Question about Linksys Wireless-G WRT54G Router
I already set up the router to the computer and the modem, the problem is I cannot connect it to the internet. the lights are all working in the modem and on the router. How will I fix it?
  • 826 Answers
First check the modem ,connect modem cable direct your system ,if modem is ok then you have problem with your router.Try to reset your router.
normally connection problem depends on your physical connection setup your router...
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Posted on Jan 04, 2013
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Posted on Aug 05, 2007
SOURCE: setting up linksys wireless router with motorola 2210 dsl modem
One thing that isn't mentioned anywhere is the modem has to be in bridge mode. I was told this by a Linksys tech after doing all that was documented in the references article. I contacted my internet provider and they told me how to set the modem to bridge mode. This corrected the PPPoE error.
Posted on Jun 09, 2008
SOURCE: Connecting my westell 6100 modem to my router
linkseys Wireless G broadband router need to hook up to Verizon router/modem
Posted on Jun 22, 2008
kakee
  • 1268 Answers
SOURCE: Router not seeing internet connection
If you are on cable internet, you need to perform MAC Address Cloning. Access the router's setup page using your main PC, under SETUP tab, there's a sub-tab called MAC Address Clone. Enable that and click on "Clone My PC's MAC" then click on Save Settings. Power cycle the router and the modem. You should be online after that.
Posted on Jun 09, 2009
My router is connected, but there is no internet connection.
Actually, Linksys WRT160N is meant to be used as a router not an access point. It can be but with at
Jul 26, 2011 | Linksys WRT160N Wireless Router
It has stopped connecting to the Internet. The cable modem and computer are fine, but the cable modem and the linksys no longer "talk" to each other. Other wireless connections in my vicinity work OK on...
Base from the description of your problem it seems that we need to reconfigure the router to work with your modem again and we need to do that manually using a computer connected wired to the router.
To do that follow these steps.
Connect the modem to the router and computer to router also, make sure all connections are correct.
Then power on the router , modem and computer and check all the lights on the router are fine and make sure power is solid green if those are fine access the router setup page.
From the computer that is wired to the router a\open internet explorer and type 192.168.1.1 and hit enter then that should ask for a username and password, just leave the user name blank and password is admin hit enter you should be now on the router page.
From there under SETUP tab look for a sub tab MAC ADDRESS CLONE , then enable that and clcik on clone pc mac and ten save settings and once its save power off the router and modem for 1 minute then after that power on the modem and then the router and check if internet is already working.
Oct 11, 2010 | Linksys Wireless-G WRT54G Router
Wireless is nonexistant
You need to bridge mode your modem. And when set it to bridge mode already. Connect the dlink router. Access the gui of the router. Enter there your username and password. Powercycle modem, router and computer. Check connections. I f this didnt work, set again your modem to default, connect your router. Configure your router with username and password. Powercycle again. Check if it is working.
Jul 16, 2010 | D-Link DI-524 4 Port Wireless-G Router -...
How do i configure my cable modem to a linksys router
On this hub this will give you a step by step instruction on how to manually setup or install a Linksys router for Cable internet.
This guide is recommended for Cable Internet Service in the USA like Charter, Cox, Comcast, Cable Vision, etc.
  1. First you need to connect the device together. You need to connect your cable modem to the internet port on the back of the router, and the computer should go to one of the 4-port on the router labeled Ethernet (1, 2, 3, 4).
  2. Then turn on the modem first, wait for the lights to stabilize before powering on the Linksys router. Lights that you should have on the router are Power (solid green), Wireless/WLAN (Green sometimes flashing), One of the no. lights where the computer is plugged in (flashing), And the internet light (flashing).
After doing this step there are times that this will already get you online. If the internet will not work, you continue following the steps 3.
3. If the internet is still not working; we will need to adjust a setting on the router setup page. To access the setup page of the router you need to open your internet explorer or Firefox on the computer that is hardwired directly to the router. In the address bar of your browser (Internet Explorer or Firefox) type http://192.168.1.1/ and hit enter or click Go. It will ask you for a username and password. Just type "admin" for the password field and there is no username. If you have ran the setup CD prior to this, then use the password that you have set when were running the setup CD.
