Question about Clarion XMD3
Clarion Xmd3 I have had no problems owning the clarion Xmd3 for 4 years. When I was testing all my boat electronics I noticed my stereo was dead. Just by chance I blew the horn and the stereo came on? Bad connection was my first guess. I have check all connection points hot & ground and they are all solid. All wiring harnesses are tight and leave little room for bouncing around when the boat is moving. I have also tested all my fuses and they are in working order. After working and tracing the wiring to all connection points the stereo turned back on but for only a few seconds before turning off again. My gut tells me my problem is in the wiring but I'm at a loss. Any help would be great!
  • michael_1616 May 14, 2009
    I already have an I pod hooked up to the aux and it works great! Now I would like to run my tv on the boat through the stereo as well. Can I do this and how. The tv has a coax audio arrangement. What's up with the cnet mentioned in the xmd3 manual? Does that carry audio?
  • 48 Answers
Bottom line is that boats are a hrsh environment for electronics. Moisture, salt, and vibration all conspire to undo solder joints and electrical connections. 4 years is a pretty good life span on a boat. A solder connection within the unit could have let go. A good repair shop could probably fis the bad connection but you can probably replace the unit for less.
Posted on Jun 29, 2007
SOURCE:
I have a Clarion XMD3 am/fm marine cd player that came with my 2000 Searay boat. I was somehow able to turn the inside cabin speakers off last season and only have the outside speakers on. I must have...
Might be set on mute !
Mute instructions
Use this function to turn off the sound immediately.
1. Press the [ M ] button.
The sound turns off and "MUTE" appears in the display.
2. Press the [ M ] button again to cancel the mute mode
in this other user manual it is a mute button[m] page 4
http://www.clarion.com/us/en/MungoBlobs/552/388/XMD3.pdf
or
Adjusting the fader
1. Press the [ A-M ] button and select "FAD 0".
2. Press the [ w ] button emphasizes the sound from the front
speaker, press the [ z ] button emphasizes the sound from the
rear speaker.
? The factory default setting is "FAD 0". (Adjustment range: F12 to
R12)
3. When the adjustment is complete, press the [ A-M ] button
several times until the function mode is reached
May 04, 2017 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Clarion XMD3 No Sound
instead of trying to put a new head unit on it i would get a new wiring harness might have some bad connections in that if that doesnt work a new cd player would be the way to go can get a brand new one at abc warehouse for about 75 bucks
Jun 10, 2010 | Clarion XMD3
Bass and Treble controls
Use Z-enhancer to select custom (you may have to hold it down for 2 secs)
A-M button then selects or bass treble settings.
volume up/down changes the setting
May 19, 2010 | Clarion XMD3
Clarion XMD3 Condensate Problem
the only way to remove moisture is to get it looked at by a local repair shop .Or remove radio yourself ..let it dry for a few days and see if it helped .Water in LCD may not dry completely and may rust LCD with in time
Aug 05, 2009 | Clarion XMD3
I have a Clarion installed in my boat. Sirrius, cd am fm. No jack to plug in iPod. Solution?
FM Modulator.
(clarion makes a hardwire direct connect one)
FM200
You would use a 3.5mm to RCA adapter
There are also battery powerd ones (Belkin)
Either one is used by simply tuning in to an empty (white noise) radio station.
Im assuming the XMD3-RET is not the radio you are inquiring about since you described Sirius as a feature.
Some clarion radios have an AUX input or changer port that can be converted to an ipod cable.
If you reply with a model # i can look it up for you. I am a Clarion Dealer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
Apr 14, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Instaling a Clarion XMD3
clarion website download + print
Jan 08, 2009 | Clarion XMD3
XMD3 unable to select anything but satellite
i have had several problems like that. It is probably one of your controllers especially if you have the old oval ones. Go to the back of the stereo and unplug them, then plug one in at a time and isolate the problem to a controller.
Jul 19, 2008 | Clarion XMD3
Connecting my ipod to xmd3
I believe that if you use the RCA connectors, you can use your iPod. If you use the clarion cca connector, you get more functionality from the dash of the clarion.
Jul 07, 2008 | Clarion XMD3
Clarion Marine XMD3 / SIR-CL1 Sirius Troubleshooting
I had the same problem with invalid channel on all channels ! Had to reset the siriuss receiver by removing power for 15 sec and restoring! that means not just shuting it off but removing all power to the sirius unit not the clarion unit itself and reastablishing power to it turning on the clarion head unit and walah! satelite would recieve ESN and 184 and programing! Hope it works for you after 3 long waiting periods on the phone!
Oct 21, 2007 | Clarion SIR-CL1 SIRIUS Radio Receiver
Clarion XMD3 Logo
408 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
