Question about Husqvarna Sewing Machines
Put in viking machine embroidery arm, the machine went crazy then shut off? help?
  • Elizabeth Jones Jan 29, 2013
    Its a #1+ and by went crazy the needle wont stop going I have turned off and on and I have taken embroidery arm out and back in and it still is acting like this.
    Scholar:
  • Husqvarna Expert
  • 104 Answers
More details needed. What model machine? What does "went crazy" mean? What happens when you turn the switch off, then on again (with the embroidery arm attached)? Does the machine function normally once the embroidery arm is removed?
Posted on Jan 22, 2013
  • 5 Answers
SOURCE: #1 Viking Embroidery #13 Set.
Use any card that has the On/Off in the bottom right og the card (1). You have to know what number is you design so you can push that number after selecting on/off. Make sure you programmed emb card is in the machine. You can use another card if you do not have the generic numbered card with on/off and the hoop positioning E on the right side of the numbers 1 to 35 designs.
Sew Technologist
Posted on Apr 21, 2008
dupina
  • 110 Answers
SOURCE: internal flopppy problem with Designer 1 embroidery machine
Dear bjdouce,
Push the floppy drive lid inwards and do the following:
First of all, check for any visible thread or dust inside the floppy drive.
Secondly clean the drive by blowing it with compressed air.
If this does not help, it is time to upgrade your machine to USB. Great to work with. Cost: plus minus $500.00.
Good Luck
Posted on Nov 17, 2008
  • 192 Answers
SOURCE: viking D1 error message file not found
You need to use either Organizer or Disk Manager to put designs on the floppy disk. Both of these are Husqvarna programs, not part of your computers operating system. If you copy shv file directly, the machine does not have all of the information that it needs to read the files. If the folder containing your original shv files that you purchased contains additional files, you just need to copy EVERY file within that folder to the floppy disk and it might work. Don't attempt to move individual files to the floppy. You will need them all.
Posted on Apr 20, 2009
  • 152 Answers
SOURCE: My sister owns a Husqvarna Viking Iris Embroidery
The Iris Tension unit is controlled by the computer. You can't turn the dial with your fingers. There are 2 buttons on the panel that control the tensioin knob. The graphic looks like rope (sort of) and there is a + and a - on each side of the graphic which increases or decreases the tension.
Posted on Oct 10, 2009
  • 11 Answers
SOURCE: need a manual for Husqvarna Viking 100 series
I would try ebay.com
Posted on Dec 07, 2010
My machine does not recognize that the embroidery unit is attached. It keeps saying attach embroidery unit. Has anyone had this problem
What make and model of sewing machine do you have? I have seen this problem with a Husqvarna Viking Designer I (or similar older Viking machine). In that case, the problem was corrosion on the contacts between the embroidery unit and the sewing machine. The solution was to use an electronic contact cleaner to clean the contacts; this is one product: http://www.amazon.com/CRC-05101-QD-Electronic-Cleaner/dp/B000CCMLD0 . Make sure that the machine is unplugged. Spray the contact cleaner on the contacts. (In some cases, you should then connect the embroidery unit to the machine and remove it a few times.) Allow the product to dry before you plug in the sewing machine again.
In another case, the solution was actually easier. The owner had two similar embroidery machines. She managed to mix up which embroidery unit went with which sewing machine. Neither embroidery unit could be properly seated on the machine that she attempting to use it with. Once the embroidery unit was paired with the correct machine, both pairs worked.
I hope this helps.
Aug 03, 2015 | Sewing Machines
I have a viking designer 1. When I put the embroidery arm on the pressed foot will not stay down. But does stay down when regular sewing arm is attached.
When embroidering, the presser foot hovers above the fabric a few millimeters. The machine does this automatically.
May 04, 2015 | Sewing Machines
How do I take off the arm
On the embroidery unit or regular unit? I have a designer
both comes off easy
Jan 28, 2015 | Husqvarna Viking 1
Why won't embroidery machine arm won't move freely
The arm belts may be in a bind. You will need to have it serviced by a Viking Service Tech. You can find a dealer near you by using the link 'Locate a Dealer' at the Husqvarna Viking Website - http://www.husqvarnaviking.com/us
Jun 28, 2014 | Husqvarna Sewing Machines
Cant get rid of message
I think that you need to have an authorized Husqvarna Viking repair center look at your machine.
