Question about Sony Grand WEGA KDP-57WS550 57" Rear Projection HDTV-Ready Television
Where is the location of 2SC5778 on sony d-board
K770i sim ic location in board
i want to know sonyericson sim ic location in board.pls show me now
Apr 05, 2012 | Sony Ericsson Cell Phones
Hello, I have a problem with my sony rear projection tv. When I try to turn it on the standby lights blink but it odes not turn on. I turned it on using display 5 vol- power and it did turn on and know it...
You need to count the number of blinks between the pause. Most common is 9 blinks. Also- after you press POWER, do you hear a "click" or not? If no click and 9 blinks, you probably have a "zero cross failure" and have two options:
(1) Replace the "G" board (part # A1054157A) or have it repaired (they repair it on eBay for about $40. You ship them the bad board and they either repair and return or ship you a different repaired board) A new board costs about $80- without having to send them your board.
(2) Repair the board yourself- by replacing the two diodes on the "G" Board - (D6301 which is on top- by the small transformer) and (D116 which is an SMT component on the bottom of the board- it takes VERY steady hands and a good solder iron). The parts should cost less than $25 and are available on eBay by searching for "sony a1054157a".
Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-2.jpg Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-5.jpg Component D6301 location (Sony KDP-51WS55)
problem-4ojfzua2t5qdonett1db0kz0-5-9.jpg Component D6116 location (Sony KDP-51WS55)
Sep 11, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
Where is the g board and how to i know witch one
Go to encompassparts.com. They are good about listing parts. Use guest login. Sony boards have the letters stamped on them. Just look for the one with "G" board. Some of the sony put a diagram on the inside to show where they are located.
Oct 14, 2009 | Sony KP-51WS510 51" Rear Projection...
Where is the convergence chip located
Convergence out ICsare located on D Board of Sony KP-46WT510
These are 2 big ICs of black color mounted on silver heat sink.
Check out location of D board in TV in below exploded view...
Aug 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
SONY KDP51WS550 NEEDS ITS D-BOARD REPAIRED OR REPLACED
Below is an exploded view shows all boards location in KDF-51WS550
Hope this will help you to identify required D board.
Mar 04, 2009 | Sony Grand WEGA KDP-51WS550 51" Rear...
Location of the convergence circuit board on KP46WT510
they are located on the board on the left when looking in the rear of the set ( Brown Board) you can get the convergence repair kit at the follwing link which has the ICs , the six pico fuses and four of the feed resistors, plus it comes with instructions, Here's the link.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits
Jan 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kp 51hw40 real projection tv
Below is exploded view of your Sony KP-51HW40 TV rear side which shows board names and location.
You need to check D Board for convergence ICs and these are marked as IC8001 & IC8002 on circuit board.
Nov 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-57WS500
The flyback transformer is defective when the LED flashes 8 times. The FBT is located on the main board(D board).
Location of the part is T8005 and the Sony part number is 1-453-285-41
This part is available from this website.
This type of repair might not be a DIY due to the danger of working with devices that generate high voltages.
Sep 03, 2008 | Sony KP-57WS500 57" Rear Projection...
Locate Convergence IC's
They are located on The D board (on the right) mounted to two huge heat sinks. you can get replacement ICs here.
Apr 18, 2008 | Sony KP-46WT500 46" Rear Projection...
Double images--3d view--ghost picture Sony KP-53HS30
The convergence amps are the big STK's*** located possibly on the G-board in the sony. It is very difficult if you are not familiar with components and soldering, You can buy them at MCMelectronics, bluestar-online.com, Tritronics, VanceBaldwin.com, etc. Diagrams are online at fixya.com on the rightside of screen. Places like Manual.com or you can search the web. Hope this helps!
Sep 24, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony Grand WEGA KDP-57WS550 57" Rear Projection HDTV-Ready Television Logo
37 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
