still stalls but dont let it go into gear with driveshaft off you will not be able to stop driveshaft when disconnected, just see if it stalls in neutral. good luck.
Mar 13, 2011 | 1992 Jeep Wrangler
Rear end has wobble and vibration, there is a clunking sound when i put it in gear
Check your driveshaft joints for excessive play. If it's bad enough to clunk into gear, usually if you have someone watch from the side underneath you can see the one that is worn when you go from drive to reverse. (do not lay in the path of the wheels when doing that ) Another way of checking is with both rear wheels safely supported (on flat ground) and the trans in neutral to unload the driveline...then try to move the driveshaft by hand. When replacing the bad joint, check the opposite end as well for any binding or play.
Dec 02, 2010 | 1995 Jeep Grand Cherokee
Clunking sound when beginning to move forward on my 1999 ford ranger
Check your driveshaft U-Joints. Also sometimes the calipers will shift back into position after you start moving.
Check under the seats and in the bed for rolling bottles or a loose jack.
Jun 12, 2010 | 1999 Ford Ranger SuperCab
Driving alongfreeway abiut 100 klms hour all going fine 1 moment then out of the blue there was nothing, no gears, just reving like in netural. no noise was heard either
If this is an Automatic it would be the Torque converter. If you have someone to look under the car when you put it in gear, see if the drivehaft is turning. If the driveshaft is turning and the differential is not, you blew the rearend. If the driveshaft is not turning it is the Torque converter.
If this is a stickshift it would be unusual to detroy the clutch without some noise.
Mar 27, 2010 | 1966 Ford Mustang
Clunking when decelerating,vibration at all speeds.
Check your driveshaft first, sounds like U-joints. Next I would look at motor mounts.
You can try to move the U-joint from under the truck. If you do not want to jack the truck yourself, go to a shop. Sometimes Muffler shops will work on driveshafts. There should be no slack and sometimes there is a rust trail at the bad joint.
The motor mount can be checked with help. Open the hood, brakes on and put the engine in gear and see if the engine raises up. Put it in reverse with the brakes on and see if the other motor mount lets the engine raise up.
Jan 26, 2010 | 1990 Ford Ranger SuperCab
1998 Silverado 1500 Rear End Howl/Leak/Clunk/Vibration Pinion
A pinion seal leaks for one or boyh of these reasons. A worn pinion bearing or a driveshaft vibration, Sounds as though you have both. Do not confuse tire howl with gear howl, be sure.The rear end can run 3 to 500.00 if not more. Ck the gear oil in the rearend for metal content. That will tell you alot. The hard shifting is generally from a sticky spool in the trans valve body. Have the trans serviced w/new oil and filter. The new oil often cleans the moving parts of gum and varnish buildup.in the valve body. One more thing, the rear ends take a special oil and additive if it's a limited slip or posi lock. You will have a popping/binding noise when turning if the wrong lube is install. Have your driveshaft aligned and balanced at at driveshaft shop.or you will end up tearing up the tailshaft on the trans. Good Luck
Jul 07, 2009 | Chevrolet Silverado 1500 Cars & Trucks
1999 f150 2wd transmission clunk
ujoints I would check out first mainly the rear one. if it wobbles in the sockets its worn
May 24, 2009 | 1999 Ford F150 Regular Cab
Rear end noise
You cannot check universal joints with the driveshaft under tension. Trans needs to be in neutral (wheels blocked or on jackstands)
If diff is noisy, check gears by removing cover and checking lube for metal debris, gears for "sharpening" on edges. Generally it is cheaper to replace unit with one from a scrapyard. Any work regarding bearings or gears requires precise depth and lash adjustment or the unit will quickly fail again.
Universal joint failure will cause a "clunk" when engaging reverse or drive and also can cause vibration similar to out of balance tires. Worst case is a rhythmic squeak while going about 10-20mph.
May 10, 2009 | 1999 Chevrolet Astro
1995-1997 Chevy Suburban Ignition Starter Alarm switch Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
