Question about Casio TE-2000 Cash Register
Hello, TAX-AMT is not printingon receipt after changing tax rate.
After changing the tax rate to 8% per instructions in manual and assigning tax calculation to dept key 12, the TAX-AMT 1 is not printing on the receipt. T1 is printing next to dept on receipt. I do not understand why TAX-AMT 1 is not printing . When listing departments T1 is printed next to dept. Any advice would be appreciated. Thanks, Monica
  • Casio Expert
  • 592 Answers
Go back to system options and print options and select PRINT TAXABLE or TAX AMOUNT
Posted on Mar 18, 2014
Casio pcr 308 cash register
Per the instructions on the Casio4Business Support website, you can do the following:
PCR 308, 350, 355, 408, 450
TO PROGRAM STATUS OF DEPARTMENT KEYS:
1. TURN KEY TO Z MODE
2. PRESS SUBTOTAL
3. PRESS 02 FOR TAX TABLE 1, 04 FOR TAX TABLE 2, 06 FOR BOTH TAX TABLES, AND 00 FOR NO TAX
4. PRESS DEPARTMENT KEY
5. REPEAT STEPS 3 & 4 FOR MULTIPLE DEPTS.
6. PRESS SUBTOTAL
You can access additional information at the main support site: http://www.casio4business.com/sa/support/taxtable_programming.html
Regards!
Dec 17, 2013 | Casio Parts Cash Register PC Desktop
Tax Rate Button
That is the correct program it seems your program is corrupt, just wipe out everything and start afresh
May 11, 2013 | Casio PCR-T2000 Cash Register
How do I change sales tax
Casio TE2200: Key To PGM, Press 3 then Subtotal, 0125 Subtotal ( this sets tax table 1, 0225 will set table 2 etc), 6.725 CA/Amt Tend (insert your rate here), 0 CA/Amt Tend, 5002 CA/Amt Tend (this sets to Fraction Round Off and Add On Tax), Subtotal
Nov 06, 2011 | Casio Parts Cash Register PC Desktop
Remove Casio PCR-T2000 Tax Table 2
Hi. You are working in the wrong area. You need to tell each department not to add TAX2. Go to the department programming, and there should be a setting that says use tax1, use tax 2 etc. Turn off tax2 for any depts that you don't want it added and it will no longer print or calculate tax 2 for that department.
For anyone looking for a Casio PCR-T2000 manual, see here:
http://the-checkout-tech.com/manuals/cashregisters/Casio2.php
Feb 06, 2010 | Casio Parts Cash Register PC Desktop
Tax change
To change the tax rate on your cash register, do the following:
  • Turn key to PGM
  • Press 3
  • Press SUBTOTAL key
  • Enter new tax rate ex: 7% is 7, 7.5% is 7.5
  • Press CA/AMT TEND key
  • Return key to normal position
If this procedure doesn't work or you need to program more than one table, kindly post back. Best of luck.
Greg
Jul 14, 2009 | Casio Parts Cash Register PC Desktop
Programming sales tax
You're right, the manual is terrible but I think I got it worked out...
Turn to PGM mode.
  • Press 3 then subtotal button.
  • Press subtotal button again.
  • Then endter tax rate (if even enter two digits 05 for 5%, if more enter 4 digits like 5.75 *5+.+7+5 for 5.75%) and press ca/amt tend button
  • Press 0 and press ca/amt tend button
  • Press 0125 and press ca/amt tend button *this is for rounding/tax table code not positive on this one but looks like the right entry for "add on" tax
  • Press sub total button
This should change your tax
Apr 07, 2009 | Casio TK 6000L Cash Register
How to change tax rate?
1) switch to PGM mode
2) press 3 then sub total key
3) press 0125 for tax table 1 or 0225 for tax table 2 followed by the sub total key
4) enter tax rate percentage using the decimal point and then press CA/Amt Tend
5) press 5002 and then CA/Amt Tend (to round off results)
6) press sub total key
Apr 01, 2009 | Casio Parts Cash Register PC Desktop
Receipt
Absent any specific model information, I suggest you refer to the manual to see if there is a "calculate but don't print option". I doubt it seriously however, since the receipt would make no sense to the customer. It may be possible to trick the register by telling it to print those lines in a color that is not available on the print ribbon, but still the customer would be confused if they tried to manually total the bill..
Nov 21, 2008 | Casio Parts Cash Register PC Desktop
SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
May 01, 2008 | Sharp EL-330AB Calculator
Casio tk1300
I'm in Australia and only going on the program manual for your area, it states that canadian tax is tax on tax? if this is true then you probably entered a code for add on or add in tax and thereby changed it all.
you need the following
tax table address
1 125
2 225
3 325
4 425
rounding off codes
rounding off to 2 decimal places is 50
rounding up to 2 decimal places is 90
cut off to 2 decimal places is 00
tax system code
tax table with out tax rate 01
tax table with tax rate and add on rate 02
add in tax rate 03
Canadian tax-on-tax rate 04
starting point
to get the starting point you multiply by 100 and subtract 1
eg 50 cents = 0.50 X 100 - 1 = 50 - 1 = 49
eg $4 = 4.00 x 100 -1 = 399
to program the tables go through these steps
go to program 3
tax table address eg 125
subtotal
tax rate
ca/amt tend
starting point eg 0.50 = 49
ca/amt tend
rounding eg 50
tax system eg 04
ca/amt tend
ca/amt tend
here you have 2 choices,
press ca/amt tend to go to the next tax table ie 225 and start over by entering the tax rate and go through the procedure again
or
press subtotal to finalise the tax table you are on
Hope this helps,
Adam
Apr 18, 2008 | Casio Parts Cash Register PC Desktop
Casio TE-2000 Cash Register Logo
204 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
