Question about Makita 9.6 Volt Cordless Drill/Driver Kit
Old makita model 6012HD cordless dill
How do I get the chuck off
rowdy45176
  • 2176 Answers
SOURCE: chuck change
After removing the screw and inserting the allen wrench shift the drill to the LOW position and turn the clutch to the drill only position. Use an allen wrench about the size of the chuck capacity so that it will not flex when hitting it with a mallet. Sometimes they are stubborn because of the torque but this should work. Put the allen wrench at about a 30deg angle and hit the wrench. I support the chuck on a workbench or a block of wood will do fine. The chuck has standard threads.
Posted on Dec 20, 2008
rowdy45176
  • 2176 Answers
SOURCE: chuck removal
First open the chuck jaws and remove the LH chuck retaining screw. After that find a bent handle allen wrench about the size of the chuck. Put the shorter end in the chuck and clamp down on it. Put chuck on a block of wood or workbench with the long end at about a 30 degree angle so you can hit it counterclockwise with a hammer. It might take a couple hits but it will come off.
Posted on Jan 08, 2009
co7196
  • 3433 Answers
SOURCE: my chuck is broke , on my 18v makita cordless
Put the chuck key on and strike it with a hammer counter clockwise. the chuck key must be properly seated in the hole. Once the chuck is brokrn free, you can unscrew it my hand. Buy a new chuck an screw it in olace and againm strike the key but no as hard clockwise. It will self tighten more as it is used, Good Luck-Ned-
Posted on Sep 17, 2009
radar001
  • 1051 Answers
SOURCE: removing chuck from Makita 64C1 drill
secure the short end of an allen wrench in the chuck, making sure it is as tight as possoble. Useing a wood or hard rubber mallet strick the long end of the allen wrench so it turns counter-clockwise. This should loosen the chuck from the spindle enough that you can unscrew it by hand.
Posted on Feb 19, 2010
SOURCE: Broken Makita Drill 6408k chuck
If the chuck itself slips, you can tear down the outer layers (yes it is a bit brutal)
of the chuck until you reach the inner metal core. You can then try several things;
1 loosen it with a pipe wrench, provided you can get a grip on the axle of the chuck to counter the torque
2 Weld an allen key to the metal core of the chuck and use a firm rapid blow by a hammer to rotate it counterclockwise
3 Dismantle the final shaft with the chuck core, and set it in a vise with aluminium plates to protect it, while you turn the chuck with a wrench or pliers.
4.If there is no senter lock screw inside the bottom of the chuck it may be fitted with a thread locking compound. It will loosen easilier if heated with a heat gun or moderate gas heat.Only supply just enough heat to loosen it, or the hardening of the steel may be compromised.
Posted on Dec 02, 2010
Replace chuck on Makita cordless drill
The BTD 140 only has a sleve, spring, washer, clip and 2 balls. If you need to replace the bit holder then it is part of the shaft (324432-0) that comes from inside the gearbox.Cover unscrews from the body.
Dec 13, 2012 | Makita 18V LXT Lithium - Ion Cordless...
How to re move chuck
Hi!there is a screw when you open the chuck of your drill,there you can unscrew the chuck so that you can replace it.But there are some dill that are not with the screw.You will need some special tool to remove the chuck.
Sep 09, 2011 | Makita Garden
Hi i broke the chuck on my 1/2 makita cordless
Put the biggest hex key you have in the chuck and tighten it then hit it clockwise with the spindle lock engaged a couple of times. The screw in the chuck will then undo clockwise and the chuck can be undone after by putting the allen key back in and unscrewing it anti-clockwise maybe with a light tap from a mallet.
Hope this helps
Jon
Jul 01, 2010 | Makita 6349DWDE 18-Volt Ni-MH 1/2-Inch...
I have a 12v makita drill and cannot remove the chuck i have removed the screw inside the chuck. lease help
The chucks on most drills are left hand thread. To be sure which way to turn the chuck check the screw the chuck will turn in the opposite direction.
Mar 29, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
How to remove chuck on makita bdf452
the chuck should open all the way then look down the old one attached to the drill there should be a screw near the end undo the screw and then it should come off :)
Mar 23, 2010 | Makita BDF452HW Factory Reconditioned 18V...
Changing a drill chuck
If this is a cordless drill open chuck jaws and remove the retaining screw (LH trheads), switch the clutch to drill only and shift gear selector to low. Insert a bent handle allen wrench about the same size as chuck (to keep from flexing) put chuck on workbench or block of wood and have the wrench about 30 degrees and strike the key counterclockwise to remove. You might have to hit a couple times but usually they will loosen up quickly. To install just reverse above. Let me know if I can help further.
Dave
Dec 25, 2008 | Makita Drills
Makita manual
too cool I have the same drill I think broken trigger on mine but managed to find this for you
its the parts diagram with everything
http://www.ereplacementparts.com/makita-6012hd-cordless-drill-parts-c-97_106_107_264.html
hope that helps. I will have to check if I still have my old manual and if I do I will post it up for you.
Aug 01, 2008 | Makita Electrical Supplies
Makita 6405 3/8
according to my breakdown its a drill. do you checked if there is a screw inside the chuck. if there is one remove it by turning clockwise.open the chuck fully & insert allen key 5/16 or 3/8 short side to the chuck.tighten the chuck & wak the allen key with a hammer counter clockwise. do it again if required.putting back together the other way.
Jun 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Chuck won't tighten
The chuck is held onto the drive shaft via screw located inside the chuck. The screw has reverse threads and sometimes the screw gets loose restrictinhg the chuck tightening. Turn the chuck to loosen and tighten the screw as though you were removing a normal screw. Good luck
Feb 19, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 9.6 Volt Cordless Drill/Driver Kit Logo
44 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