The only thing that I can think of that you can do is place your left hand on the embroidery arm that moves left and right. Put your thumb into the opening where the hoop holder comes out and lift the cover slightly. I have seen the cover get pushed down too far so that the sensor inside is not able to move when the hoop is removed so the machine thinks it is still there. Look at the end of this opening in the arm that is closest to your stomach to see if it looks as if the cover is pushed down too far.
Beyond that, several things could be causing this problem, only one or two being serious. Most are simple.
Apr 04, 2009 | Husqvarna Designer I
Machine won't recognize embroidery unit
Isnt their something in the way of the chips that connect the embroidary arm to the machine
Mar 04, 2009 | Singer CE-200 Quantum Futura Computerized...
On 955E embroidery unit, the large black gear snapped
Welcome to FixYa. Hi - Viking has online tutorials for several of the 955E features, including embroidery.
Here is a link to the 955E tutorials. If the link isn't active, paste it into your brower window.
http://www.husqvarnaviking.com/us/6616_393.htm
As mentioned in the next paragraph, you can order a manual from your Viking dealer if you don't have yours. The Viking manuals aren't very expensive, and it is well worth having. You'll find detailed instructions for inserting and calibrating the embroidery arm, which happens everytime you insert the emb arm. See the Hints and Tips paragraph below.
If your machine is broken, the 955E Parts manual lists each part number in the machine, and the 955E Service Manual should provide instructions for repair. But because the 955E is not discontinued (as far as I know), the dealer might not be willing to sell you those manuals or order the parts you need. eBay often has Parts and Service manuals for sale for current model Viking machines, or you might be able to find them for sale on other web sites. Keep in mind that if your machine is still under warrantly, you risk voiding the warranty if you attempt to remove the covers and perform a "non-consumer" repair.
Some general hints and tips for inserting and removeing your embroiodery arm and navigating the Viking web site:
  • Always turn your machine off when you attach or remove your embroidery arm or when you insert or remove an embroidery design card.
  • When you insert your embroidery arm, insert an embroidery design card. When you turn your machine back on, you should see a message on the info screen that says something like "embroidery arm will move". Press OK, and the embroidery arm will calibrate.
  • After the embroidery arm has calibrated, place your hoop on the embroidery arm.
  • Look at each end of your embroidery arm - you will find a connector that must slip into a corresponding connector on the embroidery machine. This connector slides into a corresponding connector on the machine. The connector on the machine has a cover that slides open and closed. If it is closed, it you might not spot it right away. You must open this slot when you attach the embroidery arm - slide the embroidery arm straight back (not at an angle), so the embroidery arm connects to the machine securely. Although you might need to nudge the embroidery arm in place, do not force it!
If you or other viewers have a minute to rate my response (good or bad), your rating will help me to determine whether I unserstand your question and provided useful information. These ratings help me provide better service.
If you have additional questions or more information to add about your situation, please feel free to comment.
Cheers,' Ginny
Feb 10, 2009 | Husqvarna Designer I
Trouble with Viking 955E Embroidery Unit and Control Panel
Here is a link to the 955E tutorials:
Some general hints and tips:
The Viking site also has projects for the 955E that will help you learn to use some of the features - you can probably sew most or all of the free projects on the site, but projects for the 955E incorporate features on your machine that might be available on others. And look for the free designs!
Hope this helps get you started.  If you and other readers have a minute to rate this information (good or bad, or indifferent), your rating will help me determine if I understood your question and if my answer is helpful.
A few more recommendations...You can order a manual for your machine from any Viking dealer and probably online, and I recommend that you do. Your machine has some very cool sewing and embroidery features. I sold Vikings, so I can answer specific questions about many individual features, but Viking manuals are not expensive and can help you save time and avoid irritating problems.
If you have more questions, please comment and I will do my best to help you further. I am pleased to answer general questions about embroidery, if you want hints and tips or run into problems.
Cheers, Ginny
Jan 16, 2009 | Husqvarna Designer I
Embroidery Arm
Here's the number for Viking - they're really helpful over the phone. They can probably walk you through it.
VSM Sewing Inc.
31000 Viking Parkway
Westlake, OH 44145
440-808-6550
800-358-0001
info@husqvarnaviking.com
Feb 02, 2008 | Husqvarna Designer I
Sewing Machines Logo
64 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
