Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Bought a McCulloch M3414 started okay yesterday wont start today maybe I flooded it, pulled cord so many times
1. set on/off switch to on, 2.prime it first, push the bubble about 6x 3. pull the choke all the way out, 4.pull trigger and string simultaneously 5. push in choke halfway try again, pull choke back out and etc. should start after repeating steps 4 and 5 3x or 4x when it does start, pump the gas at half choke then let it idle untill it stops push in choke all the way and it should start. don't forget to check the safety bar in front of the handle usually works with most gas operated tools
Posted on Jan 05, 2013
2 Suggested Answers
  • 250 Answers
SOURCE: Have a McCulloch Mac110. The
If the saw got overheated it would have that problem. Take a air hose and blow the dirt off the saw. You probably have to take a cover off and blow compressed air around the cylinder fins to clean that area. Also make sure you are using the correct gass oil mixture for the saw.
Posted on Mar 15, 2011
My troy-bilt 5550 started yesterday - won't today
check oil levels look for any obstructions around blades watch your hands
Aug 28, 2012 | Cars & Trucks
Poulan prolink pp335 wont start
In case anyone else hits this question, I had this weed eater and all of the attachments. I had it in my garage for a good 7 years, and it had gas in it 7 years ago.. I've known for some time that it now had no gas in it & that it wouldn't be easy to start if it worked at all.. I put some normal gas in it and dripped a bit of oil into the gas because i didn't have a can properly mixed and didn't want to oil up my lawn mower gas.. I had a guy cutting my lawn for the past 7 years but he recently disappeared..
I primed the weed eater and attempted to start it for a good 20 minutes yesterday to no joy.. I put it away and figured i'd try it again and more in depth today when I had more time. I wanted to take the spark plug out and make sure it was clean, etc.
On attempting to remove the spark plug, I couldn't find a wrench or socket that would work to do so, so I just reconnected spark plug cable and figured I'd give the pull start method another try.. I pumped more gas into the primer and attempted to start it normally a few times.. It wouldn't even attempt to fire. Just for fun since I was going to have to throw this and tons of never-been-opened attachments away, i decided to try something goofy (in my opinion) and squeezed the trigger as far as it would go (which disengages the choke feature..) and gave it a few pulls on the cord.. It attempted to fire a few times, then it fired! It worked very well although it was a little bit thick on the smoke for a bit..
Maybe this answer will help someone else who hits the problem of leaving gas in a weed eater for years.. don't use the choke feature to start it.. start it at full throttle with the primer perhaps flooded a little bit..
Apr 01, 2012 | Garden
I have just bought 2 midi ATV quads, I got one started yesterday and today it won't start and keeps popping when pulling the cord to start. The other one I think the engine has flooded as there is...
If it started yesterday you might have fouled the spark plug or check crank case, air intake system, and exaust pipe for dirt dobber nests if both have sat up for some time I had this problem when I bought one of the same 4wheelers what happens is the crank case builds pressure also the exaust builds pressure and will not let the motor run check for ignition spark parts are vary cheap for the pocket minies check ebay i got a exaust pipe for 13 dollers 49cc also check motosports max.com or type Kazuma.com in your search bar
Jul 23, 2011 | Quad 47 cc / 49 cc Pocket Mini Bike...
I HAVE JUST UNPACKED A NEW RYOBI TILLER BUT WON'T START. NEW GAS MAYBE FLOODING FROM LEAVNG IN START AND PULLING THE START CORD FOR SOME TIME?
yep...take the plug out...pull it 5 or 10 times to clear the gas...dry off the plug....re-install...hold the trigger wide open...and pull...
if that worked, go back and review the start procedures
Apr 18, 2010 | Ryobi Cultivator
Blowing out gas at the start. Drained and filled with fresh gas mixture. Cleaned spark plug and srayed carb cleaner in hole. Pull choke pull cord , blowing gas out of carb. Stuck float? Buy carb kit from...
No floats in chainsaw carbs. Severly flooded most common start problem with chainsaws. Read and follow the start procedure in your manual. Don't use choke on flooded engine (may set fast idle, set then turn off)!
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Oct 31, 2009 | McCulloch Garden
Poulan micro xxv 25 yesterday i started the saw ran fine.tryed today would not start.got gas and spark.loosenthe gas cap firer but would not stay running.thank you.
i'll bet you have it flooded. Try a dry sparkplug. pull it over a few times with the plug out to help dry the cylinder out too
Aug 13, 2009 | Poulan Garden
McCulloch 338 wont start
I assume that you mean it won't run rather than a locked engine. Check for spark at the spark plug. Is it wet with fuel? Is the air cleaner free of sawdust and dirt? If it has flooded, pull through with wide open throttle and no choke.
A locked engine could be a hydraulic lock (a lot of fuel in the upper cylinder) which should be expelled when pulling the starter cord with the spark plug removed, or a mechanical problem like a thrown connecting rod, broken piston or loose ignition components under the flywheel, or a frozen starter mechanism. Good luck!
Mar 15, 2009 | McCulloch Garden
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
134 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
