Question about X-Rite XRite ColorMunki Photo Color Management Solution
Colormunki installation after installing the software form the CD or the Xrite web site, when I restart the computer I get the error message: "cannot run because icuuc46.dll is missing"
F380 printer will not SCAN - keeps giving error message
Do you have original CD with you? if not down load the full feature drivers from hp web site. Un install the drivers, re-install once again..verify your driver CD supports the OS what you are using?..
Feb 03, 2012 | HP DeskJet F380 All-In-One Printer
Conexant realtek ac'97 audio ( code 10 )
Please check system configuration. Use Mother board Driver's CD provided alongwith system. If so, in CD trace out audio driver i.e., realtek and install.
Feb 25, 2011 | Computers & Internet
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    I have purchase AOc V22+ LCD monitor last week. I have installed all softwre drom CD. But Web camera software is not installed properly. Tray Icon for web camara is not created. When I start the program an...
    Unplug Web Camera. Remove its software. restart your system. Install the software. Restart the system. Now attached the camera, it will work properly INSHALLAH. THANKS FOR ASKING QUESTION.
    Sep 23, 2010 | Computers & Internet
    Printer comes up with - error message: does not recognize cartrige
    reinstall your printer driver software. you can download the latest printer driver software form your printer manufacturer's web site then restart the computer
    Jun 11, 2010 | Canon PIXMA MP780 All-In-One InkJet...
    Windows installer error
    DID YOU GET THE RESTORE CD WITH THE HP SYSTEM IF YES THEN PUT THE CD IN START YOUR COMPUTER CHOOSE BOOT FROM DVD AND THATS IT IT WILL RESTORE IT OR ELSE U TRY PRESS FUNCTION 8 LIKE F8 AND CHOOSE LAST KNOWN GOOD CONFIGURATION. IF DOSENT HELP U HAVE TO GET THE GENUINE wINDOWS DVD AND INSTALL YOUR WINDOWS AGAIN
    Mar 03, 2010 | HP Pavilion A6400f Desktop PC, Refurbished
    No network adapter after restarting computer
    Go to the computer manufacturers web site and put in the product number for your computer, then when you have the info on your computer up, you should see a link for support or software and drivers, when you are on the drivers page, look for networking drivers and download.
    Apr 04, 2009 | Dell 430-0008 Network Adapter
    Error 2738 when attempting to install HP F4180 printer software
    Hi Stargateforg,
    Try the solution from HP.
    Solution one: Restart the computer
    1. Turn off the product.
    2. Restart the computer.
    3. Turn on the product.
    4. Use the HP software CD or the downloaded software file to install the HP Software.
    Solution two: Register VBSCRIPT.DLL
    1. Search for the VBSCRIPT.DLL file on the computer. It is usually located in the C:\Windows\System32 folder.
    2. Click the Start icon (c01319360.gif ) , click All Programs , and then click Accessories .
    3. Right-click Command Prompt , then click Run as Administrator .
    4. In the command prompt, type CD C:\WINDOWS\SYSTEM32 . If the VBSCRIPT.DLL file is located in a different folder, use the appropriate folder location.
    5. Press the Enter key.
    6. Click Continue in the window that appears on the computer.
    7. Type REGSVR32 VBSCRIPT.DLL in the command prompt and press Enter . A message appears on the computer indicating that VBSCRIPT has been installed successfully.
    8. Use the HP software CD or the downloaded software file to install the HP Software.
    Solution three: Download and install the latest version of the software
    1. Click here to go to the software download page on the HP Web site.
    2. Type the product model name in the text box and click the gray arrow button.
    3. Select the appropriate product model from the list that appears on the computer, then select the appropriate operating system from the list that appears on the computer.
    4. Under the Drivers section, click Full Feature Software and Drivers .
    5. Follow the on-screen instructions to download and install the HP software.
    Solution four: Custom Install Use Custom Install to install the basic print drivers only.
    1. Use the HP software CD or the downloaded software file to start installing the HP Software.
    2. When prompted, click Custom Install .
    3. Clear all the entries in the list of software to install except Photosmart Officejet and Deskjet Drivers and Imaging Device Functions . Click Next to continue.
    4. Follow the on-screen instructions to install the basic print drivers.
    Dec 22, 2008 | HP Office Equipment & Supplies
    Error in Installation CD of HP2015dn
    There may very well be a glitch in the HP installation CD. Go to their web site, HP.com. On the home page, left hand side - middle of the page, you will see a link for software and driver downloads. Click on that and then fill in the blanks on the type of printer you have. It should take you to a page that shows all software available for your printer - including the latest drivers. Once you find the driver(s), you can either download the file(s) to your computer and then do the installation - or just run the installation program from HP's web site (probably the easiest way to do it).
    If that does not solve the problem, contact HP Customer Care via email or live on-line chat.
    Hope this helps - Ghost
    Oct 27, 2008 | HP LaserJet P2015dn Printer
    X-Rite XRite ColorMunki Photo Color Management Solution Logo
    123 people viewed this question
    Top X-Rite Computers & Internet Experts
    David Payne
    David Payne
    Are you a X-Rite Computer and Internet Expert? Answer questions, earn points and help others
