Error code FH
Washing machine takes water into the drum and then sounds alarm and displays error code FH. I have looked on other sites and found that the problem may be the pressure sensor but find that on a rinse spin cycle the alarm does not sound,on all other programmes that involve water the error code is displayed. I have cleaned the filters and checked all obvious things such as hoses and siphon etc.
Please help as i have 6 children and the washing is becoming a mountain.
  • neilandbeck Jan 19, 2009
    I am sorry for not giving all the info on my original posting. the model is an AWM1001-F whirlpool 6th sense front loader. i dont have a date of manufacture but the machine was bought from new in May 2007.
    The only other number i can find on the machine and i am not sure how relevent this is but 857007529800 and ETK334.
  • Stephen Christy May 11, 2010
    I have seven children myself. But when it comes to electric sensors there is more work to be done. Please givem a model number and year of the machine
Push the off button once to pause it and then push the start button again.  I have the same problem and this is what I do.  Works every time.
Posted on Mar 02, 2009
    Problem Solver:
  • 20 Answers
I cant do anymore without the machine in front of me
GE Answer Center®
1-800-626-2005
Monday - Friday: 8 a.m. - 10 p.m. ET
Saturday: 8 a.m. - 7 p.m. ET
Closed Sunday.
GE Warranty Management
1-800-626-2224
Monday - Friday: 8 a.m. - 8 p.m. ET
Saturday: 8 a.m. - 4 p.m. ET
Posted on Jan 19, 2009
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
FH SIGNAL MEANS ......... WHAT IS THE USE OF FH SIGNAL........ AND APPLICATIONS
The error code FH means no water is detected entering the machine which can be due to a faulty flow meter not registering the correct amount of water that has passed through it or the pressure is not tripping from the empty position to the full position when the correct water level has been reached. Your machine is definitely made by Whirlpool like other Kenmore and Maytag washing machine so they are basically the same and troubleshooting is then the same. The link below contains the detailed troubleshooting of this error code for a Whirlpool Duet and should be applicable to your machine.
Error Code FH on Whirlpool-made Front-Load Washers
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
Hi Expert, I have the 9200 Whilpool Duet washer that is now stuck in the rinse cycle and is 1/2 full of water. I tried to drain it by lowering the hose into a pail but no luck. I get the FH code. I have...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Aug 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Keep getting FH code. Have cleaned inlets and checked hoses. Water is coming in,sounds right but then goes to FH again.
Hi
Daniel
Aug 06, 2011 | KitchenAid KHWS01PMT Front Load Washer
We have a Duet Washing machine. It keeps sounding the alarm and then the letter F will show up followed by the letter H..do you have any idea what these warnings mean...it just stops working and keeps...
Hi
Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hose, it may be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Feb 11, 2011 | Washing Machines
Get Fh alarm water is going in washer just fine. What are most likely causes? Model GHW9400PL0.
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing machine whirlpool awm8123/1 stopped and FH on display
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR If the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. Press PAUSE/CANCEL twice to clear the display.
check the fill hose screens or you my have to repalce water valve make sure water is turned on....
Sep 19, 2009 | Whirlpool AWM8123 Front Load Washer
Kenmore Elite quietpak9 HE4T washer FH error code
take the lid off attached to the inlet valve to the dispenserr you will see a little white mechanisim in line with them. this is called your flowmeter take it off and blow through it is should sound like a cazoo. put it back on and try to do a wash cycle. if this doesn't help you need a new flowmeter. also if you take the kick panel off you will find the tech sheet to help you diagnose this problem.
Jun 23, 2009 | Kenmore Elite 45986 Front Load Washer
FH error
You are correct..
FH is an indication the the machine is not sensing enough water flowing into the machine....
The only thing you can do without taking the machine apart is to disconnect the water hoses to the back of your machine and inspect the filter screens for any type of debris that might be restricting water flow into the machine. Typically, the cold water line is more susceptible to foreign matter than the hot waterline.
If screens appear OK then the problem may be with the water fill valve, water flow sensor, (flowmeter) water pressure switch or blockage in the water pressure switch hose.
However.. if everything is fine using just cold, verify hot water for proper pressure or possible kinks in the hose.
Jun 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
407 people viewed this question
Top Washing Machines Experts
