Question about HP LaserJet 4250n Printer
Need to clear all printing jobs from the printer 4250 HP
We are a school and a child printed several thousand copies of a picture.  The job already spooled and cannot be cancelled from the computer end.  The cancel job function does not work from the printer. How can we manually clear the print jobs from the printer?
  • Anonymous Mar 24, 2014
    I have paused the printer and hit cancel print job. It won't. I have shut down my entire computer and printer.
  • Anonymous Mar 28, 2014
    send print job to printer always says printer is spooling
    Novelist:
  • 159 Answers
It's probably queued up on the computer you're using. If this is Windows or Mac, look for a printer icon toward the bottom-right corner of your screen.
If you don't have it and you're on Windows, click Start: Control Panels: Printers. Find your printer.
Inside the new screen, you should be able to first pause the printer, then cancel all the jobs. You may have to highlight all of them, then right-click to get cancel.
When they're all cleared out, go back to where you paused the printer, then hit Resume printing.
Posted on Jan 19, 2009
How to clear error code 49.4c18 on HP laserjet 4250
any 49.xxxx codes are related to firmware crash.
the probable cause is a corrupt file in the print queue. remove the printer from the network then after network is disconnected - cycle the power on the machine ( switch off then wait 10 seconds switch back on)
the 49 error will probably clear . if so Clear All print jobs in Print queue on the computerr workstation. then reconnect printer and away you go!
if however the error remains then you will need to Upgrade the firmware or replace the firmare chip/formatter ( unlikely I've only ever replaced one out of thousands of calls for this fault)
Nov 04, 2012 | HP LaserJet 4250n Printer
How can i print multiple copies of the same document with 3 pages and have the printer staple the copies in the correct groups?
In the print driver you should have the option to collate, you need to make sure that that option is on, and when you go to send the print job, you need to make sure that you adjust the finishing options in the driver to tell it to staple.
May 11, 2011 | HP LaserJet 4250 Printer
Hp 4250(on a network) is hung up on processing job. I restarted the print spool and physically restarted the printer put the problem still exists.what should i do
you may need to turn off your print services on your pc. pull up the printer que on the pc. delete the jobs in the que. right click my computer. go to mange. go to services and applications .go 2 services. double left click. look for print spooler. right click. choose stop. then go to printer and reset job. turn off printer. turn on printer. restart your print spooler. close all windows and try to print
Jan 07, 2011 | HP LaserJet 4250n Printer
Error during print 'Remove all paper from bin'
HP Laserjet 4250 Network connected laserjet printer.
Steps to be follwed to set right :
01. Please check in number of desktops or laptops it connected.
02. Give proper IP Address in the Desktop or Laptop where it has to be orignally installed.
03. Being a network printer, lot of desktop or laptop users might have printing job iniated.
04. Right click the printer properties which is available bottom right hand corner ikon and delete or cacel all printing jobs.
05. The original desktop or laptop where the IP Address created will be rebooted. System should be restarted.
06. Try to print now to close this solution.
07. Still the problem persits, kindy contact local HP Authorised printer service engineer to set right this issue.
Have a nice working day.
Jul 17, 2009 | HP 4250 Monochrome LaserJet Printer
Print Job enter's queue, but doesn't actually print.
hi thanks for using fixya!
Do you have 32bit or 64bit system?
Mar 24, 2009 | HP LaserJet 4250n Printer
Hello my name is Karen, and our school has bought a canon pro9000 from you. We use the printer in our digital photography class and someone has sent several copies of one picture to the printer and I am...
Try to delete the print jobs again and if it will not clear or clear the previous jobs, click on start then on run, the type in services.msc
on the open box then enter on the services local window look for print spooler, right clcik on it then click on stop, right click back and click on start. reboot the computer and try prionting again
pls dnt 4get to rate solution if helpful thanks
Apr 17, 2008 | Office Equipment & Supplies
Cancel already sent job
turn off the printer, and disconnect from computer..turn it back on, and clear all jobs from front panel controls
Mar 20, 2008 | Brother HL-2040 Laser Printer
Printing the same picture all the time?whats wrong
go to priner and faxs in control panel double click "hpdeskjet" driver icon, window should open with pending jobs, you can delete them before they get to printer, if jobs are at printer then power off and on of printer will clear its memory of jobs requested
maybe too one of your pictures is bigger than the paper so your printer is trying to finish very big job. either way powering off printer and deleteing jobs in driver then power on printer will enable next job to be sent
Oct 29, 2007 | HP DeskJet F380 All-In-One Printer
HP LaserJet 4250n Printer Logo
1,659 people viewed this question
Ben Johnson