4. Once you are in the setup page of your router make sure that the Internet Connection Type is set to Automatic Configuration DHCP, then click the save the settings button at the bottom of the page. After saving the settings, click the sub tab at the very top of the page that says MAC Address Clone. Set it to enable and click the button that will say Clone or Clone your PC's MAC and save the settings again.
5. After doing step 4, do a power cycle. Power cycle is done by turning of the router, modem and computer. Leave them off for a minute, tuned them back on in this order. Modem first wait for the lights to stabilize, then the router wait until the power light become solid. Then turn on the computer. This will get you online through the router.
I hope this one helps. Don't forget to share or rate this.
Thanks for reading and dropping by.
Step by Step Guide to setup cable modem to a linksys router With Graphic/ pictures
Click here
Please rate my solution
Apr 02, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
Internet light on wireless modem is red and wont connect to internet. DSL, Wireless and Ethernet port 4 are all connected with green lights. Wont properly connect the modem.
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 04, 2009 | NetGear DG834G Router
I am using linksys router but its internet light not on. i have configure fully the router but still the status showing is down..& not UP
Check the cable connection between the modem and the router.
You said that the Internet light is not on on the modem or on the router.
If you connect the computer directly to the modem does it work ?
If yes then connect the computer and the modem to the router and open the router set up page.
Set up the router manually.
Click Here for more info about router set up
Nov 30, 2009 | Linksys WRT300N Wireless Router
Modem is not working
the fact that the computer and modem are not in contact with each other, means that we really don't know that the modem is not connected to the internet. i'll assume you've tried all lan ports on the modem.
did you attempt a connection with another computer? another modem?
Mar 31, 2009 | NetGear DG824M Wireless ADSL Modem Gateway...
Router Question
hello!
-- what is the brand of your modem? have you tried connecting your computer directly to the modem and check if you can get online? If yes, Internet connection is fine and the problem is on the router if not, call your ISP first and check your connectivity with them.
-- have you tried connecting your computer directly to the router without connecting the modem to the router and check if you can access the router setup page? there are some cases where in the modem and the router have same IP address that's why you cant access the setup page of the router because of IP Conflict. Try to access the router page , router not connected to the modem only on the computer and change the LAN IP address of the router to 192.168.2.1. Connect the modem to the router and try again to shut down everything and power on the devices one by one and check if you can get online.
-- if after changing the LAN IP address still doesnt work, try to check if you can access the router page by the new IP Address. Make sure that you do not have other firewall or any security enabled on the pc. If yes, try to enable the MAC Address clone on the router and check again the internet connection. Try to configure the router with a diff computer also help isolate the problem
-- if after that and it still not working last option is to upgrade the firmware of the router. possible that there is a problem with the router and upgrading the firmware normally fix internal problem. If that still doesnt work, the router is defective.
Aug 29, 2008 | Linksys Wireless-N WRT150N Router
Need help in connecting to the internet using Dlink 704p router.....
it doesn't matter whether the other computer is set to static and the other one is set to dynamic as long as both computers are getting/using valid ip addresses.
if i got it right. 1 computer is connected to the LAN port of the router and the other computer is connected to the WAN port. if so, you need to connect both computer to the LAN ports and the WAN port of the router should be connected to the modem that you are using.
if the physical connection is correct, check how you are connecting to the internet through the modem. if you can access the internet from the modem without configuring anything, you just need to power cycle. turn off everything then turn on the modem first, wait for the lights on the modem to turn on properly before turning on the router then turn on the computers.
hope this'll help you but if not, just provide the following:
(1)ISP:
(2)brand/model of the modem:
so i can help you further.
Jun 04, 2008 | D-Link DI-704P Router
Linksys Wireless-G WRT54G Router Logo
91 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
